Question about Canon FAX-L800 Plain Paper Laser
Saving fax numbers
How can i save frequently used Fax numbers in the Fax machine ?
  • 85 Answers
Yes, you may.
If the Fax machine has a Memory function press it.
then type the number then enter.
or read the manual..
or visit www.canon.com
Posted on Dec 11, 2007
I need to send 1 fax to several recepts
You can send a fax to up to 142 fax numbers, using any combination of dialing methods:
- One-touch Speed Dialing (up to 32 destinations)
Press the desired One-Touch Speed dial button(s)
- Coded Speed Dialing (up to 100 destinations)
Press [Coded Dial] > enter the 2 digit code (00-99) using the numeric buttons and be sure to press [Coded Dial] before each code
- Regular dialing and redialing (10 destinations)
Enter the number using the numeric buttons or [Redial/Pause] and be sure to press [Set] after each entry with the numeric keys
After all the numbers are listed, press [Start]. The machine will scan in the document (memory) and then begin sending it to the destinations in numerical order, starting with One-Touch, then Coded and finally the numbers dials with the numeric keys.
You can also create a group if you frequently send faxes to the same group of people by first saving them as One-Touch and then adding them to a new group.
Apr 13, 2011 | Canon FAXPHONE L170 Plain Paper Laser
How do I program my fax numbers?
You can program your fax number by going into the menu, go to initial setup and then station ID.
The station I{ will save your name and fax number (you do not need to put either one if you do not want to).
Thanks,
Pat
Nov 08, 2010 | Brother IntelliFax-2480C Fax
How to delete and program in speed numbers for fax
Create speed dial entries for fax numbers that you use frequently. The number of speed dial entries you can set up depends on the HP device. For more information, see the specifications for the HP device.
expanded.gifTo manually create a speed dial entry 1 In the HP Solution Center, click Settings, point to Fax Settings and Setup, and then click Fax Speed Dial Settings. 2 Click New Entry. 3 In the Speed Dial Settings - New Entry dialog box, type a name and fax number, and then click OK. 4 In the Speed Dial Settings dialog box, click Save. The entry is stored on the HP device.
Note If you are creating a speed dial entry for a networked HP device and you are unable to save the entry, another user on the network might have accessed the same speed dial. Wait a few minutes and try to save the entry again. expanded.gifTo create a speed dial entry from the Address Book 1 In the HP Solution Center, click Settings, point to Fax Settings and Setup, and then click Fax Speed Dial Settings. 2 Under Address Book, click Select From. 3 In the Address Book dialog box, select one or more names, and then click OK. 4 In the Speed Dial Settings dialog box, click Save. The entry is stored on the HP device.
Sep 11, 2009 | HP Office Equipment & Supplies
Cant change fax number of machine
GO INTO THE MENU AND YOU ARE LOOKING FOR FAX SET UP IN THERE YOU WILL FIND A SECTIOON TO SET D FAX HEADER AND NUMBER THE HEADER IS THE NAME THAT SHOWS WHO IS SENDING THE FAX IE ..VOLVO TULSA OR WHITE HOUSE!!! YOU ENTER THE FAX NUMBER BY THE DIAL PAD AND PRES IOK TO SAVE
Jun 26, 2009 | Brother IntelliFax-2820 Laser Fax
How to save numbers
Your machine can store up to 30 numbers. To store numbers, use the following process:
  1. Press functioni button once
  2. Press right arrow > once
  3. Assign a two digit speed dial number or press the right arrow (machine will suggest a 2 digit speed dial number
  4. Enter the fax number (use speaker button if a mistake is made to clear)
  5. Press Start/Memory button
  6. Go to Page 28 in user manual
At this point, there's a chart for entering names for the fax numbers which can be found in the owners manual at this link: http://www.sharpusa.com/files/fax_man_UXP115.pdf
After the name has been entered, press Start/Memory button to Store and press Stop button to leave the process.
Best of luck and hope I helped.
Greg
Jun 16, 2009 | Sharp UX-P115 Plain Paper Thermal transfer...
