Question about Cycling
Was having problems with my steering and now realise that the bearing are shot to pieces, but cant get at them to replace them? I have a fron suspencion Mountain bike.
  • 484 Answers
There is an allen screw in the cap on your stem an a couple that clamp the stem to the steer tube of the fork. Take the cap off entirely and loosen the allens on the stem so that the stem can be removed. Now slide the fork down and out of the head tube. If your headset permits bearing replacement, you are all set and can just do that, but if the whole headset needs replacement, you have a much bigger task on your hands. There are tools to do the job, but given their cost and the frequency which you need them, it may be better to just take it to the shop. However, if you are determined to do this with basic tools, here's what you'll need:
A block of wood or piece of 2x4
A mallet or single jack (hammer/jack hammer for single-handed use)
A hacksaw
12" of 1" EMT (Electrical Metallic Tubing; available at the hardware store)
Cutting a 12" section of the EMT off and de-burring the cut end, cut an "X" into the cut end of the pipe.
Flare this "X" out slightly and push the good, uncut factory end through the headtube until the flared section is past the headset bearing cup. Now take your hammer and beat the headset out. Repeat for the other headset bearing cup.
Clean the area of the headtube that receives the headset cup and make sure there are no burrs, then apply a small amount of grease (bike specific) into the same section. Now, using the block of wood to protect your new headset, tap the new cup in gently until the entire circumference is started into the headtube and then beat it in all the way. Repeat these steps for the other side.
Now reinstall the fork and stem, tightening the cap before clamping the stem.
Align the stem and clamp it.
Test and tune the tightness of the cap - if it isn't tight enough, the headset will seem sloppy and noisy.
Posted on Sep 13, 2009
Has power but cant get it goin
see the video and fix it. However if the problem persist LUBE the deck belt+rollers bearing fron and rear.Test the drive belt motor and replace and tight a little.
God bless you
Jun 14, 2013 | Exercise & Fitness
1998 mercury villager van , power steering belt was sqealing, so I replaced all three and it still sqeals and its still the power steering belt thats sqealing. I tried tightening it and that made the belt...
CHECK ALL THE PULLEYS WITH BELT OFF TO SEE IF ANY HAVE PLAY IN BEARINGS
OR ARE CONTAMINATED FROM PREVIOUS BELTS SLIPPING MAKE SURE THEY ALL ROTATE FREELY WITH NO SOUND
May 17, 2011 | 1998 Mercury Villager
The bike wobbles a lot at low speed. the casquette and triple clamp fittings are tight. The wheels are balanced, the swingarm bushes are new and the both wheels are aligned. The all wheel bearings have...
The problem you are describing is just low tire pressure. If you replace the steering neck bearings you also need to replace the races the bearings roll against to properly tighten the neck. One piece bearings are like automotive wheel bearings , It is a cone shaped bearing with a cone shaped race. If you know the dimension of the steering stem and the steering neck inner diameter , you may be able to purchase some.
If your fork slide bushings were loose , or if the inside of the fork lower/bottom were worn they could be sloppy with out leaking past the seal on top of the fork lower/bottom.
I think you need to inspect your tire for cupping and try 35 pounds of pressure that may be all you need.
Oct 09, 2010 | Enfield Bullet Electra Motorcycles
Hey ive just replaced the steering head bearings and i cant get the top seal to go on , the serial number on the seal is 320/28jrrs-2 any help?
The seal is part of the tapered rollor bearing, the seal should not be seperate, you might be able to remove it from the bearing but it technically is one piece, the part number that you should have replaced it with is 92116-1076, the number that you posted up is correct.
Apr 22, 2010 | 2003 kawasaki KX 125
Left fron axle needs replacement
pretty good do it yourself job.take off wheel.loosen axle nut in the center.seperate table from ball joint.give the shaft a few shots with an extension and a hammer to loosen it.loosen the clips around the inner axle boot.pry it out of the tranny.shaft should come out.inspect splines on tips of the shaft.is damaged also take note that the spindle bearing and tranny output bearing might have damage on the teeth.
Oct 04, 2009 | 1998 Chevrolet Cavalier
Heavy steering when turning right but not left on my 1999 honda cb600f
Lift the front end and see if the steering head bearings are loose. Grab the lower end of the forks and see if you can wiggle the steering head. Adjust untill thee is no play there. If your bearings are shot it won't matter and you will have to replace them.
Oct 02, 2009 | 2001 Honda CB 600 Hornet F
Steering dodgy on my honda xr 125
two reasons are that you have either slightly bent your front wheel /or front forks or both even the slightest damage to either of these can throw the handling and steering the best thing to do is visit your local bike dealer and have the aliignment checked /before you do that though raise the front wheel off the ground and check for play in wheel bearings hold the suspension with one hand so the steering doesnt turn then with other hand pull and push wheel from side to side if it rocks it will be the bearings
Jan 22, 2009 | 2006 Honda XR 125 L
Kenmore Front load Belt problem
can your retighten it ,,w / cresent wrench if not bearing is probably shot check for any leaks
Oct 17, 2007 | Kenmore 43042 Front Load Washer
Cycling Logo
66 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
