Question about Hoover F5866-900 SteamVac Deluxe Wet/Dry Vacuum
My hoover steamvac optional tools won't fit.
I removed the block to attach the back of the hose into the recovery tank like it said and it won't fit all the way in and now it broke.
SOURCE: Hoover Upright SteamVac Deluxe with stair and upholstery cleaner
Don't listen to Solution #1, it is simply NOT correct. This is the correct answer:
As you stated, you already know where the water hose connection is. It is under the easily visible port cover on the top of the base.
What is NOT easily visible is the connection for the vacuum hose. That's because the machine needs to be "reconfigured" before the hose can be attached. To "reconfigure" the machine:
1) Remove the cover off the waste water tank and notice how things appear--it will soon be important.
2) Find and remove the "panel" on the front of the waste water tank by sliding it straight up and out.
3) Replace the panel with the connector by sliding it straight down. When finished the top should look something like it did in step 1). This assures that the dirty water will be vacuumed into the waste water tank.
Done!
Posted on Dec 06, 2007
reddevil6
  • 1673 Answers
SOURCE: hoover steamvac clean surge turbo power 5200 attachment problems
That part to install in tank, is at the end of your hose. Take the lide off of the dirty water tank, on the front of the tank, there is a block that will slide out, then you can insert that part in its place. You have to have suction to make the brushes spin, so you just need to put the block on the end of the hose in the slot on the front of the tank. When down however, put that block you took out back, or your cleaner won't work right.
Posted on Jan 10, 2008
The original problem was, How do I attach the upholstery attachment to the cleaner. I see where the water connection is, but not where to attach the hose part.,
The solution to attaching the upholstery attachment to the Hoover Steam Vac cleaner was excellent for steps 1 and 2. However, in step 3, I can not simply slide the upholstery attachment straight down. It gets stuck and does not connect to the bottom connector and is stuck in midair. It seems like I am doing something wrong. My Hoover model steam vac model number is F5900-900.
The solution given in steps 1,2, and 3 where I have a problem with step 3 is as follows;
Done!
Posted on Feb 16, 2008
SOURCE: attach upholstery hose
Go to www.Hoover.com. Click on Carpet Cleaners. Click on Steam Vac All Terrain. Click on Learn more. Then click on Download the manual in pdf. The manual explains all.
Posted on Feb 07, 2009
AV Nerd
  • 4 Answers
SOURCE: Hoover SteamVac Agility
Press the handle release kick-button with your foot, extend the handle all of the way back, and take a look at the gap between the base of the unit and the handle/reseviour assembly. You should see several black hoses attached to the base and running up into the handle assembly. One of them (the dirty water return hose) might be cracked. Turns out that might be a common problem with this model. We had the same problem.
Judging by the interference between the vacuum hose and the "dirty water return" hose, there is NO WAY those two hoses can exist together in that housing without causing the dirty water return hose can last for many full bends of the handle. We opted to not repair our unit, but you might be able to do it yourself for the cost of the part and several hours of your time. Otherwise, seek out your certified Hoover repair center for more info.
Posted on Jun 18, 2009
Why will my hoover spin scrub steam vac upholstery attachment not suction?
With this model, check all hose connections and recovery tank lid. if you have good suction before you put on the tool it may be the tool that needs service. inspect the tube under the recovery tank for the round gasket and the filter inside the tank.
Aug 26, 2014 | Hoover SteamVac F5914-900 SpinScrub...
I want to use upholstery cleaning tool and do not know how to hook it up
Hi There,
I'll be happy to walk you through step by step how you can attach the hose to your Hoover SteamVac.
Here are step by step instructions for you:
Step 1. To prevent possible leaking, remove
clean solution tank by pressing down on
tank handle (D) and pulling forward; set
tank aside (do not set tank on furniture2_bing.gif).
Remove hose from storage rack.
Step 2: Step on handle release pedal (E) and
lower carpet cleaner handle until it rests
on the floor.
Unlatch back part of recovery tank and
remove lid.
Step 3: Remove recovery tank front panel (F)
by sliding it straight up.
Step 4. Replace panel with converter (G).
Slide converter halfway down opening
until it is firmly in place.
Step 5. Before connecting tube (H) to
cleaner, make sure black tabs are
extended by pulling tan collar toward
tube.
Open door on hood labeled “Stair/
upholstery Cleaning Connection”. Press
round solution tube connector onto
round projection inside door. Press connector
collar down firmly to ensure
that it is fully connected.
Step 6. The tank replaces in a hinge-like
manner. Position front of lid under tabs
(I) on front of tank. Rotate lid down onto
tank.
Make sure lid is secure on all sides
before cleaning.
For full suction, it is important that
the recovery tank lid is properly
secured before cleaning.
Reverse procedure to remove hose
and solution tube.
Raise carpet cleaner2_bing.gif handle to upright
position.
I hope that this was helpful to you in hooking up your Hoover SteamVac hose. If you found this helpful, please be so kind and rate my repair helpful by clicking the 4 thumbs up icons in the top right hand corner of the repair, this is really appreciated.
