How do i remove the cover of a honeywell home security system keypad to clean or fix a bad number? The cover seems to be attached pretty well and i don't want to break it.
look under the keypad on each side you will see a small slot , put a small screwdriver in there and push up and it will un hook from the bottom...if this is the most common keypad..send a picture if you can,I have been doing alarms 30 years and have seen it all...
Code Alarm F60 / F65 Remote start is starting the truck, but parking lights don't come on. Truck...
(More)
Code Alarm F60 / F65 Remote start is starting the truck, but parking lights don't come on. Truck starts runs for 2 sec then turns off, starts again, then shuts off. No Running lights turn on. Same thing if truck is already running and I try to put it into the starter. Lights don't stay on, and truck turns off with in 2 seconds.
my alarm is set and im inside the house, im unsure of my code? if i type it in and its wrong, will...
(More)
my alarm is set and im inside the house, im unsure of my code? if i type it in and its wrong, will the alarm go off or just stay set?
have a 2005 Ford Mustang 6 cyl coupe. Have a Code Alarm keyfob that locks/unlocks doors, etc. Was...
(More)
have a 2005 Ford Mustang 6 cyl coupe. Have a Code Alarm keyfob that locks/unlocks doors, etc. Was working fine till today....new battery in it....when I push button on keyfob to unlock/lock doors...the keyfob light goes on..but doorlocks do not respond...help!!! :) Bill 480-343-6919
