Question about Dehumidifiers
Blower works but get no water all setting ok - Dehumidifiers
  • 52 Answers
Sounds like low on charge or compressor not running
Posted on Sep 13, 2009
My Haier dehumidifier runs fine, only 2 years old but doesn't pick up any water.
You may think that it is working' but it may be that the blower is running and not the compressor. You need to check the compressor and see if it is overheated or not.
Jul 20, 2014 | Dehumidifiers
Why does blower wheel stop on Frigidaire dehumdifier?
Good Afternoon Desi,
I understand that the blower wheel is not spinning on your Frigidaire dehumidifier, model# FAD504DUD. I also see that the compressor will stay on unless the dehumidifier is unplugged. I suggest you contact the manufacturer for further assistance. They can possibly clarify why the compressor stays on and why the blower fan is not working. If not, they should at least be able to point you in the right direction of having your dehumidifier working. Hope this is helpful.
-Best Regards-
WP
May 30, 2014 | Frigidaire FAD504DUD White Energy Star 50...
My dehumidifier freezes up. It starts collecting frost within just a few minutes. It is in a basement which is very damp and temp is about 77F. The fan is working on HIGH. Freeze sensor has been...
I don't think there is anything wrong with your machine ... What I think you should do is get another fan and blow air onto the rear of your dehumidifier. I also think you should select a higher setting until you get some of the water out of the air. When you get down to 80% for example (evidenced by the machins turning off - set it then to 70% and so on until you arrive at the moisture content you desire (50% is usually considered perfect.) You might also consider adding another machine to help the first, same setup with a fan blowing on it.
This is what I did when my dehumidifier did the same thing yours is doing.
Thanks for your quesiton @ FixYa.com
Sep 07, 2011 | Fedders A7DH45B2A Dehumidifier
Compressor will not run, but blower works. coil and filter are clean
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Aug 05, 2011 | Maytag M3DH30B2A Dehumidifier
My Santa Fe compact dehumidifier in my crawlspace makes a noise (not a smooth humming sound but more of a harsh vibrating sound) when it is not dehumidifying. I can turn the knob to the dryest setting and...
The black cylinder is the compressor. It sounds like your unit is cycling the compressor for some reason. If the compressor starts, runs fine, and removes water when you set the humidity control to the driest setting the compressor is probably OK and the problem may be with the humidity control causing the dehumidifier to "short cycle" for some reason. You may need to change the humidity control or relocate the dehumidifier in your crawl space.
If the compressor attempts to start, and then sits quiet for 10 minutes, and then attempts to start again, you have a problem with the dehumidifier. There are a few things that can cause this problem:
Low refrigerant charge
Bad compressor capacitor
Bad compressor overload
Plugged capillary tube or broken expansion valve
are the common causes of this behavior. If you suspect one of these problems, call the factory service department at 1-800-533-7533 for help.
Good luck with your dehumidiifer.
Jan 11, 2011 | Santa Fe Advance Pre-Filter Dehumidifier
Spitting water out of vent. dehumidifier is has drain hose set up.
If the room tempature is close to 60, the coils may be frozen (completely encased in ice). If this is the case, move it where the water can drain off - about 1 gallon which may NOT run into the drain bucket.
I out mine over the floor drain.
Turn off and it will defost over night.
Only specially made dehumidifers work below a room temo of 60 degrees (the temp of a basement in winter).
Does it need to be running? A digital humidity sensot from Radio Shack is cheap and may tell you the humidity is OK - only 50% or less.
Dec 31, 2009 | Dehumidifiers
Water does not drain thru hose for continuous drainage
water only comes out when you have hi humidity
and will only drain after the unit shuts off
the indoor blower motor makes a vaccuum and holds the water in the drain pan
Sep 11, 2009 | Frigidaire Dehumidifiers
Dehumidifier headaches!
There are three things that must be working to extract water. The 'coil' (a finned metal part that allows air passage) if it's filled with dust and obstructions, no air can move...no water. There is a blower motor that mus move the air. If it is seized up an not blowing air...very little or no water. The compressor uses condensation from the air moving across its coils (like the moisture than forms on a cold glass on a humid day) to extract the water from the air. If it's not working then no water.
So, if there is air blowing out of the dehumidifier the blower is working. If the air is room temp the compressor is not working. If it's real hot air, and the humidifier keeps cycling on and off quickly, the coil is dirty. Those are the 3 things that need to be working.
Jul 27, 2009 | Kenmore 54501 Dehumidifier
My kenmore 50 pint dehumidifier 54501 runs but it does not taking in water
You need to determine what's "running". Here's why: There are three things that must be working to extract water. The 'coil' (a finned metal part that needs air to flow across its surface) may be filled with dust and obstructions, so no air can move...then no water. There is a blower motor that must move the air. If it is seized up and not blowing air...very little or no water. The compressor creates condensation from air moving across the coil (like the moisture than forms on an ice filled glass on a humid day) to extract the water from the air. If it's not working then no water.
Jul 18, 2009 | Kenmore 54501 Dehumidifier
H20 POURS OUT OF THE UNIT BEFORE BUCKET IS FULL
It sounds like your unit is freezing up. Let it set for a day then set to run on the 3 hr cycle. Also rase the % of humidity to 60 or 65, and if it starts working lower the % setting in a few days by 5% increments until you get to the setting you want. Also read your owners manual troubleshooting section lots of good tips.
Jimh32851
Mar 10, 2007 | Kenmore 54701 Dehumidifier
Dehumidifiers Logo
174 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
Michael Youngman
Michael Youngman
Are you a Dehumidifier Expert? Answer questions, earn points and help others
