Question about Lanzar Car Audio & Video
Theres a green box inside my lanzar 800 watt amp that is loose. Its right next to the line out. How can i fix this?
SOURCE:
  • 155 Answers
SOURCE: audio bahn 1205n
sounds like your over working your amp 800 watt on a 2000 watt sub. might wanna upgrade your amp
Posted on May 11, 2010
  • 3 Answers
SOURCE: I have a lanzar opti drive plus 500 old school,i
The 40 amp fuse is too small. 1000 watts = 12 volts @ 83 AMPS. Bigger power wire my friend. If you want to sell, let me know.
Posted on Aug 21, 2010
logosc75
  • 625 Answers
SOURCE: Ok I have a 1800
Maybe the wires are disconnected inside the box. Remove the sub from the box and check the wiring.
Posted on Sep 12, 2010
SOURCE: can i use a 300 watt amp for 2, 800 watt woofers
yes, but you would not get the same performance as you would if you gave them the suggested power. I have found that it is always better to use a more powerful amp than your subs are rated for (as long as it is clean, high quality, low distortion power). I have had the best luck with name brand amps (kicker,rockford fosgate,phoenix gold,etc...). I hope this will be helpful to you.
Posted on Jul 30, 2012
mr1967mejias
  • 746 Answers
SOURCE: 15" Lanzar 400 watt sub
Being that I do not know how tall you are. It's hard to give you the dimensions on placing a 15 behind the seat of a single cab. Being that you already have that will fer I can only suggest to build as long a box as you possibly can from one side to the other approximately 60 inches in between the seat belts. As deep as you possibly can at the bottom and place the sub as close to the bottom as possible. This will allow room for the magnet. Good luck.
A thumbs up would be greatly appreciated if answer is helpful for your question. THANK you and GOD BLESS
Posted on Nov 22, 2014
I have a lanzar vector VCT-2210 2000 watt amp hooked up to two menace 1300 watt subs. when i turn the volume up on the head unit the amp goes into protection mode. i checked all my wiring and it seems all...
Things to check: Is the wire between the amp and the subs heavy enough to pass 167 amps? 2000 * 12 = 166.66666 amps. Max volts on the subs are 10 volts....close enough. Are you sure you're using the line out on the head unit? You may be over driving the amp if it's anything else.If the head unit doesn't have line out connectors then you'll need to get an attenuator for each channel. Do you have caps on the 12 v power in wires? They'll keep the headlights from dimming and the alternator will last longer if you do.
Apr 09, 2014 | Lanzar VCT2210 Vector Series 2 Channel...
Will a Lanzar Vibe 286 4000 watt amp push a power acoustik fubr 12 700 rms 1800 max ....
Yes it should do the job. You will need to wire the sub in series and make sure you have a 4ohm load on the amp. It should be right at around 700 watts RMS @ 12-13 volts.
I’m happy to help further over the phone at https://www.6ya.com/expert/chris_7f7f91eb941fb23f
May 18, 2012 | Lanzar VIBE266 Car Audio Amplifier
There are 4 connectors on each side of the speaker, how do i wire it so i can put the sub in the box so i can connect it to my amp?
There are 4 connectors on each side of the Problem with the Lanzar 15'' 2000 Watt Dual Voice Coil Subwoofer Driver for Small Enclosures Car Speaker. how do i wire it so i can put the sub in the box so i can connect it to my amp?
Dec 24, 2010 | Lanzar (MAXP154D) 15'' 2000 Watt Dual...
My amp doesnt work
their may be a short some ware check your power line and your ground i had the same problome with mine
Apr 29, 2010 | Lanzar VIBE241 Car Audio Amplifier
Lanzar 800 watt amp protect mode stays on
protect mode usaully means that something has disrupted the power of feed lines to the subwoofer/speakers possibly fuse is blown in amp or amp is blown in which we hope not. see if you have a warrenty if blown and send back or bring it to where you purchased it from.
Aug 01, 2009 | Lanzar VIBE266 Car Audio Amplifier
Speaker box wont work. Its hooked correctly to the lanzar amp. Theres little action. It started when we took my speaker box out in order to have space for vacation. Put it back in n after a couple days the...
The quickest way to tell the woofers are good or still hooked up... you need a multimeter set to ohms. test each speaker and make sure you get a reading of 2, 4 or 8 ohms. ifs its a prefab box, probably 4 ohms each but still depends on make. Make sure the speakers have good connection inside and out. Make sure amp wiring is in good condition too.
Jul 12, 2009 | Lanzar (Pair) MAXP104D Max Pro Series...
Bridged lanzar amp
no idea, but i think you should leave the subs the right way in the box
Feb 15, 2008 | Lanzar VIBE266 Car Audio Amplifier
Audio bahn 1205n
Nov 28, 2007 | Lanzar 2H 1000W MOSFET AMP Car Audio...
Sub for lanzar mxa 282
2 X 18" Kicker CVR they will work really clean. 2000 watt max each and 1000 RMS just like your amp.
Nov 16, 2007 | Lanzar MXA282 Car Audio Amplifier
Car Audio & Video Logo
29 people viewed this question
Top Lanzar Car Audio & Video Experts
Mike Duncan
Mike Duncan
Joe Alexander
Joe Alexander
xxxxxx xxx
Are you a Lanzar Car Audio and Video Expert? Answer questions, earn points and help others
