Question about Panasonic KX-T7630 Corded Phone
Telephone Hi, With the recent rain in India with lot of thunder & lightening my phone stopped working i have to diconnect and connect the cable to get a dail tone if by mistake i dail the wrong number i have to repeat the same procedure again. after making the call i have to disconnect the phone and use another instrument to get incomming calls. I had purchased another instrument earlier but did not use it as the above was working properly. after the above mentioned problem i used the new instrument but to my surprise certain numbers are not dailing. Appreciate your help to rectify the above mentioned problems
  • Mentos Dec 15, 2007
    Dear,
    Sorry, did not reply. you maybe right. due to work load was unable to go to the sevice center.
    Thanks.
  • 85 Answers
Bring your phone to its service center.
have it check, maybe the problem is inside the telephone.
maybe it affected the inner core of the phone's board.
had a problem like that also,
we just brought it to its service center.
and they had to change some stuff..
then it worked again.
no charge if under warranty.
but its P500.00 if not on warranty
Posted on Dec 11, 2007
Phone not working
Hi Pam,
Try these..1...remove your telephone line from base unit and fix it into a working land phone and check whether is it having normal dial tone.If it's having engage tone(beep beep...)remove paralleled phones and re connect to cordless base unit.
2.If line is ok (normal dial tone with full volume) & still display indicates line is busy, your main base unit must be having faulty components inside.Commonly these defects happen in thundering or surges through telephone lines.You have to take full set to a repair shop.
Rana.
Dec 28, 2013 | Gigaset As300 Twin Dect Cordless Phone -...
Caller ID is not working
Hello Samiran mandal, here is a solution.I purchased one cordless telephone (Siemens Gigaset) in Germany. I also had the same problem, caller-id did not work. I purchased this telephone because we can set different ringtones for different caller groups. But, if caller-id doesn't work, this feature also doesn't work. I had gone through internet and finally found that CA electronics, Bangalore has it and got it through courier (I live in Pondicherry). It worked flawlessly for two years. Then it stopped working. For 'no reason' I ordered for a 'caller-id' unit on ebay for Rs.75/- (+ Rs.75 shipping). I just got the unit and fixed it to my line. Very very surprisingly, my cordless telephone is now showing caller info. This is a real surprise to me. By the way, caller-id unit is "Eurotel" make, DTMF/FSK caller-id. I feel this is very nice solution. The 'caller-id' unit is nice (backlit display) and also there is no need of converter for using the caller-id feature of your foreign telephone. I connected caller-id between the line and telephone. That's all. Enjoy.
Apr 12, 2013 | Lands Phones
We have a Frigidaire 2 ton heat pump. The condenser fan hums loudly but does not turn. It was running well until a strong rain storm with thunder and lightening. This is the 4th breakdown, all with...
yes its worth fixing!!!! Take something and give the fan a spin if it starts then you know its your capacitor that run the fan motor if it does not start then it is your fan motor. It will be cheaper to fix this unit then it is to buy a new one!!!!
Aug 20, 2011 | Frigidaire Heating & Cooling
Im here in candaba,pampanga,my 32''inches philips tv is cannot open.the repair man man said,because of thunder thats why they some wires burn....the repair man said,go to philips service...
Hello -
So, you reside in the Philippines. I suspect it was a nearby lightening strike which damaged some of your TV wires and not thunder.
This is the link to the Philips Philippines home page:
https://www.philips.com.ph/
Note: I found the web site for Philips Philippines by using Google, my favorite search engine, and using the following search phrase:
Philips TV Philippines
On that page you will find the link for SUPPORT. Click or tap on that link.
You will be brought to the Philips (Philippines) Consumer Care page:
https://www.philips.com.ph/c-m/consumer-support
Scroll down that page to find the icon and link for SERVICE AND REPAIR. Click or tap on that link.
You will be brought to the page for CONTACT PHILIPS PHILIPPINES:
https://www.philips.com.ph/content/B2C/en_PH/support-home/support-contact-page.html
Scroll down to see the telephone number to call regarding Philips LED TVs. Call the telephone number listed to find where the nearest Philips TV repair center is located.
I am answering from the USA.
Best wishes.
Feb 14, 2018 | Televison & Video
I have an HP 2510 printer. I cannot use it to fax because once I plug the phone jack into the printer I get a busy signal. If I plug the jack into a phone, it works fine. How do I get the printer to...
