Question about Xerox Phaser 6100/BD Laser Printer
Want to buy fuser assembly for xerox 6100 from india dealer
I require 4 fuser assembly for the printer xerox 6100 printer in punjab. From where I can got it.
Printer fuser temp
Replace the fuser assembly.
Nov 28, 2013 | Xerox Phaser 6100/BD Laser Printer
I required rc xerox 250 machine in kolkata
Corporate Office
Xerox India Limited
5th & 6th Floor, Block One
Vatika Business Park
Sector-49, Sohna Road
Gurgaon - 122018, Haryana, India
Sales: +91-124-39400400
askus@xerox.com
Ahmedabad Office
Xerox India Limited
Raindrops Building,
405 - 406, 4th Floor,
Main C.G. Road, Navarangpura,
Ahmedabad - 380 007
Gujarat
Sales: 079 - 4004 9864 / 4004 9869
FAX: 079 - 4004 9870
Bangalore Office
Xerox India Limited
Akshaya Commercial Complex
26, Victoria Road, Civil Area
Bangalore - 560047
Karnataka
Sales: +91 80 - 25369143/42
Support: +91 124 2561930
FAX: +91 80 557 1800
Chandigarh Office
Xerox India Limited
S.C.O. 74
Sector-20C
Chandigarh
Sales: +91 172 2708214
FAX: +91 172 2708214
Chennai Office
Xerox India Limited
VDS House, Ground Floor
41, Cathedral Road
Chennai - 600086
Tamil Nadu
Sales: +91 44 - 28116705
Cochin Office
Xerox India Ltd.
1st floor, Kaloor Towers,
36/1951, Elamkulam Road Kaloor,
Cochin - 682017
Kerala
Sales: +91 - 484 - 4456255 / 4456256
Hyderabad Office
Xerox India Limited
6-3-1109, Nav Bharat Chambers
Rajbhawan Road, Somajiguda
Hyderabad - 500082
Andhra Pradesh
Sales: +91 40 - 23405088/20367/68/66
Kolkotta Office
Xerox India Limited
37, Shakespeare Sarani,
1st Floor,
Kolkata - 700 071
Sales: 033 - 44004875
Lucknow Office
Xerox India Limited
I.T.P.I. Bhawan
Capt. Manoj Pandey Crossing
Near Gomtinagar Police Station, Gomtinagar
Lucknow - 226010
Uttar Pradesh
Sales: +91 522 - 2396771/2396775
Mumbai Office
Xerox India Ltd.
1st Floor, Nyloc House
254 D-2 Annie Beasant Road
Worli,
Mumbai 400025
Maharashtra
Pin code no. - 400 030
Sales: +91 - 22 - 4004 9393 - 96
FAX: +91 - 22 - 2493 8729
NLC Hyderabad Office
Xerox India Ltd.
Hyderabad Nagpur Highway,
Survay No. 58, Gundla Pochampally village,
P.O Hakimpet - 500014
Dist. Ranga Reddy
Andhra Pradesh
Sales: +91 08418 -232401
Pune Office
Xerox India Limited
302, Kensington Court
Plot No: 345, Land No: 5
0ff North Main Road,
Koregaon Park
Maharashtra, India
Pin code no. - 411 001
Sales: 020 - 4000 1000
FAX: 020 - 4000 1010
Rampur
Xerox India Ltd.
Modipur Bareilly Road
Rampur
UP -244901
Sales: +91 0595 2357152-4
Find a local Office Products dealer in your area:
Feb 25, 2011 | Xerox DocuColor 240 All-In-One Laser...
Printer error fuser temp
You will have to replace the fuser. Call 1-800-835-6100 and follow the prompts to purchase parts. It isnt real expensive. Just make sure you still don't have some warranty left on the parts.
Mar 09, 2010 | Xerox Phaser 3100MFP/S Laser Printer
PRINTER XEROX 3100MFPX FUSUR TEMP PROBLEM
Most likely you have had a fuser failure. It could possibly be the fuser and power supply board.
If the fuser rolls melted together, I would replace both, if you can remove the fuser and are able to rotate the gear, then just the fuser needs replaced.
Call 1-800-835-6100. They can take care of what you need.
Jan 05, 2010 | Xerox Phaser 3100MFP/S Laser Printer
Xerox Phaser 7700DN jam at fuser
Those rollers are necessary to feed paper from the fuser. Order PN 116-1759-00 which is the 15 inch long shaft w/ 4 rollers
Whit
Item, Inc.
Nov 10, 2009 | Xerox Phaser 7700DN Laser Printer
Xerox phaser 6100 low fuser temperature
The only thing I know to do is to replace the fuser. When you buy a new fuser the installation instructions should come with it.
Jul 17, 2009 | Samsung CLP-500 Laser Printer
Xerox 416si print or copy are dirty
the problem is upper heat roller of the fusing unit are defective.try to ask xerox u.s.a if you can buy only the upper heat roller.
Apr 14, 2008 | Office Equipment & Supplies
Xerox workcentre xd 100 paper gets jams just before intering fuser
On the XD 100 if it is jamming when it is just entering the fuser, check the gear on the end of the heat roll.
Those frequently crack and or flat out break off.
That gear is easily replaced and inexpensive. If you require information where to purchase one, let me know via a message here.
I checked and you can purchase that gear for $14 or less.
Nov 15, 2007 | Xerox Phaser 6100/BD Laser Printer
Xerox Phaser 6100 Fuser Error
Try this,
Reset Fuser Life
  1. Using the control panel buttons scroll to Maintenance, press OK.
  2. Scroll to Check Others, press OK.
  3. Scroll to Fuser, press Reset
Oct 22, 2007 | Xerox Phaser 6100/BD Laser Printer
Xerox Phaser 6100/BD Laser Printer Logo
105 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
