Question about Microwave Ovens
My microwave keeps sparking when i turn it on
  • 4,070 Answers
This can be caused by grease etc. inside the oven and on the wave guide which is the paper like thing in the oven. If you can remove it look for burnt areas which may can be scraped off or you may need to replace it. An appliance parts store usually has the material you can cut to fit you own.
Posted on Sep 13, 2009
What cause sparks to shoot inside the Daewoo KOR-1B4H Microwave Oven when it is empty?
You should never run a microwave with nothing in it!! There is nowhere for the energy to go. The oven itself has a special coating that keeps the sparks from happening. Anywhere the coating is bad will arc. If it keeps arcing it will burn out the microwave generator.
Oct 02, 2013 | Daewoo KOR-1B4H Microwave Oven
Microwave when turn on making a noise and sparks comin from fan area?
follow this steps and fix it. God bless you
Waveguide Cover
If the microwave is sparking or arcing the waveguide cover might be damaged and shorting out. Try removing the waveguide cover and see if the problem goes away. If there are any damaged spots in the microwave ceiling or sidewalls, repair them and paint them with microwave oven paint. Replace the waveguide cover if it is burnt or if it will not stay in place.
Microwave Oven Paint
If the microwave is sparking or arcing on the side walls the paint might have chipped causing pitting in the metal oven wall. Use microwave safe paint to touch up any bare metal spots.
Rack Support
If the microwave is sparking or arcing near one of the rack supports, remove the support, repaint any bare metal, install a new support.
Feb 06, 2013 | Turbo Air TMW-1100M Green World 1000 Watt...
Makes a really loud noise and no longer heats up yet turntable still turns and all buttons or settings work.
If there is noise it can be due to spark, is so please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is leaking and sparking to the ground. As you have mentioned it was stored, it is quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron.
http://www.espares.co.uk/advice/microwave/a/5/1146/how-to-replace-a-microwave-guide-cover.html
So Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off.
Now keeping clear switch on , use a cup of water inside to test.
If you notice any sparks shut off as the magnetron or the main HT capacitor can be faulty. replace with same type.
If there is heating without any issues , you can use the microwave safely
Sep 14, 2011 | Magic Chef MCO160UQ Microwave Oven
I was cleaning my gas stove near the knobs and now it keeps sparking until i turn it off. will it eventually dry up and work again?
Usually but not always....
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair
Burners Keep on Clicking
heatman101
Feb 06, 2011 | Microwave Ovens
All four burners of the stove spark without turning on the burners.
Gas Range Repair
heatman101
Jan 15, 2011 | Microwave Ovens
The electric starter on one burner sparks once every ten seconds or so. All burners are turned off.
Gas Range Repair Burners Keep on Clicking
heatman101
Jan 10, 2011 | Microwave Ovens
My microwave sparks when I turn it on.
Its called arcing, its either the card needs replacing (in the cabinet)or the the magnetron is sick and make sure its nice and clean in the cabinet
Oct 18, 2009 | Welbilt MR622W Microwave Oven
What does it mean when a microwave does not get hot,?
my microwave oven keeps showing sparks when turned on? help.
Sep 12, 2009 | Kenmore Microwave Ovens
Sparks
usually sparks come from turning and cooking with nothing inside the microwave..if there is grease or something on the bottom the heat will generate a spark
Mar 22, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
Microwave Ovens Logo
324 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