Thanks again,
Chris J.
GoVacuum.com
Jun 15, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Replace accessory hose
i There,
on the floor.
remove lid.
tube.
tank.
before cleaning.
and solution tube.
Raise carpet cleaner handle to upright
position.
Thanks again,
Chris J.
GoVacuum.com
Apr 15, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Hoover Superscub attachments won't work
It sounds to me like you have the water hose plugged in, but not the hose block. In the front of the dirty water return tank there should be a removable square plastic piece. Remove the lid and slide that piece out. Replace wth the back end of the hose receptacle. If you have already done this, then here is your problem: when you return the lid to the top of the return tank, you must roll it on from the front(there are brackets the lid hooks under) to the back and listen or feel or the "click" your tank is now ready to pick up the dirty water from your hose. let me know if this helps!
Aug 06, 2009 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
Instructions on how to put attachments on hoover steamvac to clean upholstery
Remove solution tank.
Remove recovery tank and lay cleaner flat on floor. Remove lid,
Now, remove front panel from recovery tank by sliding it straight up.
Take your hose and slide the U-shaped end (converter) into the place where you removed the panel. Slide halfway down opening until it is firmly in place.
2nd step: You should have a tube with a "plug" on it hanging from the converter end. Open door on hoodl abeled "Stair upholstery/Cleaning Connection". Extend black tabs by pulling tan collar toward tube. Press connector collar down firmly to ensure that it is fully connnected.
It's sort of like a childproofed plug and socket. Pull back on the collar and push in the olug. Not hard at all once you've done it the first time.
Make sure you put the lid on the recovery tank correctly so you have suction. Attach whatever brush you want to use on the other end until the tab locks into place.
Sometimes you have to bleed the air from the line by turning on the cleeaner and letting it **** against your hand or hard surface for 15 seconds before its ready to use. This gets the solution to flow to the tool.
Aug 06, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
No suction from upholstery attachment
http://www.hoover.com/pdfs/manuals/F5914900.pdf
Problem: Low suction
Problem: Clean solution won’t
dispense
Problem: Brushes/brush indicator
won’t rotate during floor cleaning
Possible cause
Possible solution
• Not firmly plugged in
• Plug unit in firmly
• No voltage In wall plug
• Check fuse or breaker
• Blown fuse/tripped breaker
• Replace fuse/reset breaker
Possible cause
Possible solution
• Recovery tank full/automatic
shut off engaged
• Remove and empty recovery tank
• Blockage In tool on end of hose
• Remove tool and clear blockage
• Recovery tank lid not on
correctly
• Make sure lid is on securely
• Recovery tank front panel not
replaced after stair or upholstery
cleaning
• Replace recovery tank front panel
(page 14)
Before using tool
It may be necessary to remove air from
the system (“prime the pump”) so the
clean solution will flow to the tool. Follow
these steps:
1. Attach tool to hose and turn the carpet
cleaner ON.
2. Put the tool on a hard surface or
against your hand to block off the suction.
3. Wait a few seconds (can take up to
15 seconds). Then squeeze the trigger
and begin cleaning.
GOODLUCK!!!!
Jun 17, 2009 | Hoover SteamVac F5914-900 SpinScrub...
My hoover steam vac is not releasing the cleaner
http://www.hoover.com/pdfs/manuals/F5914900.pdf this is the manual for your model
Godbless
dispense
Possible cause
Possible solution
Possible cause
Possible solution
shut off engaged
correctly
cleaning
(page 14)
Possible cause
Possible solution
• Solution tank not firmly in place
• Make sure tank is securely locked in
position
• Solution tank empty
• Refill tank according to instructions for
surface being cleaned
correctly
• Make sure lid is firmly in place
• Pump needs to be “primed” (when
using tool)
• See “Before using tool” section, p. 13
Jun 15, 2009 | Hoover SteamVac F5914-900 SpinScrub...
How do I attach the stair cleaner attachment
  1. remove recovery tank lid
  2. remove tank duct from front of tank
  3. slide flat end of hose into slot where tank duct was<open side up>
  4. place tank lid back on
  5. open water hose door on hood
  6. push waterline onto spickett
  7. clean your stairs.
best of luck
Jun 11, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover steam vac
  1. Remove your cleaning solution tank and set aside.
  2. Remove the lid to your recovery tank.
  3. Remove the front panel of the recovery tank by sliding it straight up.
  4. Slide the convertor half way down into the same slot. (Curved side down). The opening should be facing upward.
  5. Replace the recovery tank lid.
  6. Open the door marked stair/upholstery cleaning connection.
  7. Press the tube connector with the black tabs onto the projection inside the door.
  8. Replace you cleaning solution tank and you are ready to go.
Note: It's a good idea to turn your brushes off. Also, you may need to prime your hose by turning on your cleaner and holding the hand tool onto a flat surface for a few moments before use.
Aug 08, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover steamvac clean surge turbo power 5200 attachment problems
Jan 02, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Hoover F5866-900 SteamVac Deluxe Wet/Dry Vacuum Logo
56 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