Hi irwinbadin,
HP fax products are designed so that other telephone equipment can be connected on the same line as the fax. The unit must be connected first using a two-conductor fax/phone cable like the one that shipped with the HP product. Using a four-conductor telephone cable may cause problems receiving faxes or calls.
There are two different types of phone cables. There are two-conductor phone cables like what originally shipped with the HP fax product and there are four-conductor cables. HP fax products are designed to work with a two-conductor phone cable. Look at the end of the cable and verify that it has only two copper leads or wires. Replace any four-conductor cables with a two-conductor cable. Only two-conductor phone cables should be used to connect the all-in-one to the phone line.
Figure 1: The difference between a two-conductor phone cable and a four-conductor phone cable
Step one: Connect the phone line to the fax
The fax will have two or three sockets (or jacks) for phone lines. Some of these may have a removable plastic plug in them. These sockets will be labeled with text, To Wall Jack , or with a graphic of the wall jack. See Figure 1 below.
Plug the two-conductor telephone cable that came with the HP product into the telephone wall jack. Then, plug it into this socket as shown below.
In areas with above ground telephone lines and electrical storms (lightning), it is a good idea to purchase a telephone line surge suppressor and connect it between the telephone wall jack and the fax. This will help prevent damage to the fax from a lightning-caused power surge on the phone line.
Step two: Add other phone-line devices
To connect other telephone devices, use the other socket (or sockets) on the fax. These are identified by text or with a graphic of a telephone and/or computer.
Connect a caller ID unit between the fax and the telephone.
Use the information below that matches the devices you need to connect.
Fax and telephone
Connect a single-line telephone to one of the added sockets on the fax. The telephone will share the same phone line as the fax. See the illustration below.
Fax, answering machine, and telephone
When a telephone answering machine and telephone are connected, connect the answering machine to the fax and then connect the telephone to the answering machine as shown below.
Fax and computer modem
To use a fax and a computer modem on the same phone line, connect the fax to the computer modem. The modem socket on the computer may be labeled Line or Wall jack .
Fax, computer modem, and telephone
To use a computer modem and a telephone with the fax, connect the computer modem to the fax. Then, connect the telephone into the second phone line connector on the computer modem or the third fax socket (if it is available). The image below shows how to connect a computer and a telephone to a fax with two sockets.
Fax, modem, answering machine, and telephone
The image below shows how to connect a computer modem, answering machine, and telephone to a fax. Connect the computer modem to the fax, then connect the answering machine to the computer, and finally, connect the telephone to the answering machine.
If the fax has three phone line sockets instead of two, some of the devices can be connected to the other phone socket on the fax.
Hope it helps.
Thank you for using FixYa.
Jun 27, 2011 | Office Equipment & Supplies
No picture after thunder and lightening although power supply was cut off however cable tv antenna was still connected
Electric current can pass through the tv antenna cables as well. You can try to replace your backlight inverter, but there may also be serious damage to the power supply!
Thank you and best of luck!!
Jun 14, 2011 | Sony BRAVIA KDL32V5500 32 in. TV
Our electricity went out on thursday with a storm for about 10 hours, when the power came back the answering machine plays the greeting for the calls and beeps but doesn't let you leave a message it says...
Did you have a 'Thunder Storm'?....
If so you equipment could be rendered useless.... Lightening travels through Telephone Lines on occaision... seeking ground through your power supply... We have had complete telephone systems taken out by lightening.
Some Household insurances covers equipment.
Jun 28, 2010 | GE 29897GE1 Corded Phone
I can not send or recieve faxes. Ran fax test
Cox Cable is pretty much the same as comcast's and vonage's services. HP fax machines have had HUGE compatibility issues with those types of services, and may be that they did something to their service that caused your fax to stop working.....
Other than that call HP and see if they have any troubleshooting or Diagnostics that you can run, but I ran in to these problems with HP faxes all the time while installing comcast phone service, never knew WHY it didn't work, just that HP doesn't work on that type of service.....at least certain models...Also maybe call COX and see if they did anything recently that could cause it to stop working....
Jun 25, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
My TV-N99i not working in India
The frequency band does match the one in India.. I think it supports 900/1800/1900MHz . Try with Reliance network, maybe they have this band
Jan 03, 2009 | Dual Electronics N99i Cellular Phone
Air conditioner
The lightening may of caused a surge and your unit may have it's own protector that resets and comes back on after a time frame programed into it.
Jul 30, 2007 | Maytag M6Q10F2A Air Conditioner
Panasonic KX-T7630 Corded Phone Logo
67 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
