Question about Whirlpool GU2400XTP Built-in Dishwasher
The clean light is blinking diswasher won't start
I ran the diswasher, it ran through the cycle and stopped at cleaning, i can't get that light to go off by touching cancel/drain, i can't get the dishwasher to start a new cycle
  • 220 Answers
Push these buttons in this order High temp wash > Heated dry>High temp wash >Heated dry all the lights will come on and this will reset the board and run it through a short test cycle but more than likely it will come up again,It's a failure in the heating cycle either the heater itself or the turbidity sensor which sits mounted up into the tub right behind the drain pump...hope this helps
Posted on Sep 13, 2009
Testimonial: "i tried the sequence of buttons that was suggested and my dishwasher reset itself and is now washing!!!"
This same problem happened to my diswasher and I watched as the repairman did the button sequence in case it happened again. It did and I was happy that I paid attention. Then one night around 3:00 am (I always ran it at bedtime) I smelled something burning. I got up and looked around and found it was the dishwasher. I immediately went to the fuse box and shut it down. We called the company and was told that we were still under warranty for the electronics (check your warranty). They fixed it for free and it has been fine since. I do not however run the diswasher while in bed anymore.
Posted on Sep 14, 2009
Clean light keeps blinking; dishwaher won't turn on
Hello Brian, welcome to FixYa.
Based on your post I understand your dishwasher is a Kenmore and the clean light is flashing and it won't start, correct ?
If so, this is usually an error code indicating there was a problem in the heating process the last cycle it ran, however if you could provide the complete model number I could speak specifically to whether it applies to your machine and potentially what to do about it.
Thank you for choosing FixYa and I look forward to your reply.
Regards,
Macmarkus :)
Oct 12, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
I have a Kitchen aid dishwasher model # kudpo1ilbs6 the clean light is blinking 7 times then stops for a sec and does it again
I am assuming the problem does not go away when you turn the mains power off and on.
The problem is linked to the temperature variation in the incoming water.
This confuses the diswasher. You have to reset it now. Try this sequence..
Press heated dry, normal heated dry, normal quickly within 5 sec. All lights should light up.
Advance through the cycles by using the start button
Please post a comment to confirm if this helps.
Oct 12, 2010 | KitchenAid Dishwashers
Clean light wont stop blinking
This is a code that the water is not being heated. this could be caused by a bad heating element, lack of water, computer control problem or an inadvertant error. all things involved with heating the water need check. the computer has to be reset using a diagnotic mode. wiring info usually behind toe panel may help to solve the problem. please include model # if further info needed.
Mar 20, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Icemaking cycle automaticall self stops and cleaning light blinks
ice machine runs one cycle and freezes ice will not release ice block to wire cutter. then after a few minutes the cleaning light starts blinking
Jun 11, 2009 | Kenmore 51lb. Clear Ice Maker
Cleaning light will not quit blinking after cleaning
The same thing happened to our Mr. Coffee this week! I followed the instructions about running vinegar through, then rinsing several times with water. However, the light would not stop blinking. We did by-pass the light by setting the timer for delayed brewing and it worked. However, that blinking light came on again. Then, my husband tired the vinegar wash again but instead of doing it one time, he ran the same vinegar through 6 times until the light went out! Then he proceeded with the water rinse. Our Mr. Coffee is working again!
Nov 16, 2008 | Mr. Coffee 072179228578 12 Cup Coffee...
Cuisinart Coffee Maker Model # DCC-1150
Unplug for longer than 15 minutes to completely reset it
Oct 09, 2008 | Cuisinart DCC-1200 Coffee Maker
Blinking clean light
replace the dishwasher thermistor if it didn't work than replace the computer board.
May 09, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Self clean light blinks, oven does not work
You were right. The locking mechanism switch somehow became jammed and the oven thought the door was locked, even though I could open the door. I didn't know if I was supposed to take the top off and moving the lever back and forth did not help. Finally I turned the oven on and just kind of jiggled the latch in the unlocked position. I kind of moved it back and forth furiously and the cleaning light stopped blinking and the oven light came on. I'm glad it is working now, but I will be manually cleaning my oven from now on! Thanks for your help.
Dec 25, 2006 | GE JGBP26 Gas Kitchen Range
Whirlpool GU2400XTP Built-in Dishwasher Logo
602 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
