Question about ASUS M2N-E SLI (M2N-E SLI GREEN) Motherboard
Asus m2n-e sli Cpu changed settings on boots up
Ive had the asus M2n-E sli for just over a month,since ive had this board Ive updated Bios to the latest (1302)
Every time the pc gets to the post screen i get the message
'Warning your CPU has changed Enter CPU settings in CMOS'
Now im Not the dumbest of cpu Geeks & I do take pride in clocking up pc's to an art But for some reason im either having a Dumb moment now & i cant see whats wrong.
I Do Know i made a bad choice when i purchased this motherboard, It IS in my eyes the worst board for overclocking & I do admit it was the only board at the time In My fav shop.
There is one other problem i have at post screen.
Why doesnt my dual core 4200 show up ?(insted it just says Unknown)
Hope you can help
  • Mike 'H'
    Mike 'H' Dec 12, 2007
    I have an upto date Bios ver. of 1302 for the M2N-E SLi
    I did have ver. 0902 before & the reason i update again was tbecause the 0902 gave me the CPU had changed error.
  • Mike 'H'
    Mike 'H' Dec 13, 2007
    returning back to an earlier bios version 0902 /does NOT do the trick BUT just to verify what ive already tried I returned to 0902.
    The Result (No Difference)
    & STILL the error 'Warning CPU has Changed Enter CPU settings in CMOS'
  • 2,351 Answers
I could not find BIOS ver. 1302 for the M2N-E Mb. What I do know: Your dual core 4200 showing up as "unknown". Asus says:
This is because the BIOS does not have the relative CPU uCode to support this processor. Please simply update your BIOS to version 0902 or later to resolve this problem.
BIOS 0902 can be downloaded from the link below:
Once you cpu shows up correctly, chances are that your over clocking will work and the bios will stop sending you back to change your settings.
Posted on Dec 12, 2007
  • Mike Peluso
    Mike Peluso Dec 15, 2007
    I'm glade your on top of this. Your board is warranted for three years. You have done what Asus wanted you to. So here's their direct number. Bummer it's not a 800 number but it is worth it.
    Their hours are EST M-F 9:00AM to 5:PM but many stay till 9:00PM. 812-282-2787 Tech IL. Everyone gets the automated voice stuff. Just follow the prompts.
Will an Asus m2n-e sli run an AMD Athlon X2 7850 2.8GHz am2+
As you can see here
if you have the correct BIOS, yes.
Dec 24, 2010 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
BIOS voltage settings for ASUS M2N-SLI Deluxe 570 SLI chip set.
Hi glen909nwi,
Here's the configuration for that board. If your trying to overclock, you'll want to go with a higher setting.
CPUChiosei HT Voltace 11.20 VI
Allows you to set the pocessorhipset HyperTranspoit voltage.
Configuration options: [1 .20V] [1 .25VJ 11 .30V] [1 .35VJ [+1 .40V1 [+1 .45V] [+1 50V]
Chtoset Core Vo#aae f1.40V1
Allows you to set the dlipset core voltage.
Configuration options: [1 .40V1 [1 .50V] [1 .60V]
Ctitpset Slan&w Core Vo?taoe 11.40 VI
Allows you to set the diipset standby coe voltage.
Configuration options: [1 .40V] [1 .6OVJ
CIhVsef Fi-E Voitaae 11.50 VI
Allows you to set the dlipset PCI Express voltage.
Configuration options: [1 .50V1 [1 .55V1 [1 .60V] [1 .65V] [1 .70V1
CPU Vcore Offset Voltage fDisabdJ
Allows you to csable or set the processo vCore offset voltage.
Configuration options: [Disabled] [Offset lOO.OnIV]
ASUS M2N-SU Deluxe
Oct 21, 2009 | ASUS M2N-SLI Deluxe Motherboard
Powers up ,but no bios beep or video ,displays error 50 on pc analyzer
Accordin to manual: Error Code – 50
Phoenix (50)Display CPU type and speed.(Beep)=2-2-1-1.(50)Per- form LSL instruction test.[Beep]=none Custom chip set or custom platform.
The POST process stop detecting CPU.
M2N-E SLI use Award/Phoenix BIOS.
Oct 19, 2009 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Green flashes
Is your graphic card an Asus ??
If so uninstall the Asus splendid software and reinstall your graphic driver.
May 27, 2009 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Asus |M2N-E SLI Reeboot issues
Hey, I own the same motherboard and I don't have your problem.
I would suggest trying to update the bios, i think its more of a bios problem / motherboard issue, not windows related.
you can get the newest bios from
Oct 20, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Asus m2n sli motherboard
That single beep is most likely POST. Power on self test. You're board, Asus M2N-E SLI uses an Award bios. The beep error codes can be found at this link:
If you are using a single PCI-E card, check that you have the bios set correctly. Shown on page 4.4.6. Do you have you're memory in slot A-1 & A-2? Check that you have PCI-E set for primary display adapter, pg 4.4.4
For windows XP Pro with out SP2, please disale ACPI in you're bios. After SP2 & updates, you can turn it back on. It's realy odd that you're high power PSU did not come with an ATX 4-pin_12v connector for the board. (Needed for CPU).
This is a standard feature for current PSU's. Can you swap the PSU? Considering what devices you are running. You can easely run a 350w PSU? This swap would only be used as a test. Next test, go into the bios & go to Advanced, CPU configuration, check hardware monitor. Stay here a bit & watch temp settings.
Go over these suggestions. Let me know if any one of these suggestions has helped? Can you see the drive in you're bios?
Jun 06, 2008 | ASUS M2N-E SLi Motherboard
Motherboard Issue
Hi Tomokato,
This maybe nothing but the first thing I checked is the CPU.
Supported CPU list through Asus web site for M2N-SLI
(Click on this link).
The first supported 64 X2 is;
Athlon 64 X2 3600+ (CU),512K,65W,rev.F2,SocketAM2
Second CPU supported;
Athlon 64 X2 3600+ (DD),1MB,65W,rev.G,SocketAM2
The CPU that you are using is not supported.
Since this is a new CPU, you might be able to exchange it for the Athlon 64 X2 3600+ (CU),512K,65W,rev.F2,SocketAM2.
Link to Asus main web site for M2N-SLI.
Suggest you add the above link to you're favorites.
Even you're memory is not supported. As seen in user manual page. 2-13.
Have more questions, feel free to ask.
May 01, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
ASUS M2N E SLI Boot and Audio Problems
I would check if there is an updated BIOS available for your board, as this may help
Dec 04, 2007 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Am2 sli fault
does ur monitor light blinks if the monitor light blinks remove ur memory card and cleant the dust on the card and insert the memory card i think it will work
Nov 26, 2007 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
ASUS M2N-E SLI (M2N-E SLI GREEN) Motherboard Logo
411 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
