Question about Watches
Adjusting ******** 2009 tissot moto GP watch
I have a 2009 Tissot moto gp watch that i need to adjust the rubber strap to. How do i do it?
  • 14 Answers
SOURCE: Tissot wrist watch goingin reverse since new battery fitted
bikie,
It would be easier to tell you more if the age of the watch was posted, but not knowing that I am going to assume it is less then 3 yrs old and in good shape. He goofed! Never be afraid of asking someones experience level when working on something that belongs to you, find out if they are just a clerk in a jewelry store and are getting paid minimum wage and care more about their paycheck then your watch, OR if they have been doing it forever and care if you come back again! "IF" the watch is older then I assumed, or in questionable condition (a few bumps and scratches) then it may have nothing to do with the fact that the battery was just replaced, it really could be it's "time" to expire, pardon the pun!
Posted on Dec 01, 2007
SOURCE: tissot navigator manual
DIRECT LINK
http://www.t-touch.com/t-touch_images/usersmanual/140-en.pdf
Posted on May 20, 2008
escapement
  • 2334 Answers
SOURCE: Shortening stainless band for 1st generation Tissot Le Locle
Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet,make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
Posted on Jan 04, 2009
HyeProfile
  • 35 Answers
SOURCE: Changing the rubber ******** a Tissot T-Touch Watch
HOW TO remove/resize watch bracelets
Posted on Aug 05, 2009
SOURCE: my Tissot Watches second hand jumps 3-4 seconds bursts.Why?
The second hand jumping three or four seconds .I have had this same problem and found out that its i sign of wanting a new battery.Mine is now perfect
Posted on Feb 26, 2010
Can i get an extra link for my tissot 1853 (prs 200) bi metal,the strap is to tight, and will not adjust anymore.
I need one link for my watch that was given by my daugther its tissot diamond t shape stainless steel case,mop dial
Oct 26, 2012 | Tissot T Touch T33158851 Watch
I have a moto gp and popped the back to change the battery. no matter how hard i try the cover will not snap back on. am i doing something wrong?
Putting the back on a watch seems to be a frequent problem, possibly why most makers recommend that you let a jeweller replace a battery.
I suggest you try the following method:
1) Place you watch on a flat surface (on top of a cloth to protect the crystal)
2)place the back in position (check alignment of any seal)
3)place the thumbs of each hand together at one point on the rim and then (leaning firmly on both thumbs) work you way round the rim until the back clicks into position.
If there is a notch on the back which is made to make is easier to remove it, then I suggest that you start on the opposite side to this.
You may need several attempts to to get it right but keep trying.
If all else fails, a trip to your local watch shop should solve your problem.
Dec 31, 2010 | Tissot T0114171720200 T Race Moto Gp Le...
I dont know how to adjust time
You can download a manual or contact Tissot direct at this link:
http://support.tissot.ch/
Best regards
Aug 19, 2010 | Tissot T-Touch T33159851 Wrist Watch
Im trying to adjust the time because it stopped when i took it off for a day. Im not sure how i can change it because the adjusting knob is not popping out.
mcdevito75 here, Tissot a very, very great name and watch, a you know most stems pull out to set the time, some watches have a screw down crown this adds to it"s waterproofing as there is a gasket under the crown. Maybe your Tissot has this screw down crown, simply un screw the crown then gently pull up on the crown to set the time. If this fails, see any Jewler for help, doN't mess with the watch to much a syou or anyone could wreck it, and Tissot is very expensive.
Jun 24, 2010 | Tag Heuer 2000 Aquaracer WAB2011.BA0803...
Wrong airpressure reading in my Tissot Touch
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all TISSOT watch manuals.Rate me, please
Mar 22, 2010 | Tissot T-Touch T33159851 Wrist Watch
I have a new tissot Prc100 T22268631 watch, but i don't know how to adjust the time and date. What will I do?
The usual way to adjust time and date is to screw out (not pull) the winder and rotate it backwards or forwards. The winder will have two "out"positions, one for the date and the other for the time. (the "screw" for the winder is to improve water resistance).
If you have already tried this and it does not work, then go to the Tissot web site "tissot.com", locate your nearest dealer and ask for advice.
Alternatively on the Tissot site find your watch under the heading "sport". To view all the watches in a section move your cursor along the dots, this moves the images along to find the one you want.
Select the PRC100 and details of your watch appear and at the bottom of the menu on the left hand side select "user manuals".
Click on "download" on the right and instructions will appear
Jan 13, 2010 | Tissot Prc100 T22268631 Watch
Where to buy a strap
you get watch straps on ebay or you can go to watch menders or market or jewlers have them
Oct 03, 2009 | Tissot Prs516 T91141731 Watch
I went to Spain in July and I put the watch forward one hour.On my return home the watch will not return to GMT
You have to re-adjust your watch. Visit this site and find out how to:
www.tissot.ch
Rate me, please.
Aug 10, 2009 | Tissot T-Touch T33759851
Watches Logo
121 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
