Mitsubishi CS 35301: No vertical deflection: Is this repairable? Set is ~15 years old. Is it worth repairing? There were no problems prior to this failure.
    President:
  • 1,922 Answers
Either your vertical output transistor/I.C. is out or possibly a coupling capacitor is bad,does it try to fill the screen if you tap on the cabinet, if so open up the back and using something like a drink straw prod and push on the board and see if you have just a "cold" solder joint
Posted on Sep 13, 2009
Testimonial: "I worked in home electronics repairs long ago, when vacuum tubes were the standard. Your tip made me feel as confident as when I was the pro in this "
  • 525 Answers
Yes it is fixable . easy fix by a professional.some little components failure or bad connections
I have a Mitsubishi CS 3515R 35" Tube TV. The screen has narrowed at the top and the bottom so only about 2/3 of the horizontal screen has picture. There are black areas at the top and bottom....
There are two issues, the first is a vertical deflection problem, "needs a few parts+an ic" the second problem is intermittent color, "crystal and color processor ic" If the set is close to 10 years old then your money is better spent on a new tv.
Mar 20, 2011 | Mitsubishi CS-35503 TV
When I power on my Mitsubishi CS-35313 tv, I only get a thin horizontal line across the center of the picture tube. What could be the problem?
There is a failure in the vertical deflection circuit. Typically there is a vertical output i.c. that provides the deflection vertically. The i.c. itself is a fairly common component to fail. There are some lower power circuits that feed this output device that also could be the problem. When the electron beam in the tube is not deflected vertically it "writes" only horizontally across the center of the screen thus resulting in a single trace. Be careful not to leave this at high brightness for any extended time as it can "burn in" that area of the screen. Unless you are a "techi" this is a job for a qualified technician. Troubleshooting would be in the vertical deflection section of the set. Most of the parts are not expensive in themselves, except for the deflection yoke which sits around the neck of the tube. The cost to repair would typically be the shop labor.
Nov 25, 2009 | Televison & Video
When we turn on the VS-5051 we hear a click, but get no power led, no sound, and only a thin white line across the screen. Can you tell us if this is worth fixing?
Hello: The problem with your television is that you have lost vertical deflection. The white line indicates you still have horizontal deflection, and the answer to your question. Is it worth fixing? My answer is yes This is a common problem that happens to all tube type televisions at some time in the life span of the television. The part that has failed is the vertical deflection IC and or the voltage to power the IC is missing, But the most common parts to fail in the vertical section are pump up capacitors on the output stages of the vertical signal. Parts for this problem are very cheap. IC around $12.00, Capaictors around .58 cents each, may require two of the (Capacitors that is). Highly recommend repairing this Set. Should not cost you more than $150 in labor and parts to repair this set.
Sep 25, 2009 | Mitsubishi VS-50501 50" Rear Projection...
I have a 15 year old Zenith console, SL2737RK, lost vertical defl
You need to resolder the vertical IC and replace any electrolytic caps in the same immediate area. If you can find someone with electronics experience they know what I'm saying....It can be repaired.
Sep 24, 2009 | Televison & Video
No picture
Symptoms shows TV got problem in Horizontal deflection area that's why you do not see picture and get only sound.I think its not worth to repair as its 14 years old model and spear parts might not be available or cost too much. Since you still want to repair it, let me know exact model number of TV to check parts are available some where?
Jan 10, 2009 | Mitsubishi WT-46805 46" Rear Projection...
1995 Mitsubishi 40" Television - Worth Repairing?
there are bad solder connections on the vertical deflection IC resolder them and you will be fine
Mar 13, 2008 | Mitsubishi CS-40503 TV
Mitsubishi CS-27205 shrunken picture
Good set...worth repairing vertical circuit.....in shop...
about 100.00........................T.
Nov 15, 2007 | Mitsubishi CS-27205 TV
Mitsubishis TV Problem
have a Mitsubishi TV 1993. Model CS-35301. The problem is that there is a white line that is running through a blank screen. The sound is fine just no picture. Have you heard of "Vertical Collapse?" I would love to save the TV. Hi nothing to worry just minimise brightness to avoid screen burn. "Vertical Collapse?" means one bright hor.line in the middle of screen. this problem can be solved 1 check vertical yoke connector or wire loose 2 check supply to vertical section which normally comes from EHT transformer check components in vertical section or print loose regards thanks
Sep 10, 2007 | Televison & Video
Vertical Sweep
If the quality of the picture was good before it failed it is worth repairing,replacing the vertical Ic should take care of your problem and for a service technician is a fairly easy repair and they usually dont charge too much,maybe 100.00 to 150.00,if you take the set to someone is less the charge but I know is heavy and it might not be an option,shop around for the price of an estimate in your house.
Sep 30, 2006 | Mitsubishi CS-35505 35" TV
Televison & Video Logo
142 people viewed this question
Top Televison & Video Experts
