Question about Whirlpool Refrigerators
Light does not work, even with new lightbulb - Whirlpool Refrigerators
  • 6,784 Answers
HI. The actual door switch has failed.
Test the switch for continuity using a multimeter. Set the multimeter to the ohms setting X1. Place a probe on each terminal. The multimeter should change from a reading of infinity to zero when the probes touch the terminals. With the probes still touching the terminals depress the switch, the reading should change back to infinity. If it does not pass both of these tests, the switch should be replaced
Posted on Sep 14, 2009
Change lightbulb
most times you have to take the outer case off (the stainless steel part) and then you can see all the wires circuitry etc. thats how you get to the light bulb. make sure you unplug the microwave first and do not touch where it says electric shock hazard it will shock you even if not plugged in
Jul 16, 2012 | GE JES1142SJ Microwave Oven
Replaceing bulb on ceiling fan
Turn off the fan before you climbing the ladder to remove the dead bulbs
  • Note whether a screw secures the shade or if the lightbulb holds the shade in place.Unscrew the lightbulb counterclockwise. If the bulb is securing the shade, grasp the shade with one hand while removing the bulb.Install the new lightbulb by turning clockwise into the socket. If the bulb holds the shade in place, keep the shade in position with one had while screwing in the bulb with the other.
  • ceiling light
  • May 15, 2012 | Hampton Bay 24002 Ceiling Fan
    VW Passat 2006 What is warning light showing lightbulb with lines
    orange circle with dashed lines each side indicates worn brake pads, circle with cross through indicates bulb failure. third orange light indicates brake light bulb faiure
    May 13, 2010 | 2001 Volkswagen new Passat
    What lightbulb do I need for headlight on euro
    open bonnet and under slam pannel behind lights unclip and take out bulb, take to local parts retailer and ask for new one, dont touch glass of metal contact and insert new one, this will work, dont take it to a garage as they will charge you loads
    Apr 17, 2010 | 1992 BMW 5 Series
    Nes zapper wont shoot ducks.
    I've never tried the lightbulb trick, but I do know that light guns won't work an LCD or plasma screens, as it relies on how CRT screens work. If this describes your problem, you'll have to scrounge up a good 'ol boxy tube TV for your duckhunting needs.
    Jul 30, 2009 | Nintendo NES Console
    Lightbulb with exclamation mark inside????
    This means you have a light buld not working some where in the front or rear lights.When you fix the problem the light will automaticy go out hope this helps.
    Jun 03, 2009 | 2001 Volkswagen Jetta TDI
    Refrig light out, but lightbulb is new
    you dont know how many calls i ran about light buls not turning on and when i get there is loose try giving and extra turn to tighten remove and re install tigh if is not commimnog it might the light switch or loose connection inside.
    Oct 31, 2008 | Whirlpool 21.6 cu. ft. Top Freezer...
    Flasher clicking noise
    Lightbulbs
    They tend to speed up when the powers to high...;)
    Sep 26, 2008 | 2002 Volkswagen Passat
    Short in freezer?
    IF THE WIRES SHORTED, AND THE DOOR WAS REPLACED,
    WAS IT COMPLETE OR WAS THE DISPENSER ASSEMBLY TRANSFERRED TO THE NEW DOOR? IF THE ASSEMBLY ISN'T NEW, THE CONTROL BOARD IN THE ASSEMBLY MAY HAVE BEEN DAMAGED FROM THE WIRE SHORT.
    Feb 25, 2008 | KitchenAid Superba Architect KSCS25INSS...
    Refrigerators Logo
    57 people viewed this question
    Top Whirlpool Refrigerators Experts
    John Tripp
    John Tripp
    Charles T Nevin
    Charles T Nevin
    Dan Webster
    Dan Webster
    Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
