Question about Canon LASER SHOT LBP-2900 Printer
How print 300x300 dpi image in CANON 2900B??????
  • 33 Answers
Resolution
True 600 x 600 dpi
AIR (Automatic Image Refinement) 2400 x 600 dpi equivalent
Posted on Sep 13, 2009
I have used last 4 year canon 2900B printer. How to set 300 dpi printing resoluation
Canon PIXMA Manuals MG2900 series Resolution
Resolution The data in the image you have scanned is a collection of dots carrying information about brightness and color. The density of these dots is called "resolution", and resolution will determine the amount of detail your image contains. The unit of resolution is dots per inch (dpi). Dpi is the number of dots per inch (2.5 cm). The higher the resolution (value), the more detail in your image; the lower the resolution (value), the less detail.
How to Set the Resolution You can set the resolution in Resolution on the (Scanning from a Computer) tab of the Settings dialog.
Appropriate Resolution Settings Set the resolution according to the use of the scanned image.
Item Type Use Color Mode Appropriate Resolution Color photo Copying
(Printing) Color 300 dpi Creating a postcard Color 300 dpi Saving to a computer Color 300 dpi Using on a website or attaching to e-mail Color 150 dpi Black and white photo Saving to a computer Grayscale 300 dpi Using on a website or attaching to e-mail Grayscale 150 dpi Text document (document or magazine) Copying Color, Grayscale, or Black and White 300 dpi Attaching to e-mail Color, Grayscale, or Black and White 150 dpi Scanning text using OCR Color or Grayscale 300 dpi Important
  • If you double the resolution, the data size of the scanned image quadruples. If the file is too large, the processing speed will slow down significantly, and you will experience inconvenience such as lack of memory. Set the minimum required resolution according to the use of the image.
Note
  • When you will be printing the scanned image by enlarging it, scan by setting a higher resolution than the recommended one above.
Oct 07, 2014 | Canon LASER SHOT LBP-2900 Printer
I cannot understand how will print picture 300x300 dpi in CANON 2900B
Have you looked in your manual? If you don't have one download it from http://files.canon-europe.com/files/soft26403/Manual/LBP3000_UG_EN.PDF
As far as I could see, you cannot define a setting of 300x300 dpi. You have to decide on level of 'grayness' and 'density' [Ch..4 Page 44+]
If you need further help contact Canon Support at
http://www.canon.co.uk/Support/Consumer_Products/product_ranges/printers/i_SENSYS/index.aspx
May 10, 2014 | Canon LASER SHOT LBP-2900 Printer
300 dpi print
go to the cannon website and check their support/downloads
Dec 23, 2013 | Canon LASER SHOT LBP-2900 Printer
How do i change the print dpi on my canon ip4600
That is changed in your printing software and will depend on how the image was saved to your computer. You can't print at higher DPI than image was saved in.
Dec 13, 2009 | Canon PIXMA iP4600 Color InkJet Photo...
CANON LBP 2900B
open the printers properties.
open printing preferences.
go to quality
go to details
click on save toner mode
apply
close
now your printer prints in 300 x 300 mode
Sep 13, 2009 | Canon LASER SHOT LBP-2900 Printer
300 dpi in canon 2900B
I cannot understand how will print picture 300x300 dpi in CANON 2900B. There is solution but not working.....
How to set resolution 300X300 dpi
ok goto start /control-panle/display /change isplay settings then drag pointer to ur number/then apply
Aug 24, 2009 | Canon LASER SHOT LBP-2900 Printer
How can set 300x300 resolution canon lbp 2900b
When you hit print, a pop up will come on screen. Select printing preferences and select what you want.
Aug 07, 2009 | Canon LASER SHOT LBP-2900 Printer
Hp deskjet 940c printer
1.Setting DPI values
2. Follow one of these paths to select your print options, depending on the
software program you are using:
• Click File > Print, then select Properties
–or–
• Click File > Print Setup, then select Properties
–or–
• Click File > Print > Setup, then select Properties.
The printer properties box appears with Setup, Features, and Advanced
tab options.
3. Select the Setup tab, then choose the following:
• Print Quality: Best
• Paper Type: The appropriate photo paper type
• Photo Paper Printing:
- PhotoREt for best print speed and quality
–or–
- 2400 x 1200 dpi for source images greater than 600 dpi (requires
400 MB or more hard disk space and takes longer to print)
• Paper Size: Appropriate paper size
4. Select the Features tab, then choose the following:
• Orientation: Appropriate orientation
• Two-Sided Printing: Unchecked
• Copies: Up to 20
5. Select the Advanced tab if you wish to make optional adjustments to
color, ink volume, or ink drying time.
6. Click OK to return to the Print or Print Setup screen.
7. Click OK to print.
Apr 08, 2008 | HP DeskJet 940c InkJet Printer
How do I setup the camera to save pics above 180 dpi resolution?
Select image>image size, make sure that the 'resample image' box is unticked and change the resolution to 300 dpi. This will automatically change the image size.
Sep 14, 2005 | Canon PowerShot SD200 / IXUS 30 Digital...
Canon LASER SHOT LBP-2900 Printer Logo
282 people viewed this question
old marine
old marine
