Hello, Lana -
It looks like the Hoover F5835-900 is a steam cleaner. This is the link to a Sears PartsDirect website where you can download the manual:
https://www.searspartsdirect.com/manual/3rniocgylx-000517/hoover-f5835-900-steam-cleaner
It was easy to locate. I used Google and entered the following search phrase: Hoover F5835-900
Best wishes.
SOURCE: Hoover Steamvac F5892-900 leaving lines on carpet, does not seem to spray
Is the cleaner sucking up the water like it should? If not , check that the filter on the inside of the lid has a 1/4 in. gap between the filter and the top of the lid. Either that or the water isn't completely being shut off when you release the trigger, in whcih case you would probably have to take it in for service.
SOURCE: Belt replacement Hoover carpet cleaner
Hoover steamvacs don't use belts. If the brushes are not turning, pull the brush block out, turn the machine on and see if the square hole where the brush block was, is turning. If not then the turbine is bad. Sometimes you can take the turbine apart and clean it out. most times I have found , replace it.
SOURCE: hoover steam carpet and upholstry cleaner
I have a model F6211. On mine you have to remove the hose caddy and the door is under it.
Hope it helps.
SOURCE: Where can I find a user manual for a Hoover Steam
The manual can be downloaded at Hoover.com for your exact model
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
SOURCE: how do i hook up my stair cleaner part to my
Hi There,
I'll be happy to walk you through step by step how you can attach the hose to your Hoover SteamVac.
Here are step by step instructions for you:
Step 1. To prevent possible leaking, remove
clean solution tank by pressing down on
tank handle (D) and pulling forward; set
tank aside (do not set tank on furniture).
Remove hose from storage rack.
Step 2: Step on handle release pedal (E) and
lower carpet cleaner handle until it rests
on the floor.
Unlatch back part of recovery tank and
remove lid.
Step 3: Remove recovery tank front panel (F)
by sliding it straight up.
Step 4. Replace panel with converter (G).
Slide converter halfway down opening
until it is firmly in place.
Step 5. Before connecting tube (H) to
cleaner, make sure black tabs are
extended by pulling tan collar toward
tube.
Open door on hood labeled “Stair/
upholstery Cleaning Connection”. Press
round solution tube connector onto
round projection inside door. Press connector
collar down firmly to ensure
that it is fully connected.
Step 6. The tank replaces in a hinge-like
manner. Position front of lid under tabs
(I) on front of tank. Rotate lid down onto
tank.
Make sure lid is secure on all sides
before cleaning.
For full suction, it is important that
the recovery tank lid is properly
secured before cleaning.
Reverse procedure to remove hose
and solution tube.
Raise carpet cleaner handle to upright
position.
I hope that this was helpful to you in hooking up your Hoover SteamVac hose. If you found this helpful, please be so kind and rate my repair helpful by clicking the 4 thumbs up icons in the top right hand corner of the repair, this is really appreciated.
Thanks again,
Chris J.
GoVacuum.com
