Question about Dishwashers
My DRyer just quit working. no warning, just stopped. It had a tune up kit and was serviced about a year ago so it has new ish belts etc. I change the lint trap between every load.
    President:
  • Dishwashers Master
  • 1,922 Answers
Do you have power to plug?then it could be a broken hot or neutral wire from plug to inside of unit or a bad breaker or wire from your main house power panel
Posted on Sep 13, 2009
My whirlpool large wasjer seemed the belt was squeeking .... then it stopped spinning.. Is it worth is to get a new belt repaired or buy a newer one.
Of course it worth to change the belt, is more cheap then a new washing maschine.
After 7 years of usage my Samsung washing machine was doing same problem. I change the belt with a new one about 3 years ago, and it's working fine.
All the best !
Nov 06, 2017 | Whirlpool Washing Machines
Dryer has no heat
I have one of those Kenmore "Laundry Center" stacked washer/dryer units. It comes built that way - it is not two units stacked on top of one another (if there is such a thing).
My guess is that it is at least 13-14 years old now (it came with the house I bought) and about 3-4 years ago, it also stopped heating. The dryer would run for a couple of hours and all of the clothes would still be damp and the air in the dryer was not warm or hot.
I searched online and found that the usual cause is the heating element wire was probably burned out if the dryer was otherwise running all right. I found some repair instructions online and the procedures to take the dryer apart (can't recall where - just Google it).
The heating element is like a long coiled resistance wire, similar to what you would see in a toaster but heavier duty. It is strung in a circle behind the dryer drum tub to heat the air that enters the dryer.
If you've ever looked into a toaster when toasting, you'll notice that that thin resistance wire glows red hot which generates the heat. Now imagine that thin wire being red hot and the dryer tumbling, causing constant vibration. It's amazing that the heater resistance wire doesn't break more often!
A pretty handy DIY-er can take the dryer apart and replace the heater wire, but the challenge is getting the stacked unit out in the open somewhere where you can work on it. You need a fair bit of room.
My advice would be to also buy the drum belt replacement kit to also replace that at the same time. If you're going to go to the trouble of taking the dryer apart to replace the heater wire, you might as well replace the drive belt and associated felt pad, etc. at the same time. You DON'T want to have to take the dryer apart again a little later to change that part when it breaks. (It's like a timing belt on your car - if you're doing major work on your car and have the engine apart and it's "about time" to replace the timing belt per the manufacturer's maintenance schedule, might as well do it a the same time to save on repeating the labor again.)
Apr 05, 2014 | Kenmore 98702 Stacked Washer/Dryer
I had my water pump and timing belt replaced and now my car shakes when in drive at a stop. it idles at 500rpm when i give it gas manualy to 650 rpm it stops shaking. it did not do this before I had the...
It's possible that your timing belt is installed one notch off and is idling rough because the cam is too far advanced. There is no such thing as a tune up on cars made after the 1990's. The only tune up items left on the later vehicles are sparkplugs and plug wires; everything else,e.g., fuel mixture, spark timing etc. are controlled by the computer.
Jun 18, 2011 | Chrysler Concorde Cars & Trucks
My dryer quit working this morning. The light and beep go off but the drum dies nothing.
I have the Frigidaire Affinity Washer and Dryer. A few weeks ago my Washer door switch went out I changes that with no problem. Now the Dryer has just stop quit working. Here are the symptoms on the ; 1>it's plug up and the power is fine 2> there is no errors on the panel 3> control operate fine. 4> close the door, set the controls, press start, No spinning. 5> when you press start you hear a buzzing sound for about 5 seconds, then nothing... Is it over for the dryer I bought 3 years with out extended warranty, or is the a simple fix? Thanks, Rob...
Sep 07, 2010 | Frigidaire Affinity AEQ6000WH Dryer
How do i change a carborator
If you're vehicle is 84 or prior you may have a carburetor, (some models earlier or later by a few years) if you are asking about the van you have in the picture spot for the question that looks like 98-2004 ish Caravan, no way it has a carburetor. It would have a throttle body probably. If that isn't what you're working on you can check for an ID tag on the carburetor and order a new one (or a rebuild kit) and rebuild it or straight bolt on bolt off replace it. Most new carburetors come tuned to stock specs... so you shouldn't need to tune it once its on.
Jun 26, 2010 | 2000 Dodge Grand Caravan
The Service engine soon warning light
it may have nothing to do with it or it might, you will have to let them scan it and see what code pops up and then go from there. maybe something got lefy off or got knocked off during the tune-up.hope this helps.
Jan 27, 2010 | 1996 Ford Taurus
My kenmore dryer stopped heating.
yes the price of fixing it is less then a new unit most of the time.
you might need new heating element or cut-off switch only.
Jan 19, 2010 | Kenmore 94702 Front Load Stacked Washer /...
CDE6000W, Crosley dryer stopped working in middle of load
it could just be the motor going out some dryers only last 6-8 yrs some dryers continue to be quite even if there going out i suggest call a repair preson to see if repairing it is worth it
Here To Help
Shaun
Nov 17, 2008 | Crosley CDE6000 Electric Dryer
Dishwashers Logo
Top Dishwashers Experts
