Question about JVC HD-61Z886 61" Rear Projection HDTV
Jvc hdmi???? i have a receiver with hdmi output ,ounce connected to t.v. it doesn't reconize the signal. my menu on the t.v. doesn't want to higlight the : digital in input .If i can use my hdmi input, will the component give the same quality picture. my model is JVC HD-61z886 61 inches
  • 1,284 Answers
Changing the output to digital only affectts the audio output stream such as Dolby Digital or DTS audio. Try turning on the DVD player first then the television and see if then it sees the DVD player. Otherwise using the component outputs most will never see the difference n picture quality. Good luck.
Posted on Dec 12, 2007
    New Friend:
  • 57 Answers
What component are you trying to use if it is a dvd player you will have to hook it up the basic way first (composite) then change the setting on the dvd menu for digital out put then your tv should reconize it and you will get a better picture good luck!
  • 71 Answers
Do an EEPROM reset and will be ok.
  • Eduard P Dec 12, 2007
    Make a EEPROM reset on your TV. For details write me on
I have a JVC RX-7010V AUDIO/VIDEO CONTROL RECEIVER. And I can not get it to hook up to my TV for surround sound I have to hook it up through my headphone jack on my TV.
On the back of the JVC receiver, there should be a TV input, Coax IN and OUT or AUX input (I don't remember if this model had HDMI). On the back of your TV, there should be an AUDIO OUT, connect this to either the TV or AUX inputs and make sure on your TV, to set the Audio Out is On in the TV menu. Turn on JVC and set input to TV and adjust volume. Another way is using the COAX input and outputs. Connect Output of cable box to Input of JVC, then connect Output of TV to Input on TV.
May 15, 2016 | JVC Audio Players & Recorders
What is the HDMI setup procedure for JVC
in the source menu button select the HDMI option to recognized the source signal with HDMI output.
Nov 26, 2012 | JVC AV-48WP74 48" Rear Projection...
No optical output except when using ipod dock on tv
Unfortunately, there is a limitation on the JVC LT47P789 digital optical audio out. This audio output does not get the signal from any HDMI source. This is described on page 49 of the user manual. The manual is available from JVC here: . There is a similar restriction for the analog audio output from the TV with the HDMI inputs.
If you use the component audio/video inputs on the TV from your set-top cable box and DVD player, then the optical audio output will work. Otherwise, you need to find a way to connect the audio directly to the receiver. Some receivers have multiple HDMI input ports. These then forward the video signal on their HDMI output to the TV. Another option is to connect the analog audio outputs from the cable box and DVD player to the receiver. This may require resetting the Audio output from these set-top boxes to keep from sending the audio over the HDMI cable. With the Cinemate, you might need some sort of audio input switch or an HDMI converter and switch that separates the audio from the video signal.
I hope this helps. Please add a comment with more information about your devices for ideas on how to work-around the problem with this JVC TV.
Nov 05, 2017 | JVC LT42P789 42 in. LCD TV
I cant see the menu on the tv, i conected an hdmi cable to the ouput where it says monitor out, and my tv doesnt reconize it.
On page 8 it says, "The on-screen display signals are not outputted from the HDMI MONITOR OUT".
Run a set of cable(s) from the Video- S-Video- or Component Video Out connectors to a compatible input on the TV.
Jun 09, 2010 | Denon AVR-1908
Component input no HDMI output
The receiver can only output picture from one video output at a time...ei; component video and HDMI cannot operate simultaneously. Nor can it transfer a signal from a component input to an HDMI output or vice versa. The input and output connections must match.
Apr 15, 2010 | Marantz SR5001
No video from RX-V863
This reciever might not upconvert component or composite to hdmi, which means if you have anything but hdmi hooked up you will not see it. Check your manual for what all the reciver will ouput.
Jul 24, 2009 | Yamaha RX-V863 Receiver
Get ''not supported ''message on vx-1018-ah
Verify this is a Pioneer VSX-1018AH.
The manual explains it all... The problem is probably an incompatible setting on your source.
Search for "not support" in the manual...
I think this may do it... From Page 86...
No picture or sound. • This receiver is HDCP-compatible. Check that the components you are connecting are also HDCPcompatible.
If they are not, please connect them using the component or composite video jacks.
• Depending on the connected source component, it’s possible that it will not work with this receiver
(even if it is HDCP-compatible). In this case, connect using the component or composite video jacks
between source and receiver.
• If the problem still persists when connecting your HDMI component directly to your monitor,
please consult the component or monitor manual or contact the manufacturer for support.
• If video images do not appear on your TV or flat panel TV, try adjusting the resolution, DeepColor
or other setting for your component.
If ‘NOT SUPPORT’ appears in the receiver’s display, try adjusting the resolution, DeepColor or
• While analog video signals are being output over HDMI, use a separate connection for audio
• When this receiver reproduces MULTI CH IN audio sources with the HDMI setting set to
THROUGH, you cannot hear audio output from all channels. In this case, make a digital or analog
audio connection.
• To output signals in DeepColor, use an HDMI cable (high speed HDMI cable) to connect this
receiver to a component or TV with the DeepColor feature.
Check the HDMI Control (Page 65-66 of the manual). It only works with Pioneer Flat Panel TV's. Also check Page 83 for "No image is output..."
No image is output when an
input is selected.
• Check the video connections of the source component (see page 18).
For high-definition video (using component video connections), or when digital video conversion
is switched off (in Setting the Video options on page 72), you must connect your TV to this receiver
using the same type of video cable as you used to connect your video component.
• Make sure the input assignment is correct for components connected using component or HDMI
cables (see The Input Setup menu on page 67).
• Check the video output settings of the source component.
• Check that the video input you selected on your TV is correct.
Some components (such as video game units) have resolutions that may not be converted. If
adjusting this receiver’s Resolution setting (in Setting the Video options on page 72) and/or the
resolution settings on your component or display doesn’t work, try switching Digital Video
Conversion (in Setting the Video options on page 72) OFF
Apr 05, 2009 | Pioneer Audio Players & Recorders
HDMI XBOX360 Elite -"No Signal"
The connection order can be a key issue as to whether or not the HDMI signals will pass through the system. For best results the receiver should be turned on first, then the source device(s) and then the display. The reason for this has to do with getting the equipment to handshake properly for the HDCP protocol.
If HDMI video will not pass through your receiver, you may with to just connect the xbox using the component cables. Since component will pass through 720p and your TV is 1080i you should expect the same qualtiy and a more crisp picture.
Oct 12, 2008 | Denon AVR-2307Ci Receiver
Dolby digital signal
yes go in main menu of tv audio output and use dobly digital out ok not pcm anlog ok
Feb 03, 2008 | JVC RX-7030V Receiver
Hdmi cable not working
You have a bad main board it sounds like.
Jan 06, 2018 | JVC HD-61Z886 61" Rear Projection HDTV
JVC HD-61Z886 61" Rear Projection HDTV Logo
352 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
