Television will not come on - Televison & Video
  • 525 Answers
Check outlet power, then if you know how to do that pwoer cable, then fuse inside. after here professional technician have to be called
Posted on Sep 13, 2009
I am asking for Sansui plasma TV codes pls!
The codes for a universal remote to work with a Sansui television are:
Sansui television remote code 834
Sansui television remote code 0310
Sansui television remote code 0394
Sansui television remote code 20695
Sansui Google Search
Dec 27, 2016 | Sansui Televison & Video
Lc37aa1m
1. Buy a monitor to computer cable (VGA cable),
2. Connect one end to the television,
3. Connect the other end to the computer (video port),
4. Turn on both of the television and the computer,
5. Select the television input (VGA or XGA) using the television's remote control device.
Dec 25, 2013 | Sharp Televison & Video
I locked my tv and dont have a remote how do i unlock it?
In life, simple yet unexpected events take place, such as the loss or an accidental breakage of the television remote. When a television is locked while the remote is missing or broken, it makes matters worse. Locks are placed on televisions for privacy or age-restricted viewers. To prevent a repeat of this event, store an extra remote in the house or business where the television is located. Without the original remote, some alternatives are available to remove the lock.
Difficulty: Moderate Instructions things you'll need:
  • Television manual
    • 1
      Read the manual. Televisions are accompanied by manuals when new. Some contain information on operating the television without the remote. Search for the "Lock" or "Privacy" section in the manual. If applicable, follow the given instructions.
    • 2
      Reset the television. You can reset and eliminate the lock on some televisions without the remote, using a few tactics. Hold the power button for five seconds. The television will automatically restart. If the lock is still on, unplug the television and remove the battery from the back panel of the television. Wait several hours before reconnecting the plug and reattaching the battery.
    • 3
      Purchase a universal remote. If the manual or resetting option does not work for your television, you need a universal remote. You can get one of these in electronics stores or online. The universal remote supports most televisions. The universal remote manual is included in the purchase and will instruct you on installing it into the television. After installation, enter the lock code using the universal remote.
May 09, 2011 | RCA 32F531T 32" TV
When I turn on the TV the picture comes on for about 30sec. to 1 min. then the picture goes off and the standby light(green) flashes continuously for approx. 30sec and then the pictures comes back for...
The problem with the television is that the lamp is bad and need to be replaced. This is as a result, of overheating inside the unit of the television. Be sure to have your television where there is proper vent.
Try to unplug the television for a while before working on it as the television stores high voltage in it. Then you Turn to the back of the television, then you unscrew the television and assess the lamp of the television and replace it with a new one.
Reassemble the television back together and power it on. That way it will work properly.
Dec 31, 2010 | Sony KDF-E50A10 50 in. LCD HDTV
Keep always blinking the green lights indicator ones i plug the power cord. no video, no raster on the screen.
The green lights on a Sharp television indicate a problem. The number of blinks is a code. The television has gone into a coma in order to protect itself. You can force this television on by doing this. Unplug the television. Hold down the vol+ and channel down button on the television and while holding them down still plug the television in. This is a temporary way to view the television but the problem will get worse if not repaired. Should the television power on this way unplug it when you want to turn it off without pressing the power button at all.
Dec 09, 2010 | Sharp LC-32SB24U 32 in. LCD TV
Is the tuner built-in ATSC, or NTSC?
Your tv tuner is set to function on both NTSC and ATSC. See below for the reference
NTSC (National Television System Committee) is the analog television broadcasting standard used widely in North America. It is referred to as a 525-line standard, but actually displays only 480 lines. NTSC is to be replaced with new DTV (Digital TV) standards in the coming years.
ATSC (Advanced Television Standards Committee) creates the technical standards for the US digital television system (DTV). These standards are expected to be used in most new televisions, as the US television system shifts from analog to digital.
Nov 10, 2010 | Toshiba 57H84 57" Rear Projection...
No picture
If you are having sound but no picture on your television, the problem is the t-com board of the television.
Once you have the t-com board replaced, your television will be in good condition once again. have a repairman replace the t-com board of your television and you television will be in good condition once again.
Goodluck and take care
Oct 10, 2010 | Sanyo DP42746 42 in. Plasma Television
2003 Sony Trinitron 36" television. Just shut off, light blinkin
The STANDBY light will flash if the television detects an issue within the television. Some of these issues can be resolved simply by following the steps below to reset the television.
If the issue is still unresolved after following all of the troubleshooting steps, Service will be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
Sep 14, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
No picture or sound?? status light flashes in four blinking intervals. I was told it could possibly be the lamp it has never been replaced.
The STANDBY light will flash if an issue is detected within the television. This can sometimes be resolved by simply following the steps below to reset the television.
  1. Turn off the television.IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  4. Plug the power cord back into the electrical outlet.NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
Aug 08, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
Television won't turn on
The light inside the television might be broken that is why it doesn't work.
Jun 07, 2009 | Dynex DX-LCD19-09 19 in. LCD TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
