Question about Hallmark Card Studio 2009 Deluxe Full Version for PC
Will not configure for two sided card printing
  • dkbvrdy Sep 13, 2009
    It will print only 1 side at a time, but will not configure to print both sides of s chosen card. Will only give 1 page of the 2 page test configuration. dell v 505 printer..
  • 66 Answers
What printer are you using? Many printers cannot print two-sided or duplex printing. If your printer cannot handle duplex printing, you'll need to do what's called "manual" duplex. Print one page then reinsert the paper and print the second page. Test this on cheap paper first to determine if you need to insert the paper printed side up and which way (if any) you'll need to roate the page.
Posted on Sep 13, 2009
  • sbarn Sep 14, 2009
    I don't have your exact configuration but I found a comment from another user that was able to successfully get the duplex printing to work and yes, your printer can handle duplex.
    "Getting the automatic duplex of our printer working took a bit of a while [as the printer wizard didn't offer anything for this option], but this was eventually done in Start, Printers, right-click Properties under Windows XP, and switch on auto-duplex there. Once set up, the automatic duplex printing works perfectly. The Windows 'Printer Properties' can be accessed for full control when printing cards though, via a Card Studio menu button. " From http://astore.amazon.co.uk/scientific-21...
    The nice thing about setting up the printer for auto-duplex by default is that you will save money in printer ink for anything else you print. For example, printing multiple page Word documents will now print duplex by default. If you have a document in Word or another program that you decide you don't want in duplex, when you go to print, click on Properties and you can modify it there.
Card Jam Error 112 & 245
please calibrate the Lam Film sensor.error 245 is lam sync error please check Lam power/connections and restart the Printer.
Oct 02, 2012 | Fargo HDP5000-LC ID Card Printer...
Im getting a fault message on my xerox phaser 8550 it comes up as fault:02,008,67:86362
There is a problem with your configuration card.
p { margin-bottom: 0.08in; }
Remove and Re-insert the Configuration Card
  • Power OFF the printer using the power switch. The power switch is located behind the interface cover on the right side of the printer.
  • Disconnect the power cord from the electrical wall outlet.
  • Open the interface cover and locate the Configuration Card
  • Remove and make sure the Configuration Card is properly orientated. The Xerox image should face the rear of the printer with the chip inserted into the printer first.
  • CAUTION: Do not touch the chip.
  • Slide the Configuration Card into the printer.
  • Connect the power cord into the electrical wall outlet.
  • Power ON the printer.
  • Close the interface cover.
  • Print a Configuration Page to confirm the installation was successful. See the Related Items below for additional information.
If this doesn't work you'll probably need a new card.
Hope this helps ;)
Feb 01, 2011 | Computers & Internet
How to connect a netfear router to a dell computer
I assume the Netgear is a wireless router and you want to connect to the router using a wireless connection.
Make sure the DELL computer wireless card is installed with the latest wireless card driver.
The Netgear router needs to be configured with the wireless settings ie SSID and encryption etc.
Next the wireless card needs to be configured with the wireless router's settings, ie SSID and encryption etc.
For instructions on securing and configuring the wireless router and wireless card please click in this link :-
http://www.fixya.com/support/r3559128-wireless_router_security
Dec 23, 2009 | D-Link Air Plus DP-G310 (dpg-310) Print...
I need to print the page that shows the ip of the hp 4100 printer, how do i do that
Print a configuration page. Press the Menu key until you see Information menu, press the item key until you see print configuration, then press the select key. A configuration page will print and you will also obtain the network information, unless there is a problem with the network card or circuit.
Nov 04, 2009 | HP LaserJet 4100 Printer
How do i set ip address for new jet direct card on hp 4600 dn
Go here for the manual cause it's a bit hard to walkthrough. When the printer is on and ready, you want to click the menu button and scroll though to the configuration menu -> i/o menu. You can print a configuration age to see what the current address of the jetdirect card is. If you're comfortable with command line, you cna use telnet to connect to the jetdirect card and configure it that way.
Oct 05, 2009 | Office Equipment & Supplies
Need to install network printer to DLink Router
It has been a few months, so you probably have resolved this -- but just in case someone else is looking to find out the IP address on the internal print server of an HP Laserjet 4000n printer so they can set it up on their network, here are the steps to find the IP address on the HP JetDirect internal print server:
1. Have the Ethernet cable plugged in to the router and the JetDirect 600n card and power it on.
2. Make sure display screen on printer says "Ready".
3. Press the Menu button on the printer until you see Information Menu.
4, Press the Item button on the right (+) side until you see Print Configuration page.
5. Press the Select button and a configuration page should print.
One page is the printer's configuration and the other page is the print server configuration page. If you have a good JetDirect card, and good connection to your router, the IP address of the printer, plus its subnet mask and default gateway should be shown on the EIO configuration page.
If the printer has been manually set with a static IP address, subnet mask and default gateway that will not work on your network, you will see the settings will indicate "Configured by" User Specified.
To clear those settings and allow DHCP setting, perform a cold reset on the JetDirect card, by powering off the printer, holding down the green "Go" button and powering it back on until you see "COLD RESET," let go of the green Go button, wait a couple of minutes, then run another configuration page to see the freshly assigned DHCP address of the print server.
Hope this helps someone.
Mar 14, 2009 | HP JetDirect 600N Print Server
Networking imagerunner 2200
First, plug the printer into the network with an Ethernet cable. Then, go into the configuration page on the printer's display and print a configuration page. Look for the IP address. When you have that, go to the computers that need to connect to the printer. (Note that this tutorial is for Windows XP, I am not familiar with Vista but this should give you a basic overview.) Go to Start > Printers and Faxes. Click add a printer on the left hand side of the window. Select a Local printer attached to this computer, and unselect automatically detect. On the next page, click create a new port > TCP/IP port. Type in the IP address of the printer. Then choose the driver you are going to use, you should be able to find the IR 2200 driver under canon pretty easily. If not, go to canon.com and download their drivers. Once you do this, print a test page and it should print. You are then fully configured.
Please rate, Thanks!
Jan 21, 2009 | Canon (6981A002AA) for imagerunner 2200,...
Print to card
Use straight paper path ie tray 1 as input, face up tray (sticks out on leftof printer) as output.
Set card as media type when in printer options window.
Some card is not good to print on.
Sep 05, 2008 | HP Color LaserJet 8550dn Printer
Blank Pages
The probability is that the new print server is either configured for a longer "page" than the cross match card.
There are different ways to fix this and it really depends on the application used to print the cards.
My first suggestion would be to fix the print server - followed by setting the page size in the application and finally configuring the form length for the profile you are using in the printer - the application settings usually take precedence over the other two, but I have found when using Windows server to drive the printer that Windows dictates the form size and a custom form may need to be created.
May 29, 2008 | AMT Datasouth Datasouth Documax 3300...
Hallmark Card Studio 2009 Deluxe Full Version for PC  Logo
750 people viewed this question
Top Hallmark Computers & Internet Experts
ray gallant
Frank
Are you a Hallmark Computer and Internet Expert? Answer questions, earn points and help others
