Dryer continues to exert heat from the back panel hours after use. We have been unplugging after use due to concerns.
    President:
  • 1,776 Answers
Ths sounds like a grounded heating element. Upplug the machine. There is a danger of electical current flowing throught the body of the machine. The heating element should be checked using a multimeter. Make sure the heating element is not grounded to the body of the machine. Hope this helped and best wishes.
Posted on Sep 13, 2009
I have been having a problem with the heat in my dryer for a while it worked but took over 2 hours to dry....than it totally shut off with NO power...a few days later it came back on but no heat at all..I...
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape or with an ohm meter to test the thermostat/thermistor. (Should have/show continuity)
If the coil heats up then replace the thermostat/thermistor.
(Thermal fuse.If it overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace the element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
This is a FREE answer, Please rate me
Dec 27, 2010 | Kenmore Elite HE4 Electric Dryer
Duet Dryer not heating Tumbles but does not heat.
I would suspect a heating element on this model first. Unplug UNIT remove three screws at bottom of toe kick panel and remove unplug heating element check for continuity at terninals of heating element it will be the first two you will see in front
Hope this fixes your concern
Aug 13, 2010 | Whirlpool GEW9250 Electric Dryer
Dryer ran for hours and did not stop automatically, now runs but wont heat?
Good day,
If set to automatic and there is no heat it will run continually run without shutting off. You'll need to trouble shoot the heating problem.
A lot of the problems are due to limit fuses and limit thermostats located in the back. Beyond that you'll need to supply the model and whether its gas or electric.
May 14, 2010 | Kenmore 500 6952 Dryer
Or kenmore dryer won't heat up. How to pull the front panel on the dryer??
You mean back panel
Should be just a couple screws
Unplug first.
Check the element and the thermal fuses for continuity
Feb 28, 2010 | Kenmore 63942 Dryer
How to replace gas coil valves on Whirlpool LGR5636EQ3 Gas Dryer
DOES YOUR DRYER HAVE THE LINT SCREEN ON THE TOP? IF SO, REMOVE THAT AND TAKE TWO SCREWS OF(CARE NOT TO DROP IT INTO THE VENT). PULL THE TOP PANEL TOWARD YOU LITTLE BIT AND LIFT UP, THERE WILL BE TWO 5/16 SCREWS INSIDE FRONT PANEL, REMOVE AND UNPLUG THE LID SWITCH CONNECTOR, FRONT PANEL WILL COME OUT. THE GAS VALVES AND COILS ASSEMBLY WILL BE ON THE BOTTOM RIGHT. UNPLUG AND TAKE THE SCREWS OFF THE BRACKET AND REPLACE COILS. CHECK FOR CONTINUITY ON COILS, IT SHOULD READ 1.3 TO 1.9 OHMS. THE ONE WITH THREE TERMINAL, CHECK OHM FROM MIDDLE TERMINAL TO OUTSIDE TERMINALS.
BOYNISMO@YAHOO.COM 714-334-1998.
Aug 21, 2009 | Whirlpool LGR5636L Gas Dryer
Dryer won't heat.
Hi, THe heating element is located in the back of your dryer. UNPLUG the dryer. Remove the back panel and you will see the element on the right hand side. If you have an ohms meter, check continuity on all the thermostats and the element. If any of them have no continuity, it will need replaced. Please let me know if I can assist you further.
Thanks
Vic
May 16, 2009 | Whirlpool LER5636P Electric Dryer
Heat element
if your dryer isn't heating, it's possible that your heating element needs to be replaced.
are either of these pictures of your dryer?
Whirlpool dryer 1
whirlpool dryer 2
May 15, 2009 | Whirlpool WED5521SQ Electric Dryer
My kennmore gas dryer will not heat it spins and i turn the timer on and off and that works there is gas to the unit
unplug dryer , remove back panel and you will see a thermo link in about the middle of the back of dryer with a vom test continuity of the link this is a very common problem . if no continuity replace thermo kink . if it tests good remove access pane in front of dryer and turn the dryer on to a heat cycle, see if the ignitor coil gets red hot. if it doesn't then the ceramic coil is bad. these are the 2 most common problems with gas dryers. if still no good write back
Jan 26, 2009 | Dryers
My whirlpool dryer is dead
Most newer dryers have a thermal fuse link which prevents them from producing heat if it has overheated due to lint build up. Safety! Remove the back of the dryer after you unplug it of course. Look for a white, two connector, block about 1/4 by 1-1/2 inches, mounted to the back of the heat transfer duct. Remove both of the wires from the the connectors and test the fuse for continuity. Multi meter needed. This should show 0 Ohms. If there is no change on the meter than this fuse is bad. Most any appliance parts place will have in stock. $12 - $15 Clean out as much lint as posible from the exhaust opening with a vacuume and reinstall the back panel.
Nov 20, 2008 | Whirlpool LER4634J Electric Dryer
My GE electric dryer's heating element will stay on when the dryer shuts itself off after running through a cycle. Even if the dryer is in the "off" position, the dryer will become hot to the...
It sounds as if your heating element may have broken in one area and fallen against the element shround and grounded itself out. This will cause the element to bypass the safety circuitry and continue to heat, but at a lower wattage. You were very diligent in unplugging the dryer.
You will have to replace the heating element. Do not attempt to repair the element as this will only cause a hot spot and will burn in two again.
May 28, 2008 | Dryers
Washing Machines Logo
Top Washing Machines Experts
