Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Aquarias wd 420 hotpoint
When plugging in washing machine it is popping from inside the machine then blowing the fuse.have had electric checked and plug sockets are ok.it is a hotpoint aqurias wd 420 can you help
  • 142 Answers
Sound like motors or heaters have a short good luck.
Posted on Sep 14, 2009
Washing machine not heating
PLEASE CHECK THE WATER COMING TO THE FRONT WASH FRONT LOAD WASHER DONT HEAT THE WATER IT AS A HOT AND COLD WATER VALVE CHECK WATER VALVE
May 02, 2014 | Hotpoint WMA50 Front Load Washer
Wash enhance is flashing program not advancing
iv got a hotpoint aquarias wf 514 all lights are flashing whot do i do
Jan 03, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
I have a hotpoint wd420. the door light is flashing the wash light is on constant and the machine wont work anyone any solutions please!!
My WD 420 packed up, after watching the blogs I did:1) remove filter - found 2 quid, a thong, a pop sock, a christmas cracker toy and a load of gunge. 2) removed the motor - brushes worn to nothing - replaced them.
Washer running as new. 6 years old, 2 house moves - not bad reliability. Nearly gave up and bought a new machine!!
Nov 11, 2010 | Hotpoint Ariston Aquarius WD420 Front Load...
Machine is completely dead. Fuse and plug ok.
hello, have you checked the glass fuse inside the washer's power supply ,but beware if you put another one in and blows again then you have dead short , make sure you use the same rated fuse
hope it helps
regards
shaun
Oct 11, 2010 | Hotpoint Washing Machines
Dryer not working on aquarius wd 420
call him explain still not working if hes not willing to help tell him your going to turn him into states attorney general you can file complaint online his company will get black mark and will haft to answer to the state!!!!! check for restrictions on exhaust hose-if not call reputable company and send bad mechanic bill!!!!
Jun 24, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Hotpoint WD 865- washes ok, dryer won't work makes loud popping
sounds like the dryer heater element has worked loose perhaps and shorted out against the metal dryer box which sits on top of the drum.
best to get an engineer out i'd say.
Jan 14, 2009 | Hotpoint Aquarius WD63 Front Load...
No power to washing machine
If this machine is totally dead and it tripped your home electrics - (which is probably a 30amp fuse) means that it is likely a serious fault in the machine. :-(
Washing machines take out ring main fuses if there are faults in the washers heater unit,motor or suppressor. Also water may have breached a seal somewhere and cause a short inside the electrical compartments. The flash you saw was probably some sensitive electronics and any smaller internal fuse popping. It is possible that simply replacing internal fuse will result in doing more damage once power is restored.
To fix a fusing washing machine you have to use a diagnostic electrical meter that puts high voltage across the appliance - Not something I can offer more info on. So whatever has happened (and in the interest of safety) you would probably want a qualified proffessional to take a look or as a last resort a hotpoint engineer!
Kind Regards
Feb 21, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint WD51 fuse issue
is it the motor that got hot?, if so then check the motor carbons for wear, as these heat up when worn, also if the carbons are fine check the pump and filters for blockages, this makes the motor spin while water is still in the machine causing the motor to overheat, and subsequently tripping and blowing the fuses etc hope i have helped a little
Sep 25, 2007 | Hotpoint WD52 Front Load Washer / Dryer
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
119 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
