Programming bc147xlt uniden scanner
I'm attempting to program my uniden bc147xlt scanner. I bought the scanner off of ebay and it didn't come with a book or instrutions. If you can help me that would be great.
Thanks,
Bill
  • 2 more comments
  • Don80 Dec 26, 2007
    Same problem. I bought a used BC147XLT with no manual. How do
    you set the frequencies in it? I know the frequencies, but don't know
    how to set them in.
    Thanks,
    Don Schirmer
  • Anonymous Apr 22, 2008
    don`t have programming manual with it.
  • clarie46 May 10, 2008
    i am trying to program frequencies into the scanner & when I push the number 1 then put the frequency in it then press e it is fine but if i try to put #2 in it then when reviewing #1 there is nothing there please let me know what I am doing wront thanks
  • jimmy1934 May 18, 2008
    BC147xlt
To program the uniden bc147xlt use the manual button to select channel you want to program. punch in the desired 6 digit frequency then press E, press review to check that frequency was input correctly then use the manual button to go to next channel for programming.MAKE SURE WHEN ENTERING FREQUENCY YOU INPUT THE (.) AFTER THE FIRST 3 DIGITS FOR EXAMPLE GO TO CHANNEL 1 PRESS 149.220 E AND YOU should have no problem programming . hope this is helpful
Posted on Jan 16, 2009
Using the Manual Button, choose what channel you want to program, enter the 1 st. 3#'s, press the decimal button then enter the final 3 #'s, press the E button & proceed with each channel. It is better if you start at channel 1 & write down the freq placed on each channel for future reprogramming if need be. This process works on most scannerrrs!
Posted on Jan 12, 2008
Try this link it worked for me.http://wiki.answers.com/Q/How_do_you_program_a_Uniden_Bearcat_bc142xl
Posted on Sep 01, 2008
I also have the same scanner but most/if not all of my local frequency channels are 8 digits long when my scanner will only allow 6 digits. Can I omit the last few 0's at the end of the frequency number and if so will it still program the channel?
Thanks!
Posted on May 26, 2010
    Genius:
  • 2,985 Answers
You will have to contact the manufacturere for details of this device.
Posted on Dec 12, 2007
Uniden Bc147Xlt Manual
Try Retrevo Manuals.com lots of manuals!!!
Nov 21, 2013 | Radio Communications
I inherited a uniden bearcat BC147xlt! How do I
I was unable to locate a manual, but this is a basic 16-channel scanner, and the frequency coverage is probably listed on the ID plate. To program, turn the scanner ON and use the MANUAL button to stop scanning and to advance the scanner to the channel that you want to program. Enter the frequency that you want to program, including the decimal, then push the E (Enter) key. Use the MANUAL key to advance to the next channel, and program as above.
For an extensive database of active frequencies in your area, visit
www.RadioReference.com
or
www.CityFreq.com
Oct 29, 2009 | Uniden BC60XLT-1 (30 Channels) 2-Way Radio
I need to buy a user manual for a bc147xlt scanner
You can download from ;-
http://safemanuals.com/user-guide-instructions-owner-manual/UNIDEN/BC%20248CLT-_E
Thanks.
Aug 30, 2009 | Uniden BC248CLT Base Scanner
Need manuel
The manual for the Uniden BC147XLT is not available on the Uniden website. Please contact their customer support via their website here: http://mycusthelp.com/UNIDEN/supportcontact.asp?sSessionID=&sEmail=
A few tips I found online:
Programming your scanner
1. Press Manual 1 Manual
2. Enter a frequency
3. Press E
4. Press Manual
5. Repeat steps 2, 3 and 4 as needed
6. When you finish the programming steps press Scan
Hope this helps!
Apr 27, 2009 | Office Equipment & Supplies
How do I program local frequencies into a uniden bearcat bc147xlt?
3. Press E
4. Press Manual
Apr 15, 2009 | Uniden BC244CLT Base Scanner
Programe my bc147xlt
http://www.uniden.com/index/manuals_results.cfm?cat=3 check this site out i have searched and searched the wb and could not find info on BC147XLT.. the site above is the main company and should be able to help more
Jan 25, 2009 | Uniden BC60XLT-1 Handheld Scanner
Lost the codes for my scanner
hit manua enter number then Ebthat should put them in again
Jan 10, 2009 | Uniden BC244CLT Base Scanner
Uniden bc147xlt frequncy guides
Go to this site, it has frequencies for cities and counties around the US. This is a link directly for CA. Just click on your area.
http://www.radioreference.com/apps/db/?stid=6
Rollin CBs
Dean
Nov 26, 2008 | Uniden BC244CLT Base Scanner
Uniden Bearcat Scanner Model# BC147XLT
The BC147XLT is too old to obtain a manual from Uniden, but here's how you program it:
Turn it on & press 'Manual', then enter the number of the channel you wish to program & press 'Manual' again. Now enter the frequency you want to put in that channel, example 155.550, and press "Enter'. Then press manual to go to the next channel or repeat the first procedure to select a different channel other than the next one. Repeat the programming procedure for each channel.
Sep 26, 2008 | Uniden BC244CLT Base Scanner
Help please
how do i program it
Oct 23, 2007 | Uniden BC244CLT Base Scanner
2,050 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
