Question about Dishwashers
The 3 second light is on- wont run - Dishwashers
  • 220 Answers
You locked out the control board push and hold the button for 3 secs and it will unlock.
Posted on Sep 13, 2009
Smv63m00gb/16 wont start
Are there any display light flashing or error code in the display window.
Is the drain pipe Ok.
Nov 05, 2014 | Dishwashers
Nissan troubleshooting
the eml light stays on on every car if it isn't running. this is a bulb check to make sure the bulb is working. you have air in the line. turn key to run for five seconds then off then on five seconds 6 times then it will start. you need to prime the system by doing this on off
Nov 21, 2013 | Cars & Trucks
My 1993 nissan sentra 1.6 wont run and check engine light wont turn on,bulb is ok
Could be any of several things. If the crank sensor is marginal and not sending pulses, the fuel pump is shut off. This is for safety. The pump is energized for a few seconds as key is turned in preparation for starting then engine must rotate normally to keep the pump on. If it stops, in a few seconds the fuel is cut off.
Aug 17, 2012 | 1993 Nissan Sentra 4 Door
Defrost switch wont light up
Dicky switch, dicky light or dicky earth. Take it to an auto electrician - it will save you time and probably money in the long run.
Apr 06, 2012 | 2001 Oldsmobile Alero
Acer x3400 wont start up
Remove the Power Cord and then press and hold the power button for 30 seconds. After 30 seconds plug the power cord back in and press the power button. If it reboots you had a Static Charge Buildup and released it by holding the power button for 30 seconds.
When you press the power button do you hear the fan running, disk drives running, cd drive clicks once, anything on the lcd screen? If not I would think your Power Supply is bad and needs to be replaced.
It's either the Power Supply or Motherboard.
Mar 23, 2012 | Acer Aspire X3400 PC Desktop
Ive fitted 4 k and n filters and now it wont run properly also the oil light comes on after 10 seconds
have u adjusted the oil/air mixture screws on carb when u changed air filters?if not then this needs doing , thats why wont run propely, its still set up for standard filters.
May 03, 2009 | Yamaha XJR 1300 Motorcycles
Abs light wont go out
When u power up the vehicle ABS does a self test(light stays on a few seconds then cuts off) and if it see's a problem will shut off and illuminate the ABS lamp. It will also do a second test on iself when you reach a speed of around 12-15 mph,it will run the pump for a few seconds to check pressure and look at the speed sensors,if it see a problem here it will again shut down and illuminate the ABS light.
Now if the red brake lamp is on then it will shut down because it thinks you have a hydraulic concern and will not try and run ABS if this is the case.
If red brake lamp is on most likely if you have good brakes it is a problem with the float sensor in the master cylinder reservior,maybe its bad or just stuck,or just low on fluid.
Feb 12, 2009 | 1992 Ford F250
Dishwashers Logo
77 people viewed this question
Top Dishwashers Experts
