Question about RCA P46812BL 46" Rear Projection Television
Service mode help
I have A 1989 RCA rear projection TV inn A wooden case,color track 2000,I need to know,how to open Safe Mode. Thanks Terry
    President:
  • 4,402 Answers
Are you talking service menu?
or opening the back? can you be more specific?
whats the problem your having?
Posted on Dec 11, 2007
  • Cary Farah
    Cary Farah Dec 11, 2007
    is this the same as what your getting?
    I was sent here by a friend and have searched for other threads and did
    not find anything close. I just moved across town and when connecting I
    do not get a picture most of the time. I have selected ANT-A and ANT-B
    with the same resuts. Sometimes I will get a signal and most of the
    times not. Turning TV on/off/on has fixed it, going into the menu and
    editing anything can sometimes fix it. Most of the time I get no
    picture/soundm from Disc satellite box.
    Here is what I know so far:
    -There are no codes
    -The green light is always on when I turn it on.
    -I can always get to any of the menu screens.
    -I can navigate all of these menu screens without any problems.
    -All front panel buttons work and the remote works.
    -A known good LCD TV was brought in and I always get good reception from
    this same sat box, cables, etc.
    -Maybe 10% of the time, either turning the TV or going to any menu screen
    will get me a picture. Sometimes letting the TV remain ON will get a
    picture -in about 3-5 minutes (happened twice??)
    -No difference with ANT-A or ANT-B or channel 3 or 4.
    -DVD input is NG into ANT-A or ANT-B.
KP-46WT500 46 in. Rear Projection HDTV-Ready Television convergance adjustment
Try using the MENU button on your remote control to go into the TV picture settings menu. Change the mode to NATURAL, You can also try to manually adjust the color in the COLOR SETTINGS mode.
If that doesn't work, check out the handy troubleshooting chart in TV color problems and see if another solution will work. I hope this helps!
Sep 13, 2012 | Sony KP-46WT500 46" Rear Projection...
Tv is not working will not turn on ,the green light is blinking, this happened after a power outage
I have a 26 year old TV... It is a RCA color track 2000. it will not turn on. Can anyone help?????
Apr 18, 2010 | Mitsubishi WS-55511 55" Rear Projection...
3-d Picture
The vertical deflection output chip or associated cirutry including the coupling cap and controls. Some units have vertical output transistors which can short and open the B+ resistor feeding the transistors.
Oct 11, 2009 | RCA D52W19 52" Rear Projection Television
Hitachi 53UWX10BA HDTV adjusting color
Hi, Your tv model has a small light blue color button inside for manual adjustmnet mode. You will have to remove the front covering below the screen. its just attached with velcrow. Then there will be a centre wooden pannel with the the switching box screwed to tv front with around six screws.Open this panel and look to the left corner of the chasis boards in front of a small metallic box. Thats the switch you have to press to get into manual adjustment mode. use remote to adjust the colors. once done press it again to exist. Visit www.fixurtvs.com to find out more about tv FAQs. Thanks if you found it helpful.
Apr 29, 2009 | Televison & Video
RCA d52w26 Field service menu
RCA > HD52W66
itc222a chassis
Reheat all the surface mount solder points on the Small Signal Board. Then realign the set including convergence menu. To enter service mode: power off the set for 10 sec, then hold down Vol- and Ch- buttons for 10 sec.
http://home.austin.rr.com/doctorjoe/ITC222align.pdf
Oct 03, 2008 | RCA HD52W59 HDTV Projection Television
Need a New Rear Center Lamp
IF THIS IS A PROJECTION TV ,,THE CENTER LAMP IS ACUALLY THE GREEN PICTURE TUBE-ANY LOCAL TV SERVICE COMPANY WOULD LOVE TO SELL YOU A GOOD USED PART- ..RCA IS NO LONGER --GO TO THE" THOMSON ELECTRONICS" WEBSITE FOR CUSTOMER SERVICE,,GOOD LUCK!!!!
Mar 22, 2008 | RCA P52936 52" Rear Projection Television
Zenith rear projection tv 56"
The convergence is way off. You may be able to adjust it thru a service mode menu. You'd need to get the model number first.
How old is the set?
Thanks,
SF in Vermont
Jan 29, 2008 | Zenith IQB50M90W 50" Rear Projection...
Service mode
To enter service mode, push and hold the [Menu] button on the set. While holding, push and release the [Power] button, then the [Vol +] button.
You will now have some information on the screen: "P0 V0"
To actually be able to change these values, you must push [Vol +] on the remote so the information reads V76. Then pushing on the Channel +/- will change the "P" value.
P1 - 3 are error codes. If there is a problem with the set that can be self-diagnosed, the "V" will report the code. These codes are available in the RCA repair manual.
P4 - 7 control the horizontal size, shift, vertical size and shift.
You may also find a summary leaflet for the service tech clipped somewhere inside the chassis. The procedures for getting into the service mode, as well as the service items of interest will be there.
If you're attempting to adjust color or geometry errors, you'll need the Video Essentials DVD, Laser Disc or some other source of test material.
Dec 11, 2007 | RCA P46812BL 46" Rear Projection...
1989 RCA color track 2000-model no.p46050T projection tv
Terry, bad news, there are no "factory settings" for those alignment pots, every individual pot has a distinct function, and if you look closely at the board you will see that there are pots for each color, red, green, & blue which correspond to your 3 picture tubes, every tv has to have a tech do whats called a convergence alignment when it is being built at the factory, EVERY tv is different, even if you ordered a brand new board it would need this alignment done once the new board was installed. You`ll have to call a tech for this one, no way of getting around it, hope this answers your question, more questions? feel free to email me back, good luck, BMW Rider
Dec 08, 2007 | Televison & Video
Televison & Video Logo
71 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
