Tape keeps rejecting
Tape keeps coming out of VCR. It will stay in and play once in awhile after trying several times to keep the tape in VCR.
Thanks
  • 62 Answers
Have a look at the recording lugs on the left and right hand side at the rear of the cassette tape case. Check that they are still there and not loose. If you have removed them at sometime to stop it being over-recorded then maybe whatever you use - sellotape, electrical tape, duct tape, has come loose or gone soft. If none of the latter then there must be a problem with that cassette if it is the only one doing that. If it's not the only one then the problem is inside the VCR and will need to be taken to a reputable repair shop or they may do house calls.
Good Luck
Posted on Sep 13, 2009
Testimonial: "Thank you, I will try this and let you know. Juanita_16821@msn.com"
LG ALL MULTI REGION CODE ZONE FREE DVD RECORDER PLAYER VCR COMBO I paid over $300 for this combo and it worked fine the first few days. Now, the vcr wont play, it was attempt to play then just eject...
Have to take the cover of the unit and observe the vcr rejecting the tape action. If it is the take up wheel not working; you might keep the unit on vcr for a few weeks. this will dry up the circuit from condensation and take up wheel will work again?
Nov 07, 2010 | Televison & Video
I hAVE 24 in DVD triple combo ^&@$DG TV. I put
You're describing what could be a loose or worn loading belt problem, most of the vcr mechanisms used in these combos use one to load the tape and thread it for it to play or record, that is why you have to keep puhing the tape untill the machine accepts the tape and you have to keep pressing play untill it starts the play function.
Sep 19, 2009 | Sylvania Televison & Video
SONY VCR: Keeps ejecting video tape
When putting in a video the VCR has a tendency eject the tape and then shuts off. Then there are times it works fine. What seems to be the problem?
Apr 07, 2009 | Panasonic DOLBY DIG. 850w HOME THEATER...
Magnavox zv450mw8 Walmart VCR/DVD recorder. shuts off
on vcr's if the tape is hard to turn the tape will sense this and reject the tape. Try to get a tape that you can feel turn free eaiser. I would rewind it to the middle of the tape so each side is equal and it would make the tape run easier. If it runs ok then the unit is bad and is too sensitve to the pull on the tape. This is all designed in the electronics and there is not much you can do about it then get return it if you can.
Jan 01, 2009 | Philips Magnavox DVD/VCR Dual Player
Philips DVP 3150V
saida horizontal com deficiencia faz com que a fonte aciona circuito de proteção.
Feb 09, 2008 | Philips CCB092AT 9 in. TV/VCR Combo
Tape stuck in VCR, won't eject.
you posted 2 different problems here...
to answer this one ". The tape is stuck, won't eject and I'd like to get it out without damaging the VCR unit."...open unit, find motor that moves tape ejector and spin that motor by hand (power off)
the other problem, "the VCR will not insert a tape. It keeps rejecting it."...open unit and fully turn ejection motor until home position is reached...this is a home sensor switch not being activated.
Feb 04, 2008 | Televison & Video
What do I do when my Emerson TV keeps turning off by itself?
I had the same problem with mine turning off after 3-5 seconds. After much research I found a suggestion that on some combo units the vcr part could have a power supply cutout if it is not working correctly. I tried to insert a tape and found that the tape mechanism would not accept a tape. I used a little bit of force and managed to insert a tape. I then played the tape forwards and backwards and the power stayed on! I ejected the tape and found the TV then worked just fine. The power has now been on for over one hour. I hope this give you another avenue to try and fix your problem.
Nov 30, 2007 | Televison & Video
Power problem
Has this just started happening? What did you do just before this happened? You need to supply much more information, we are not mind readers! What's the make and model, this ain't a generic problem!
Oct 06, 2007 | Quasar VV1309 13 in. Combo
VCR Tape will not play, it keeps ejecting
I have a similar problem. It takes 3 or 4 times to get my Sony VCR to accept a tape. Once it does, everything is fine, until I turn it off. Next day, same trouble. I tried several tapes and brand new tapes. No difference. I have opened the cabinet and used alcohol to clean various stuff, no change.
Feb 02, 2007 | Quasar VV-2002 20 in. TV/VCR Combo
Televison & Video Logo
135 people viewed this question
Top Televison & Video Experts
Electro Med Services...
