Question about Canon PIXMA Office Equipment & Supplies
Trying to get an elderly neighbor's Canon Prixma MP495 working. The paper won't grab to go through the printer. Any suggestions would be appreciated
I have run the clean rollers procedure, changed the ink, tried with a single sheet as well as stack of paper, etc.
    Master:
  • 456 Answers
I don't know. please open as much as possible to see if there is olde paper still in the machine. if clear, maybe a
flashlight would help search for something in feed tray.
if you haven't tried yet, shut off printer. unplug all printer wires. reconnect power cord then load a few sheets. push the 'Stop' button a few times. push and hold stop button down for 15 seconds. try to copy something. if it works, reconnect to computer and try printing off something from notepad as a test. if still not OK. Canon may be able to test machine over the internet. also, there may be updates to
install for your neighbour.
Posted on Aug 22, 2019
SOURCE:
SOURCE: Paper feed problem
i disconnected turned upside down and started shaking it and believe it or not the roller starting working it prints fine!
Posted on May 11, 2008
kristy22
  • 4 Answers
SOURCE: canon HL 5040 printer grabs multiple papers to print
try one sheet at a time that may work.
Posted on Oct 21, 2008
  • 300 Answers
SOURCE: Printer will not grab paper
You may need to obtain the HP Paper Feed Cleaning Kit from Customer Service by contacting them here. While your speaking with them you may want to ask about any issue that have came up with your particular model because I have read they have replaced some models that were even out of warranty.
To use:
It seems that by what Im reading, this is mostly caused by a dried out roller (especially if they are grey so you also may have some other options:
NOTE: These options may void warranty.
  • You may try applying a thin layer of vaseline on the rollers that pull paper. You can usually access these rollers from a door at the back of your printer. This should also soften the rubber. I would suggest running a sheet of plain paper through a couple times to clean off any excess.
  • You can try the Rubber Rejuvenator listed here.
Hope this helps. Please remember to rate this information.
Thanks
Posted on Nov 19, 2008
leroyal
  • 2120 Answers
SOURCE: Color Laser Jet 3800 leaving roller marks on paper
Pull out the fuser at the rear of the machine.
Posted on Feb 07, 2009
ikechinedu
  • 184 Answers
SOURCE: Canon PIXMA MP190 'not responding'
There are possible causes of this not responding status message you get. you will try out these option i have listed here and see which one resolves the problem. after each one, try to print from a file and from the web.
1. Configure driver to correct printer port
On the 'Ports' tab of 'Printer Properties' window, select the correct port for the printer driver.
From the Windows desktop, open the printer's properties window.
Click the Ports tab.
Below 'Print to the following port(s)' section, select the port to which your printer is connected.
Click 'Apply' to accept the changes.
Click General tab and then click 'Print Test Page' to confirm the changes corrected the issue.
2. Checking USB Connections
You should disconnect and reconnect the USB cable at both ends to ensure there is a secure connection on the device side as well as the computer side. It may also be necessary to try a different USB port on the computer. Additionally, you may need to disconnect other USB devices, temporarily, in order to determine if a conflict exists.
Disconnect one end of the cable and then reseat it ensuring the cable is firmly seated into the USB port. If the USB cable is plugged into a hub instead of directly into the computer, try connecting the USB cable directly into the computer.
Repeat step one to reseat the cable on the other end.
3. If there is still no communication, then it may be necessary to try a different USB cable or a different port on the computer.
when you are through, restart the system.
4. Uninstall and Reinstall the Driver
If the MP Navigator or the MP drivers are no longer required, or if they are not installed correctly, uninstall them.
Caution: Uninstalling means deleting software, such as MP drivers, from the computer. Once the software has been deleted the unit cannot be used through the computer until the software has been reinstalled.
Note: Login as a user with Administrator privileges to uninstall . Turn off any programs running in the background, such as antivirus programs and firewalls before begining.
Select 'Program' (for Windows 2000), or 'All Programs' (for Windows XP / Vista) from the Start menu.
Select the name of the printer model to remove and select 'Uninstall.'
When the MP Drivers Uninstaller window is displayed, click 'Perform.'
When the confirmation window is displayed, click 'Yes.'
When the Uninstallation Complete window is displayed, click 'Complete.'
5. Reinstall the Drivers
Note:
The MP drivers can be installed using Easy Install or Custom Install.
Easy Install automatically installs the software which is in the CD-ROM.
This method is recommended if you are a first-time user.
Custom Install allows you to select the software programs from MP Drivers, Application Software, and On-screen Manual.
Login as a user with Administrator privileges to install on WindowsXP/Vista/2000.
Close any antivirus software that may be running prior to installing the drivers.
Turn off the printer and disconnect the cable connecting the computer and the printer.
Insert CD-ROM in the computer. (The CD-ROM will start automatically and the following window will be displayed on the screen.)
If the setup program does not start automatically, click 'Start' and go to 'My Computer', then double-click the CD-ROM icon.
If you use Windows Vista, select 'Computer' from the Start menu, then double-click the icon of the CD-ROM.
At the main installation window, click 'Easy Install' or 'Custom Install'.
When selecting Easy Install:
(A) Click 'Easy Install'.
(B) Click 'Install' in the following window.
* Display varies according to the printer model.
When selecting Custom Install:
(A) Click 'Custom Install'.
(B) When the following window is displayed, click 'MP Drivers' and the application software to be installed, and then click 'Next'.
