Question about Fujitsu Heating & Cooling
Fujitsu MODEL #ASU12RLS2 OPERATION GREEN LIGHT FLASHING 10 TIMES, THEN TIMER RED LIGHT FLASHING ONCE. IS THIS FILTER RELATED OR DO i HAVE ALEAK AND I LOST ALL MY COOLING GAS.
IT PUSHED WARM AMBIENT AIR FOR A FEW HOURS BEFORE THE LIGHTS STARTED TO FLASH. I TURNED THE BREAKER OFF FOR 1 HOUR, DID A RESET ON THE REMOTE, IT HAS NEW BATTERIES, OUTSIDE GRILL IS CLEAN. THANKS. PIERRE
5 Suggested Answers
SOURCE:
  • 86 Answers
SOURCE: Fujitsu ASU9RLQ
check indoor unit sirkit board
Posted on Mar 15, 2008
hvac1960
  • 2133 Answers
SOURCE: My Fujitsu air condition had
The unit is under time setting. You have to cancel the timer by dis connecting the power and restart.
Posted on Dec 08, 2010
hvac1960
  • 2133 Answers
SOURCE: Hi there, we have a
Indoor coil thermistor is short. Replace it. It's located in indoor coil ending with copper sealed tub. Thanks.
Posted on Feb 02, 2011
  • 117 Answers
SOURCE: fujitsu halcyon ASU12RML unit has
If breaker keep turning off that means you have something grounded and in most cases it's the compressor
Posted on May 19, 2017
Fujitsu asta18lcc has a constantly fast flashing green light and the red light flashes slower 5 times with a small gap between each 5 flashes. Unit wont work at all apart from lights.
The red light (operation) flashing 5 times can be one of four things depending on the green light (timer) but the green light should flash at the same rate as the red light, not faster - either 2,3,5 or 6 times. Anything other than these is abnormal and you will need a tech to diagnose.
Could be a faulty controller board or compressor.
Apr 22, 2017 | Fujitsu Heating & Cooling
What does error message mean on Fujitsu inverter aircon model ASTA30LCC. red operation light flashes on 5 times with green timer light flashing on twice. Can someone please tell me what the fault is?
This is an "Outdoor unit control error" - specifically, a "Current trip error". There is a problem with one or more of the outdoor boards and you will need a tech to diagnose.
Jul 18, 2016 | Fujitsu Heating & Cooling
Fujitsu ASTA12LCC operation and timer lights flashing
You need to record how many times each light flashes before it pauses and then repeats. This indicates a specific error that a tech will be able to diagnose and directs them to the components that have failed.
Dec 27, 2012 | Fujitsu 18C1 Air Conditioner
The green timer light flashes 3 times at 10 second intervals and there is no red operation light on
Indoor fan motor mechanism locked. Rotate manually, if hard, replace bearing or motor. If easy to rotate replace capacitor. Still not working, check your motor windings.
Jan 11, 2011 | Fujitsu Heating & Cooling
Heating & Cooling Logo
Top Fujitsu Heating & Cooling Experts
Felizardo Erilla
Felizardo Erilla
Donni Steen
Marvin
Marvin
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
