Question about Denon S-101 System
Denon s 101: the power button keeps flashing orange
Same as described in the other post. I reconnected everything as described, but nothing happens. The only answer I found in the post is to bring it back. Anyone an other solotion?
Regards,
Wim
2 Suggested Answers
Drummernick
  • 440 Answers
SOURCE: neen instructions on my denon s-101 system
www.denon.com they have one if not on ther site please email there ther tech dep request manual in a pdf file in email ok they will take care of u i dont see any online justto show u
Posted on Feb 03, 2008
HP Compaq dx2000 Microtower PC not starting up properly, the orange light keeps flashing on the front and nothing on the monitor. Tried unplugging everything, depressing button for 5 seconds...nothing...
Are you sure it's not red you're seeing instead of orange? Disconnect power. Re-seat the RAM circuit boards inside the computer. Check for possible loose parts inside. Check all the fans and remove accumulated dust. Check the CPU - if possible remove the heat sink and inspect the silicone compound for dryness - reapply new compound if it's dry. The power supply may be bad as well - check that.
Nov 11, 2010 | HP Compaq dx2000 Microtower PC Desktop
Dell Inspiron 1525 laptop, no power light, battery light flash orange, wifi light flash blue and orange I bought the Dell Inspiron 1525 laptop in 2008. I use the laptop as a desktop, so I never plugged...
Since it sounds like an issue with the Power first try to release flea power.Disconnect the charger,remove battery,press and hold down the power button for 30 seconds.Reconnect the battery and charger.Turn on system and check if it turns on. For further help please check Dell Inspiron 1525 Manual. Also confirm if the light on the charger stays on,when connected to the system.
Mar 06, 2017 | Dell Inspiron 1525 Notebook
AVR-1802 5.1 Channels Receiver: My Denon AVR-1802 LED is flashing rapidly. I have...
replace all the electrolytic capacitors in the power supply. i had the exact same problem with mine and once i replaced the capacitors it powered up and stayed on and worked perfect.
these capacitors tend to fail as they're of poor quality.
this fault is very common on denon receivers, especially the later models.
hope this helps?
May 16, 2010 | Denon AVR-1802 Receiver
Fried mobo with new psu?
Yes, it sounds like the motherboard from the Dell machine is now ready for the recycle yard. My son had an old Dell that the motherboard failed, and one by one, all add on cards, and eventually the RAM stopped working. Those old Dell systems can only keep going for so long, and besides, why hang on to it? Get a new PC, they are low priced now, and you get such a faster, smoother running PC.
Jul 26, 2009 | Dell Computers & Internet
I have a denon avr amp it powers up then goes in
disconnect all connections cycle power if the power stays on reconnect equipment one at a time cycling power after each peice reconnected. If the power goes back to stand by with nothing connected the reciever needs repair
Jul 18, 2009 | Denon AVR 2808Ci Receiver
Power Button Flashing Red
Try unplugging the entire unit and letting it sit for 5 minutes. See if this helps. If not, you need to do a complete reboot, which will cause you to lose your settings, but will probably solve your problem. To do a complete reboot, you will need to hold down two of the front bottons on the front panel. I'm not sure which, so either consult your manual or see other posts here which describe the reboot process for Denons. Hope this helps.
Dec 14, 2008 | Denon AVR-1908
Denon AVR-1705 won't power up
when i turn it on it stays on for 3-4 seconds then shuts down
Jun 27, 2008 | Denon AVR-1705 Receiver
Orange light
The orange light is for you to know that the plastation2 is working unless it is not reading the disk then you etheir take it back or tip it over on its side then let it do the rest or if that dont work then it either broke or if you get it to work then you are alright at games.................. thats all the info i have on that........ there you go.
Jan 24, 2008 | Sony PlayStation 2 Slimline Console
Denon S-101 System Logo
57 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
