Question about Bosch WFL 2062 Front Load Washer
My Bosch WFO 2062 is leaking water while it works. It's not from the draining tubes on its back, for I have already checked. The water comes from the front part of the washing machine. I have raise it but still could not see where it comes from. Can anybody give a hand solving this problem ? Thanks!
Mine was doing the same and i got the door seal/gasket changed
Posted on Oct 19, 2010
  • Bosch Master
  • 744 Answers
This video will show you how to change a door seal on this Bosch WFO 2062 front loader washing machine
Posted on Jul 22, 2013
BOSCH MAXX WFO 2062
Have you checked the outlet pipe that the machines pipe discharges into ? Sometimes these get filled up with sludge etc and may siphon back in smelly water at the end of a cycle. You could also see where the pipe drains into the sewer system , see if there is a local blockage.
Jan 08, 2014 | Washing Machines
I have a Kenmore Model # 253.62812202 refrigerator. It collects water at the bottom of the vegee and fruit trays at the bottom of the refrigerator which eventually leaks out onto the kitchen floor. Does...
It has a clogged drain tube and bottom trays is already full.
De-clogged it using a solid wire, match enough to penetrate the drain tube.
Insert solid wire slowly to the drain tube, back and forth.
Put water to clean and rinse drain tube.
Regularly check drain tube for clogged and tray for full water.
Good luck.
Jun 27, 2011 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Have Bosch Classixxx WFO2466 - won't drain water from drum. Have filtered the water from the bottom and checked pipes but no blockages. Think display panel has gone a bit crazy. Is it worth getting...
Hi eileenhanks,
It is always better to have an expert check it for you. Might only be the drain pump not working, or even a loose wire on it. Replacing the Display Panel is a no-no (Waaay to expensive).
Most likely (my expert opinion), drain pump faulty, or loose wire between the PC Board & pump.
Good Luck :-)
If you found this solution helpful, please rate accordingly :-)
May 11, 2011 | Bosch Classixx WFO 2466 Front Load Washer
My dryer is leaking from the bottom. service man said either the tube or the pan is cracked. tube seems ok, so is the pan replaceable or glueable. could there be another reason to look for leak. dryer has...
Open the bottom front panel. Remove the heat exchanger. Take notice to see if theres any water in that compartment. Reach your hand towards the back of that opening to see if there is water pooling back there. If theres water present, then your condensation pump needs to be replaced.
also double check the connection of the drain hose from the dryer to the drain.
Jan 09, 2011 | Bosch Axxis WTL 5410 Electric Dryer
I have cleaned conditioner draw and checked pipes but it is still not going down, why?
Could be the solonoid valve not working, what to do is pour some water in and see if it drains away without overflowing if it does its a Valve if not then chance is its Blocked some where.....Hope you sort this . please leave me feed back
Apr 09, 2010 | Bosch Exxcel WFO 2264 Front Load Washer
My Bosch Exxcel 1100 will not drain, after manualy emptying it i have opened the front filter cap checked the filter and i can see the impellar spinning but when it is full of water it will not drain
Could be the impellor is slipping under load, or there is a blockage between the pump outlet and the point it drains into the waste pipe.
Try blowing down drain hose to see if it is blocked.
Feb 22, 2010 | Bosch Exxcel WFO 2264 Front Load Washer
No display lights on panel
Probably not without replacing the board.
Jan 26, 2009 | Bosch Exxcel WFO 2465 Front Load Washer
Water level sensor faulty
needs must.........you will need to remove lid........look for thin plastic tube coming from bottom of the drum to the top of the drom......connecting on a small plastic unit......this is the pressure sensor.....remove the tube.......blow down it a few times.............might be blocked by grit etc........
cheers
May 27, 2017 | Washing Machines
Bosch WFL 2062 Front Load Washer Logo
578 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
