Question about Sony SA-VA100 System
I am trying to find and purchase the flat ribbon speaker cable that connects the two front speakers together. Contact: simpsrl@msn.com
  • 10,594 Answers
Please intimate Sony home theater system model number to provide you flat ribbon cable part number info.
Thanks.
Posted on Sep 13, 2009
  • Shahid Electronics
    Shahid Electronics Sep 13, 2009
    Please find listed below the model and serial number?
    Model # SA-VA100L
    S/N: 8802493
    Thanks,
    Rudy L. Simpson
    Thanks for model info, get back to you shortly with info.
    OK, required connection cord has 15 pins and its part number is as follows..
    177711711 CORD (WITH CONNECTOR)(15P)
    It is not available in part shops as far I searched.
    Thanks.
  • 1,555 Answers
You have not mentioned the serial number hence here is the link from where you could choose your cable.
http://www.boxwave.com/products/easyfinder/buy-best-sony-dslr-a100-accessories_2083.htm
My panasonic says f61 when i switch it on wat do i do
An F61 error occurs on a Panasonic home theater system when the speaker cable wire connections are wrong. This situation is likely to happen if you just purchased your unit or moved the system and try to reconnect the speakers again. Polarity is key in a successful setup. The positive and negative ends of the cable wires must match the input of the main unit. Retrace your speaker wire connections to clear error F61.
Step 1 Attach the speaker labels to the speaker wires for easier identification, if they're not already labeled. At minimum, labels for front left (L), front right (R) and center speakers should be included in the packaging contents that came with your system.
Step 2 Verify that the white ends of each speaker cable are connected to the corresponding "+" positive inputs for each speaker.
Step 3 Verify that the blue ends of each speaker cable are connected to the corresponding "-" negative inputs for each speaker.
Step 4 Push the plastic ends of the speaker wires on each speaker to verify that each is locked into place.
Step 5 Connect the remaining end of the "Front (L)" speaker wire to the white terminal/connector on the main unit.
Step 6 Connect the remaining end of the "Front (R)" speaker wire to the red terminal/connector on the main unit.
Step 7 Connect the remaining end of the "Center" speaker wire to the green terminal/connector on the main unit.
Step 8 Connect the remaining end of the "Subwoofer" wire to the purple terminal/connector on the main unit.
Step 9 Connect the remaining ends of the "Surround (R)" and "Surround (L)" speakers to the wireless system.
Sep 11, 2016 | Panasonic Audio Players & Recorders
I got a set of Sony SA-VA15s from a yard sale. They didnt come with the 13 pin ribbon cable. Will the left speaker work without this cable? I tried to hook it up and nothing.
no you need the ribbon this connects the all together to get the sound usless with it get in touch with sony tell them what you haver they usuall have spare parts they will send you a new one, worth a try if not ebay is the answer
May 04, 2014 | Audio Players & Recorders
My HP 610 laptop's inbuild speaker is not working,but with the external speaker it is working.I want to know the price of HP compaq 610 inbuild speaker.
Try the following steps:
Open your laptop carefully (look out for fragile ribbon cables) !
Check for a broken wire going to the internal speaker.
Check for a faulty contact at the audio output jack (these things have a contact which disconnects the internal speaker when a plug is connected).
Temporarily connect any speaker in the place of the internal speaker.
If the problem is still the internal speaker, remove it and go to any good audio components shop and buy an equivalent speaker.
Hope this helps.
Nov 25, 2011 | Computers & Internet
I took this laptop apart to try and fix the sound jack and speakers, in the process of doing this I think I damaged a couple of pins on the flat ribbon cable with 12 pins that goes from the power button to...
the smoke means that you have a short circuit somewhere on your laptop double check the connections that you have made you might have to replace the flat ribbon make sure there is no dust at these connections you have to keep a computer free of dust/causes static electricity otherwise it can cause it to overheat and many other problems
hope this helps
May 12, 2011 | Acer Computers & Internet
I tried to extend the length of my front right speaker (power/vol) by purchasing a male to female VGA extension cord. When I connected bothe cables together and then to the sub everything stopped working...
I doubt the extension cord has something to do with that...Usually if the wires are short it would effect the main unit. Check the wires first,not only of the front right speaker but the others also...if they are short. If there's a fuse in the main unit you might find yourself lucky...otherwise you will have to get it checked by a mechanic.
Aug 06, 2009 | Logitech X-530 Computer Speakers
Need longer ribbon speaker wire for Acoustimass 16
I have the same question. I just called Bose at 1-877-210-3782 (prompt 6) and they have two solutions:
1. 20 foot Input extension - $25
2. Input adaptor - $12 (you can run your own speaker cable to the input adaptor)
Apr 10, 2009 | Bose Acoustimass 16 System
Speakers crackling and making a 'clicking' sound when volume high
The cable you are using to connect to the speakers could be duff or the connectors could just be dirty.  clean the connectors and push it in and out of the socket repeadedly to ensure you have a good connection.  Or you could try a different cable.
Mar 01, 2009 | Logitech Z-5300 Computer Speakers
Sony SA-VA100 System Logo
203 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
