Question about LG Incite Cell Phone
I have the same problem and the phone is one week old
My phone pad/screen won't unlock or allow me to do a hard or soft reset. The phone is only one week old!
I forgot the unlock code for my HTC Ozone. I bought it from a friend,who bought from a friend....anyway I can bypass it?
  1. You will have to restore it to factory settings (hard reset) . Im assuming since the phone is new this isnt a problem. Follow the steps below
  2. From the Today screen, press the left soft key to choose Start.
  4. Select System Tools then press the center of the 5-way navigation pad.
  5. Select Clear Storage then press the center of the 5-way navigation pad.
  6. Select Factory Default. Enter 1234 then press the left soft key to choose YES.
Please leave me a rating if Ive helped you :)
Mar 11, 2011 | HTC Cell Phones
My htc touch pro 2 smart phone screen is locked and seems to be frozen, I have reset and removed battery with no results how can I unlock this screen?
It might be a hardware problem, if you already tried the soft reset (removing the battery) then the next step is to hard rest. This will lose all your information and settings, the phone will be like the first day you took it home (and hopefully the screen will work)
First make sure the phone is off, then press and hold the TALK/SEND, END and POWER buttons until you see a message on the screen.
Once the message appears release the buttons and press the volume up key for a hard reset.
May 31, 2010 | HTC Touch Pro2 Smartphone
I fogot my password...how do i unlock my phone...i
I hope you have your contacts backed up because there is no way to unlock it without performing a Hard Reset. First hold down both soft keys and the soft reset hole at the bottom by the memory card slot simultaneously. The soft keys are the 2 dots to the left and right of the D-pad. If you do it correctly, on-screen prompts will appear on a white screen, just follow it from there!
Feb 18, 2010 | HTC PPC-6800 Smartphone
Im looking for the unlock code for a samsung sgh a707 phone from at
SOFT RESET
On the main screen, type:
*#337#+ call button this is the soft reset code it will reset your password.
if that dont work you will need to do a hard reset .
a hard reset will erase all data from your phone. SAVE ALL PICTURES MUSIC ect....
HARD RESET
*#6810# + call button
Then:
*#337# + call button
Nov 14, 2009 | Samsung SGH-A707 Cellular Phone
Hardreset samsung omnia i900
How to Hard Reset the Samsung Omnia Many people do not know how to hard reset the Omnia phone. The manual does not teach you the trick of doing this. You may follow the steps below to reset it to default factory settings.
1. Poke the soft reset hole beside your power button(Poke and Release)
2. Press and hold the Call and Cancel Button together(Do it immediately after Step 1)
3. Do not release Call and Cancel button, the Samsung Omnia Screen Appear
4. The Reset Screen will appear as below
This is a snapshot of the Samsung Omina Reset screen.
(Image from mobilesilence.blogspot.com)
Press Call to Format or End Call to Cancel.
This hard reset does not erase the 16GB memory. To reset everything, you could use the software hard reset by going to Settings > Hard Reset. There is also option to format the storage card.
If you decided not to format and press cancel, that will soft reset the phone.
Another Method to Hard Reset
There is another method to Hard Reset, just key in the following code on your Dial Pad
*2767*3855#
After keying in the code, the Phone will restart itself. Phone will be reset to defaulf factory settings straight away. For DZIA5 Firmware, it will format the My Storage Card also.
Reference : taken from " pspmyspace "
Best Regards
Jul 08, 2009 | Samsung SGH-i900 Omnia Unlocked Cellular...
HOW TO HARD RESET MY PHONE LOCK FOR THE BEHOLD
This Indian dude does not know what he is talking about, the instructions he is giving you is to reset a Wing not the Behold below is the exact reset steps to reset the Behold.
Remove your sim card and turn you phone on, it should read no sim mode, press the phone button to get the numeric screen type in the following:
*2767*3855#
It will automaticall reset your phone wait a few minutes and your phone will reset to manufacturer defaults.
Feb 24, 2009 | HTC Touch Cell Phone (Unlocked) - Soft...
Unlock problem
Do a hard reset. To do a hard reset hold down the red and green buttons on the front of the phone and push the reset button on the bottom of the phone at the same time with the stylus. This just fixed my problem
Sep 18, 2008 | HTC Touch Cell Phone (Unlocked) - Soft...
D pad keys do not work
the dopod 838 is a real pain in that all the screws loosen themselves up. just tighten them up and they should start working again
Jan 23, 2008 | Dopod 838 Smartphone
LG Incite  Cell Phone Logo
73 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