When the License Agreement window is displayed, read the content carefully and click 'Yes'.
The installation will start.
Messages may be displayed during the installation of the application software.
Follow the instructions on the window and continue the installation.
When the Printer Connection window appears, connect the printer to the computer and power on the printer.
Note: If the installation cannot proceed even after 2 minutes, stop the installation by following the procedures below and start from the beginning again.
1) Click 'Cancel' at the Printer Connection window then click 'Start Over' at the Installation Failure window.
2) At the window to install the driver / applications appears, click 'Back' then click 'Exit'.
3) Restart the computer.
4) Install the printer driver again.
For Windows XP, at the Welcome to the Found New Hardware Wizard dialog box, confirm Install the software automatically (Recommended) is selected, then click 'Next'.
Note: The Welcome to the Found New Hardware Wizard dialog box may be behind the Printer Connection window.
In this case, click 'Found New Hardware Wizard' button on the task bar to display the window.
After the files are copied automatically and the dialog box Completing Found New Hardware Wizard window appears, click 'Finish'.
If the Welcome to the Found New Hardware Wizard dialog box appears again, click 'Finish' again.
At the Print Head Alignment window, click 'Execute'.
Note:
* The Execute button may not appear for all models. In that case, skip to step 13.
* The Print Head Alignment can also be done after the installation of the printer driver.
When the Start Print Head Alignment window appears, load one sheet of A4 or letter size plain paper in the sheet feeder and click 'Print Head Alignment'.
At the Do not start another operation until current one has finished dialog box, click 'OK'.
When the pattern is printed, click 'Next' at the Print Head Alignment dialog box.
At the Installation Results dialog box, check the content then click 'Next'.
The installation of the MP drivers and application has completed. Proceed to the Canon user registration.
If you want to register now, click 'Register'. If not, click 'Next'.
Registration can be done after the MP drivers installation.
Then, Inkjet Extended Survey Program will be launched. If you agree, click 'Agree'. If you do not agree, click 'Do not agree'.
At the Installation completed successfully dialog box, click 'Exit'.
Note: When the Restart button appears, confirm that Restart the system now (recommended) is checked then click 'Restart'.
Posted on May 22, 2009
Why does all-in-one printer Canon MP495 keep showing up as 'offline' when all connections and cables are secure and PC can see printer?
canon mp495 printer offline error.pdf - WordPress.com
https://tumulcozi.files.wordpress.com/.../canon-mp495-printer-offline-err...
the printer model to remove and select 'MP If an error message appears or if you ...computer keeps saying mu wireless canon printer is off line If you feel any of ...
Jul 26, 2015 | Canon PIXMA MP495 InkJet Printer
Fix-ya
This sounds odd. Anyway, if printer prints, there's nothing wrong with printer detection.
First and foremost, what type of paper and color of paper are you using? What text/image color do you have in your file being printed?
Aug 28, 2014 | Canon PIXMA MP495 InkJet Printer
I have a Canon MP495 printer. It grabs the paper crooked and then it jams. I use regular copy paper for my print jobs. I took the paper out of the printer, and it grabbed and jammed. How can I fix my...
Same problem. Turned out to be a small nut lodged in the array of small rollers, just behind the ink cartridges. Managed to lift the roller bar at one corner, and shake it out.
Oct 15, 2012 | Lexmark X73 All-In-One InkJet Printer
Canon pixma mp495 error code E03
e03 is paperjam or out of paper error, make sure you have a decent amount of paper in the tray. open up all the doors on the printer and make sure there's nothing stuck inside the machine.
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Apr 03, 2012 | Canon Office Equipment & Supplies
Mp495 Pulling one side before the other causing it to jam
The roller maybe sticky and cause the paper not to feed evenly. Clean the rollers with methylated spirits.
Mar 04, 2012 | Canon PIXMA MP495 InkJet Printer
My Canon Pixma MP495 series says paper jam but there is no jam!
Hi. In the paper path is a plastic flag sensor . That detect theif there is paper or not . Maybe there is something activating it may it can be a small piece of paper or a foreign object. That sensor is located in the back side of the rollers
Feb 26, 2018 | Canon PIXMA MP495 InkJet Printer
I cant get the machine to grab the paper and it says its out of paper, yet its not out of paper.
Hi, the Ip3000 has 3 different feeding trays...
make sure that the printer is trying to "grab" the paper in the tray that you have chosen to use in the printer properties box...
when you give the print command can you see the rubber roller moving to grab the paper in the top feeder tray???
if the roller that feeds the printer is not moving you may have accidentally changed the settings to grab paper from the bottom tray...the one right under the door that opens to let printed pages out of the printer...
the 3rd feeder tray is the DVD/CD printing tray...
I suggest that you look at the printer Properties for remedial action...
hope this helps you with your problem...
cheers
haitchhcee
p.s.
suggest you place paper in the bottom tray before making adjustments to see if it is trying to grab the paper from there...
Dec 08, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Canon PRIXMA iP2600 Printer keeps jamming when loading paper.
You have a small oyster cracker lodged in the paper path. Turn it over and shake it out good. see what falls out. OK it may not be an oyster cracker but that's what fell out of mine and now it works.
Nov 16, 2008 | Office Equipment & Supplies
Open Questions:
54 people viewed this question
Clive
Clive
old marine
old marine
Ekse