How to save fax numbers
press Function
72
set
1 for ONE TOUCH NUMBERS
set
press 01 on the soft pad
enter fax number with the DIALING NUMBER KEYS
set
enter name with LETTERS on the soft pad
set
continue with 02, 03, 04 etc.
when done press stop.
press Function 67
set
cut out directory sheet on dotted lines and put under the mylar sheet on the soft pad.
press Function 62 set to print out the list of one touch numbers.
Nov 19, 2008 | Panasonic Panafax UF-560 Plain Paper Laser...
Need to change 1 fax number in group dialing on a cfx-L4000 fax
All the numbers saved in group dail,are separatly saved in the one touch speed dails,you have to locate that fax number in one touch dails and change it there.
Nov 19, 2008 | Canon Laser Class 310 Fax
Have Lexmark X9350 All in one - Need to block incoming junk faxes
You can find these instructions on page 140 of the User's Guide. The English User's Guide is here: http://images.lexmark.com/publications/pdfs/2007/9300/v1116690_en.pdf
If you have Caller ID, you can block faxes sent from specific numbers and/or all faxes which do not include a Caller ID number.
To turn on the Block List feature:
  1. From the control panel, press up arrow or down arrow repeatedly until Fax is highlighted.
  2. Press select (checkmark).
  3. Press up arrow or down arrow repeatedly until the Fax Setup submenu is highlighted.
  4. Press select (checkmark).
  5. Press up arrow or down arrow repeatedly until the Fax Blocking submenu is highlighted.
  6. Press select (checkmark).
  7. Press up arrow or down arrow repeatedly until you reach the Block List menu item.
  8. Press left arrow or right arrow repeatedly until On appears.
  9. Press left curved arrow to save and exit.
To add each fax number you want to block:
  7. Press up arrow or down arrow repeatedly until you reach Blocked Fax Add Entry.
  8. Press select (checkmark).
  9. Use the keypad numbers to enter the name of the person associated with the fax number in the Name field.
  10. Press down arrow once.
  11. Use the keypad numbers to enter the fax number in the Fax Number field.
  12. Press left curved arrow to save and exit.
To block faxes sent from an unidentified number (a number with no Caller ID):
  7. Press up arrow or down arrow repeatedly until you reach the Block No-ID menu item.
  8. Press up left arrow or right arrow repeatedly until On appears.
Sep 29, 2008 | Lexmark Office Equipment & Supplies
Fax confirmations
i have read the manual end to end and I don't think you can.
Only thing I see is this.
Customizing your settings using the Lexmark Fax Solutions You can adjust the fax settings in the Lexmark Fax Solutions. These settings apply to the faxes you send or receive.
  1. Click Start onestep.gif Programs onestep.gif Lexmark 7100 Series onestep.gif Lexmark Fax Solutions.
  3. Click each tab and change the settings as desired.
  4. Press Save Settings after you finish your updates. Nothing is saved until you press this button.
  5. Click Close.
The following table contains the Setup and Settings tabs for the Lexmark Fax Solutions.
On this tab
You can
Personalize
  • Enter your company name and fax number.
  • Enter your name, company name, phone number and address as you want them to appear your cover page.
  • Select a cover page for your fax.
Send
  • Choose to use error correction.
  • Choose to use fax header.
  • Select a maximum send speed and a print quality for outgoing faxes.
  • Choose whether to scan the entire document before dialing the number.
  • Select when to print a fax usage report.
  • Select when to print a fax activity report
Select when to print an activity report is the only close item I can find. Nothing whatsoever about a confirmation report.
Feb 25, 2008 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
One Touch Dialing numbers won't permanently save to FAX machine
If you followed the procedure F 7, 2 set, 1 for speed dial, enter your free speed dial space, enter your fax #, set, enter the name, set.(continue to next free speed dial key or stop) If this doesn't work then you may have a bad battery on the main board that saves the data if the power goes off.
Feb 04, 2008 | Panasonic Panafax UF-560 Plain Paper Laser...
Canon FAX-L800 Plain Paper Laser Logo
67 people viewed this question
old marine
old marine
