Question about Ovens
I have a Vsl 6000 that has been shutting down there's no sounds on the relay when this happens. We've replaced the circuit board thinking that was the problem but it's happened twice during since.
3 Suggested Answers
SOURCE:
aborcass
  • 2651 Answers
SOURCE: oven is noisy
next itme you get an authorized co. to come look at it ask them to call the "techline", f&p has an excellent tech resource hotline for us tech ive never called and had them not at least lead me in right direction.
Posted on Feb 27, 2008
jumptrout51
  • 3361 Answers
SOURCE: F3 Fault Code appears
What it needs is a new temperature sensor.
Unplug the range. Open the oven. Look in the top right or left side of the oven for a metal rod about 1/2 the size of a pencil. Remove the screws holding it in. Pull it out very carefully. Unplug the wire connector. Reverse this order to replace the temperature sensor.
Posted on Sep 16, 2009
Testimonial: "Thanks! I'll forward the solution to the tech when he arrives today."
Broiler comes on on top oven every time you turn bake on and won't go off. Recently replaced temp sensor for similar sporadic problem and worked for a while but now happens every time
Stove will not turn off CHECK
Temperature Control Thermostat
If the oven won't turn off the oven thermostat is often the cause of the problem. The electrical contacts inside the oven thermostat can weld themselves together and then the oven won't turn off. If this happens, turn off power to the entire appliance at the household circuit breaker or fuse. The oven thermostat usually cannot be tested and must be replaced if defective.
Oven Control Board
The oven control board has a set of relays that turn on and off power to the bake and broil circuits according to the customer settings and sensor input. If the oven won't turn off it could be that one of the relays on the oven control board is shorted closed, providing voltage to the heating circuit. It can be dangerous if the oven won't turn off. Don't leave the oven unattended without turning off power to the oven.
Relay board:
Some ovens are equipped with a relay board. This circuit board has several relays which control the switching of electrical current to the oven heat source. If the oven won't turn off it may be that one or more of the relays on the relay board have failed. If this happens replace the relay board. The relays on the board are not sold separately. ALSO CHECK THE BAKE AND BROIL ELEMENT.
: I offer free advice bcuz God is so good!
May 20, 2015 | Ovens
How do I fix oven staying on
Oven Control Board
Relay board:
Apr 22, 2015 | Ovens
Fisher Paykel double oven light and heat won't shut off
Oven Control Board
Relay board:
Mar 13, 2015 | Fisher and Paykel Ovens
After cleaning the control panel ribbon, the oven will not shut down (top and bottom ovens. Is this the thermal oven shutdown fuse that needs to be replaced? If so, how do I remove the fuse from a W
Oven Control Board
Relay board:
Dec 28, 2014 | Whirlpool Ovens
Why will my whirlpool oven not cut off
Oven Control Board
Relay board:
Jul 28, 2014 | Whirlpool Ovens
Oven will not shut off just keeps getting hotter
Oven Control Board
Relay board:
May 21, 2014 | Whirlpool WOS51EC0AW 30" Single Electric...
Why won't my whirlpool double oven model# GBD 307 cut off, plus getting a F2 E0 error code
Oven Control Board
Relay board:
May 06, 2014 | Whirlpool Ovens
We have a whirlpool double oven, model RBD245PDB12. Oven cooks well but, will not stay off, buzzes long and short intermittently throughout day and night flashing F2 code or E6.
Oven Control Board
Relay board:
Feb 13, 2012 | Whirlpool Ovens
GE profile lower oven does not turn off...maintains low heat with the convection fan on for several hours.. When i turn oven back on and then off it stops...but the problem continues to happen periodically
Oven Control Board
Relay board:
Sep 12, 2009 | GE Ovens
My oven keeps beeping F2 and it won't turn off. The top broiler coils are bright red and heat is pouring out of the oven. I have held down the off button, pushed start, pushed bake, anything I can think...
Control senses oven temperature above 615F-630F. shut down the breaker switch asap.
If actual over temperature condition occurred: Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC).
If no over temperature condition occurred: Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective.
Remember: Oven control (ERC) measures resistance of sensor circuit , not actual oven temperature.
Jul 08, 2009 | GE JGRP17 Gas Single Oven
Ovens Logo
22 people viewed this question
Top Ovens Experts
Marvin
Marvin
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
