Question about Acer Aspire 4930-6862 Laptop
My touchpad mouse is not clicking
I couldnt able to click any files by tapping the i can click only touchpad buttons so pls give me a soln hw to solve it by myself...
  • 4,281 Answers
First check in control panel that your touchpad mouse is enabled.
Then if it is enable alrady then uninstall touchpad driver then reinstall driver.
If you haven't driver then download driver from this link.
http://gd.panam.acer.com/home/
select your model and operatign system then download touchpad driver.
Let me know if you need more assistanse.
Thanks.
Posted on Sep 13, 2009
Gateway the touch pad not function why?
Adjusting the touchpad sensitivity on a Gateway laptop lets you fix and prevent annoying touchpad problems.
Often the touchpad is accidentally brushed while typing, which causes the cursor to move out of place.
Or you may find yourself having to tap too hard or too often on the touchpad to open windows and programs.
These problems can be fixed by simply adjusting the touchpad's sensitivity settings.
Click the "Start" button and double-click "Control Panel."
Double-click "Hardware & Sound" and choose "Mouse" to open the mouse properties box.
Choose the "Device Settings" tab. Highlight "Synaptic Touchpad" in the Devices box by clicking on it. Click the "Settings" button underneath the Devices box.
Choose "Sensitivity" in the properties settings box.
Click "PalmCheck" to adjust the sensitivity of the touchpad to accidental brushes against the pad while typing, which causes the cursor to move.
Click and hold the pointer to adjust the setting on the sensitivity scale.
Click "Touch Sensitivity" to adjust the sensitivity of the touchpad to tapping.
A higher rating on the scale means less tapping pressure will be needed.
Click "OK" to save your touchpad settings.
May 15, 2013 | Acer Aspire Computers & Internet
Touch pad not working
Click Start/Control Panel andlook for the Mouse and open it to check the mouse properties. Make sureyou don't have the touchpad disabled.
Some models will allow you to toggle the touchpad on or off by clicking on thebutton that is located at the top of the touch pad in the middle.
Some models will allow you to toggle the touchpad by tapping twice in the upperleft hand corner of the touchpad.
Some models will require a keystroke to toggle the touchpad. Press andHold the ALT or FN function key located at the lower left portion of thekeyboard, then hit the key that toggles the touchpad. The correct key tohit will have the icon of a finger pointing at a square that represents thetouchpad.
Download and reinstall the touch pad drivers.Get online and got towww.google.com In the google search box type: "Acer Support"(without the quotes and put your manufacturer name before Support). Lookfor downloads and drivers. Enter your model number and operating system whenrequested. Download and install the Touchpad drivers.
Jun 04, 2012 | Computers & Internet
Touchpad not clicking
go to control panels open mouse properties click on device setting then enable tapping
May 20, 2010 | Acer Aspire One PC Notebook
Hp Paviliion dv4-1365dx .....When I type all of a sudden the cursor will jump and I'll be typing into what I have already typed (just did it)....very frustrating HELP!
Unfortunately the touchpad of most laptops is very sensitive. This will cause the slightest nudge of the thumb or wrist to move your mouse and possibly even "click". In order to avoid this issue and associated frustration, I always 1) disable the touchpad when I have an external mouse plugged in and 2) disable the "tap click" feature. Follow the instructions below for these two suggestions.
Disable touchpad
  1. On my system there is a small button just above the touchpad that disables it, yours might as well. If not, go to Start>Control Panel> Mouse>Device Settings>and Device. Highlight the Disable Button.
  2. Follow the same steps as above but instead of Disable button select Device button and select the Tapping option and unselect "enable tapping".
Good Luck,
NOLA Tech
Feb 06, 2010 | Computers & Internet
Can I disable the touchpad double click feature on
You can go to the control panel and click on Mouse. Look at the top tab and click on settings. The window that comes up shoes the touchpad device, highlight it and click on the settings button. Look at the list of options and click on tapping. Look for the little box and uncheck if it says enable tapping. This will disable the tapping function of the pad, so you will only be able to scroll with the pad and click with the buttons. Click apply and ok.
Jan 29, 2010 | HP Compaq Presario 2200 Notebook
My HP Pavilion Dv6 1030us the touchpad won't work.. It moves okay but It doesn't click! The buttons work fine, the only problem is with the touchpad and is driving me crazy! =/
Try going to the control panel > mouse settings, Open the mouse settings and at the top of the page, there should be a tab for device settings. Click on this tab, It should bring up the touchpad device, highlight it and click on the settings button. When the settings window shows, scroll down to tapping, highlight tapping and make sure that the box is checked for tapping enabled. While you are in there go through all the other settings.
Jan 06, 2010 | HP Pavilion dv6000 dv6100 dv6200 dv6300...
Cannot tap touch pad
There is not a whole lot of information that you are giving us. There would be two reasons the touchpad does not work...one, there is a small button above the touchpad and if it is red (orange) the pad is off and you have to tap that button until the light turns blue. If the light is blue, then the tapping part of the pad has been turned off in mouse properties. Open control panel > mouse Properties > device settings > click on settings button and enable tapping. All other touchpad settings are in there to modify also.
Sep 12, 2009 | HP Pavilion dv6000z Notebook
My touchpad will not respond when I tap it anymore. I have to use the left button. I used to be able to tap or double tap the touchpad and it would act like the left mouse button. All of a sudden it...
On the bottom bar by the clock, if your computer is newer there should be a small icon that controls your mouse. Simply right click on it and check the box "tap to click" or similar. Hope this helps!
Please rate me if i am helpful.
Thank you.
Yboyandrei
Aug 22, 2009 | Acer Aspire One Netbook 8.9" Notebook
Disable Touchpad Clicking
Hiya, At the bottom right of the screen, by the clock, you should see an icon for the touchpad.....
Hint : Hover the mouse over the icons and wait for the "Pop-Up" Display to see what they do if your not sure.
When you find the one for the touchpad, simply right click it and scroll down to the option that says "Tap To Click" and left click it so that there is NO TICK next to it..........
........ This will DISABLE all tap click options and leave the touchpad as a touchpad and the buttons as buttons...........
Hope This Helps, Kind Regards,
Me :D
Mar 19, 2009 | Compaq Presario 700 470024-192 Notebook
"sticky" mouse on compaq laptop
Unless your left mouse button has been severely damaged, it is unlikely that a loose button is the cause of your problem. More likely, it is your touchpad. Chances are your touchpad is set to click when tapped. Oversensitive touchpads can click randomly when you're dragging your finger across the touchpad.
To test this, position your cursor over a link (or other button) but don't press the left mouse button. Instead, lightly tap the touchpad itself. If the link or button is clicked, go to your Control Panel and adjust the Mouse options so your touchpad no longer clicks when tapped. It's usually a setting titled "tap to click" or something along those lines.
Regards,
Javabytes
Nov 07, 2007 | HP Compaq Presario V2000 Notebook
Open Questions:
See all Acer Aspire 4930-6862 Laptop Questions
Acer Aspire 4930-6862 Laptop Logo
1,783 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
