Question about Lands Phones
Thereis one number we call regularly that rings in their home but no connection is made. The called party tells us that when they pick up they get what soulds like a fax signal. There are no fax machines involved.  The product is magicjack not shown below.
    President:
  • Lands Phones Master
  • 2,923 Answers
Is this working properly before? If yes, there could be some internet connection problem. If the internet connection could not provide the required upstream/downstream bandwidth, that would cause the magicJack not to work correctly.
To isolate the problem, try connecting the magicjack into another computer (Win XP or Vista only) but if the same problem occurs, then you need to contact the manufacturer for second opinion.
Have a great day!
Posted on Sep 13, 2009
My Lexmark Interpret S405 fax?copy machine picks up incoming call from cell phone as fax. it goes onto fax automatically after 2 rings..
It seems that you're sharing your home phone line with your Lexmark fax machine. You can adjust the "pick-up" ring from the printer operator panel by pressing the Setup button > Fax Setup > Ringing and Answering > Pick Up On > select your preferred number of rings before the fax answers.
Please note:
If you have an answering machine connected to the same line as the fax, set the answering machine to answer incoming calls before the printer does. Increase the number of rings by a factor of 3 over the answering machine. For example, if the answering machine is set to pick up on 4 rings, set the printer to pick up on 7 rings.
If you have a voicemail feature in the same line as the fax, you may subscribe from your phone service provider for a distinctive ring pattern feature. You can program your printer to have a distinctive ring pattern and phone number for incoming faxes.
Should you still need assistance, please leave a comment to my response and I'll get back to you. Should this resolves your problem, your rating will be greatly appreciated.
Nov 08, 2011 | Lexmark Interpret S405 Wireless All-in-One...
I am getting rid of my dedicated fax line and am adding it to my land line. I am told when I have a fax coming in I will hear a double ring which mean my fax line is ringing. How do I set my fax to...
There are two ways to configure a fax machine to answer the phone line. The first way is by pushing the "auto answer" key on the keyboard of the fax itself. When this key is used, the fax machine answers all calls that come in after a certain number of rings. The other way is to manually press the fax button when an incoming call is happening. You can set the number of rings for your machine to pick up by using the keys on the fax machine under the menu feature and then scroll using the up and down arrow keys until you see fax set up and then number of rings.
I have heard about the option that your speaking of, where they give you a separate phone number for your customers to fax when you own a business line but I don't know how the fax machine itself would be able to distinguish between the normal ring of a regular call and the double ring of the merged fax line call. I was told that when I set that up for my friends business recently, that the machine would auto recognize the double ring without any programming and to use the auto answer feature for all calls. He has not had any faxes yet (its a new business) so I can't say for sure if it works or not? I can say that none of his regular calls have been picked up by the fax so far though.
Nov 10, 2010 | Canon PIXMA MX310 All-In-One Printer
For a GE ProSeries telephone Model 2-9980A S/No 00098864 corded business phone - 1 line with speaker phone. What are the directions to forward the phone to another number? And, also, how to cancel the...
Go to settings on your phone, click on the phone option, it will display different option, select call forwarding or call divert, enter the number you forwarding the call to and press ok, you are done. follow the same procedure, when you get to call forwarding, you can select to cancel as you can no longer add a number.
Take care.
Oct 14, 2010 | Cell Phones
Cannot send faxes on my all in one hp office jet 5610
If the recipient side is ringing, then the problem is on their end. It sounds like the receiving fax is not set for auto-answering a fax call. A receiving fax machine should pick up and start to attempt the reception even if the fax number is dialed from a normal voice-only telephone; the receiving machine has no idea if the caller is a fax or a regular phone. It should pick up regardless and start to negiotiate the fax (that's the high-pitched whistling sound at the beginning of the call).
May 15, 2009 | HP Officejet 5610 All-In-One InkJet...
Need to set up phone/fax instead of just fax
I have a HP Officejet J6480 All-In-One and needed the answering machine and fax to be on at the same time.  I called the help line at HP and they said I needed another phone line into the home but I tried this and it worked.
First I got a different phone number for the fax machine - they do this for no charge at my phone company. This is not another physical line into the home - it is just another phone number with a different ring - it rings 2 fast rings for the fax machine instead of the phones regular one ring. I set the answering machine built into the phone to pick up after 4 rings and I set the fax machine to pick up on 2 rings. Be sure to set it so the fax pick up number of rings are less than the answering machine pick up number of rings.  It worked for me. Hope this works for you too.
Apr 24, 2009 | Brother MFC-260C All-In-One InkJet Printer
Not receiving any faxes but sending
Note: check your equipment for:
Fax machine must be connected to an answer machine
Receiving a fax automatically:
1 Make sure the Fax Auto Answer light is on.
2 To set the number of telephone rings before the printer automatically receives faxes,
Receiving a fax with an answering machine
When a telephone ring is detected, the answering machine picks up the call.
If the printer detects a fax, it receives the fax and disconnects the answering machine.
If the printer does not detect a fax, the answering machine receives the call.
2 Set the answering machine to answer incoming calls before the printer does.
For example, if you set the answering machine to answer calls after three rings, set the printer to answer calls
after five rings.
3 To set the number of telephone rings before the printer automatically receives faxes.
Oct 31, 2008 | Lexmark X5470 All-In-One InkJet Printer
Number or rings before voicemail
Start >> Settings >> Phone
-Choose the Services tab
-Disconnect data connection if needed
-Choose Call Forwarding and press Get Settings...
-Change "Forward After" time from 20 seconds to whatever you want
Oct 03, 2008 | HTC TyTN II Smartphone
Winfax Pick-up
Try looking at best buy for a fax switching device it can tell the difference between data and voice. I don't know how well they work but i have not used that particular program. I did find this though on another site http://www.windowsitlibrary.com/Content/238/15/1.html
You can have Microsoft Fax automatically answer every incoming call to your modem or, instead, you can manually choose which calls to answer. The quickest way to change this setting is to right-click on the fax icon on the Windows taskbar then choose Modem Properties to display the Fax Modem Properties dialog box . Another way to get to these properties is from within Exchange; choose Tools, Microsoft Fax Tools, Options, then switch to the Modem tab, select the modem, and click the Properties button.
So you have to change the settings in Exchange I assume
Jul 08, 2008 | Symantec WinFax Pro 10.0 for PC
How do I change ringing to all handsets at the same time
SET ring to standard and not musical or distinctive ring. SINCE I am in India WHAT kind of line you are using isnot known.thereis setting on FAX to detect fax tone. Switch phone Fax switch to AUTO.
Mar 18, 2008 | Uniden TRU8885-2 Cordless Phone
No ring out when line switched.
It could be that the line that you are connecting to is not the number that you think it is. call someone that has caller id and make sure that is the number you think it is. Do other phones ring when connected to that jack?
Feb 15, 2008 | Lands Phones
Lands Phones Logo
32 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
