Question about Simplicity for Children 4-in-1 Convertible 3045 Bassinet
My co sleeper bassinett is missing the 2 nylon straps with plastic plates that secure it to the bed, where can I find replacements?
  • 302 Answers
Certain cribs are going to the crypt. Simplicity Inc. is now out of business. As of July 12, 2009 at least 13 children have died in cribs and basinets recalled by Simplicity.
Please ensure that your's isn't one of them.
In the meantime I'll keep looking for you.
Posted on Sep 24, 2009
2013 MACK Pinnacle
As all these plug ins will pull considerable power I would be looking for a fusible link near the battery or near the main fuse box. Contact Mack service centre for how the sleeper is wired and where the main power comes from
Dec 09, 2013 | Cars & Trucks
How do I get instructions for a Walton high sleeper with desk and wardrobe
hiya did u manage 2 sort out an instruction book iv just bought a bed with no instructions so any help would be well appreciated thanks
Jan 04, 2013 | Cars & Trucks
How to replace trailing arm bushes
After you have disconnected the brake hydraulic hoses (left & right) remove the brake parking cable. Place a jack on the beam just so that it catches it. Secure the beam with a ratcheting nylon strap or equivalent to the exhaust hanger anchors, not on the rubber hangers. Next you remove the bolts that secure the beam.
You will need
  • VAS 6179 hydraulic foot pump
  • VAS 6180/1 assembly tool
  • VAS 6180/4 (long adapter)
  • VAS 6180/3 adapter
  • 3416/2 press piece
  • VAS 6180/2 Yoke
  • VAG 1383 A jack with VAG 1359/2 adapter
or equivalent special tools to remove (press out) and install (press in). If the bushing is Hydraulic bonded you will need a plastic catch to contain fluid while pressing out.
Mar 14, 2010 | 2000 Volkswagen Golf
Bassinett mattress for Graco Pack n Play
You may be lucky with Mamas and Papas, I know that they do make travel cot mattresses, but am unsure if they will make the size you require. I would suggest that you measure the internal dimensions and contact them,
I hope this helps.
Sep 20, 2009 | Baby Gear
Need 2001 dodge 1500 fuel pump replacement diagram
make sure you get the right pump, you need to know your tank size. then take off your bed. you have i believe 6 bed bolts, disconnect tail lights (unplug from underneath) remove bed grounding strap 1 screw, remove bed with help. Disconnect wires, unscrew fuel pump, replace pump. Reverse order to replace bed. jim
Jun 11, 2009 | 2001 Dodge Ram 1500 Truck 2WD
Bed rails for Delta Martine Crib
I have this crib for my own child. I ended up buying a guard rail from Walmart. If you tie a knot in the strap after putting it through the rails and then tuck the disc between the side of the crib and the bottom of it, it seems to work just fine. Child has been using it as a toddler bed for well over a year now and there has never been an issue. Chiild is a restless sleeper too. So, I know it works.
Mar 01, 2009 | Delta Martine Crib
Looking for replacement wheels
We also had the wheel of our mini co-sleep bassinet break due to improper shipping. You can buy the 40-mm caster with a stem and brake at most hardware stores (we found one at True Value). They come with and without the brake. We found them with the brake at Home Depot but the size was wrong, and it took a little looking around to find a place that carries just the right thing. It costs about $7.00 to buy a pair of new casters. We ended up getting a replacement wheel without the brake.
Sep 09, 2008 | Arms Reach Mini Co-Sleeper Crib
It was bought at a yard sale.....
hi. i have those directions. i have model no. 3013 pro. this can be found on the mattress support. if it is the same type of bed attachment, then here are the directions (if it isn't the same then it gives you a general idea of how it works)
converting to a bedside sleeper
remove canopy from bassinet.
unsnap the fabric and remove the removable cross tube from the bassinet frame
fold the Velcro panel down over the support bar and tuck under fabric bottom
position the retainer plate on the side of the bed opposite where the bedside sleeper will be, thread the retainer strap through the space between the mattress and box spring. make sure retainer plate is vertical and flush against the mattress and box spring.
connect the strap ends to the snap connectors on the support tube. bassinet must be pulled snugly along side of the bed.
if that isn't right, here is their support number: 18008588323.
hope it works.
Jun 26, 2008 | Simplicity for Children 3 in 1 Convertible...
Simplicity for Children 4-in-1 Convertible 3045 Bassinet Logo
214 people viewed this question
Top Simplicity Baby Gear Experts
Scott Jelt
Scott Jelt
Greg Cann
Greg Cann
Jason Morris
Are you a Simplicity Baby Gear Expert? Answer questions, earn points and help others
