Question about Cell Phones
I get the same message on mine
For two days now, it just gives an out of range message. No calls are coming in at all. There was no careless charging involved, it developed this problem on it's own. Almost like it's antennae will not pick up anything.
This is not that old of a phone and should not be giving problems like this.
Jenn Air Gaz top with convection oven: I get an F5 error message when trying to work the oven it starts then I get the error message
F5 - Hardware and watchdog circuits disagree
Replace clock assembly (also called the ERC)
Here is the part to order.
There is a video on that same parts page to show you how to make the repair.
All parts come with a 365 day, any part, any reason return policy.
Oct 20, 2013 | Jenn-Air SVE47100 Slide-In Electric...
I have blackberry when i try to open whatsapp it says uncaught exception string index out of range.35
I tried all of these and they didnt work, but this did for me and a friend of mine.....
1. go to your main messages folder where all messages go including emails and calls.
2. locate a past conversation over whatsapp (highlighted in green) and open it.
3. send a message to the contact whilst on the whatsapp conversation.
4. come out of it completely and now you should be able to open whatsapp :D
(you may have to set the mail box to display SMS/MMS on the options>inbox settings)
i had error uncaught exception string index out of range 29. but t works the same way for all XD hope this helps!!
Jan 29, 2013 | RIM BlackBerry Bold 9780
The washer stops with the code LD
Call the recall # 1 800 659 7026 & see if your model is part of the recall. Mine was! I f yours is, they will ship the new control pane via UPS free of charge & schedule a technician to come out & repair the machine (also free of charge) in about 10 days! Good luck!
Dec 04, 2009 | Kenmore Oasis HE 27082 Top Load Washer
How much time to we have to charge Samsung Omnia phone
Depends on your firmware. Updating your firmware on the somsaung site will prolong your battery life. Mine used to last about 2hours with heavy repative use. Music, gps, video etc. Standby would last about a day and a half with a few calls. Now it lasts about 4-5hours with heavy use and standby up to about 4 days with calls here and there.
Mar 26, 2009 | Samsung SGH-i900 Omnia Unlocked Cellular...
GE cordless phone no longer will make or accept calls
try new battery. that happened to me this weekend. i put the battery fro the second handset i dont use in it and everythings fine.
Jan 19, 2009 | Uniden Cordless Phone
Randomly will not connect calls, or send & receive messages
take the phone into your provider and explain the problem and see if it is a fault on the phone that can be fix or if it will be replaced.
Jun 16, 2008 | Motorola Mobility RAZR V3
Kitchen Aid KESA907 Error F2E0 Stuck Key
Turn off the breaker and wait for 5 minutes. the follow these steps:
--> After turn the breaker back on, go to the range and press "OFF", "OFF", "START", then click on the "clock set", there is a message on the display saying that do you want to delete the error, at this time press on the "START" again. And wait for a while until the everything on the screen disappear except the clock time. Hope this will fix yours. It fixed mine.
Apr 24, 2008 | Whirlpool GERC4110PS Kitchen Range
Ou t of range
i just fixed mine! hold # and * together let go and do it again, it will reset.. you will be able to make calls again
Dec 29, 2007 | Uniden TRU8885-2 Cordless Phone
Failed call messages
switch your network over to another carrier for about a hour and then switch it back. sometimes just making the switch makes your phone connect better to your tower
Sep 08, 2007 | Motorola Mobility RAZR V3
Cell Phones Logo
13 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
