Question about Lexmark P4350 All-In-One InkJet Printer
Scanning problem When using the scanner I am missing around 2" down one side of the page - can it be repaired
  • Anonymous Dec 12, 2007
    blurred scan down one edge of the paper - unable to find a sloution
  • mary_marchan Jan 28, 2009
    My problem is the same when scanning or copying. Help
My proposed solution was given to me by a Lexmark Tech. It applies to 4350 and 4850.
1. Under the Control Panel, choose Add Remove Programscanning problem - 1.gif
2. Repair Microsoft1.gif Framework 2.0
5. Uncheck Loadup Start Items -- allows the complete program to load
6. Uninstall Lexmark
7. Rebooscanning problem - 2.gif src="" alt="2.gif" class="h_mi" />
8. Install Lexmark files from
Posted on Dec 18, 2007
Scans are coming out upside down
First, are you putting the pages to be scanned in upside down. If not, do so. I sometimes encounter this problem but use the free version of Adobe that comes with the scanner to turn the scanned pages right side up. Hope this helps.
May 28, 2014 | Fujitsu ScanSnap S510
I have a big black line down the middle of my scans
If dirt sticks to the scan module, it will be scanned continuously and appear as a line in the output. Clean the glass with Isopropyl Alcohol. Dont use any other solvent.
S. Mohan, India
Mar 12, 2013 | Canon DR-5010C Scanner
Right side of document is black when scanning to print, umax 1220u
1. Fred's right about trying another computer, but you still may have wrong/ old driver- download demo version of Vuescan at and see if it's your software.
2. Partially blank pages can appear when you don't have sufficient memory for the scan, but that usuall loosees the lower half of the page.
3. The lamp is probably not the problem, because there is enough liht bouncing around in mostflatbead scanners that you would just see the image "fade"to black, not have a distinct line.
4. best bet is that something inside has come loose and is covering half the scanning sensor, or the mirrors that reflect the images to the sensor inside
Dec 24, 2012 | Umax Astra 1220U Flatbed Scanner
Why does my HP 1500 prints a test page every time I begin touse it???
As soon as the printer prints the test page or alignment page place it on the scanner glass (Place the printed side down) before that Examine the scanner glass and white scan backing. Clean the scanner glass and scan backing if they are not clean. To clean the scanner glass and scan backing, use a soft cloth towel slightly dampened with clean water.
After That press scan on the printer button panel it will resolve your issue.
Try to double check it by turning it off and turning the printer back on after 2 minute's. If still the problem exists call HP Total Care 800 - 474 - 6836 if you are from US/Canada.
) Lift the lid of the product.
2) Place the top of alignment page face down in the right front corner of the glass.
3) Place the alignment page face down
4) Close the lid.
5) Press the Start Scan button.
6) The Power button light will blink during the alignment process.
7) After the Power button light stops blinking, alignment is complete.
Aug 04, 2010 | HP Office Equipment & Supplies
Scanning Blank
Try and re-install the scanner, check the settings of the scanner software you are using and change the settings to scan picture or scan in colour. Thanks
May 13, 2010 | IRIScan Executive 2 Flatbed Scanner
Orange line running down page
lift lid on scanner and clean the thin glass on left hand side
you usually find when you scan alot of docs dust builds up and leaves lines down page
Mar 08, 2010 | HP Scanjet 5590 Flatbed Scanner
Whitch way does the paper go in for faxing ?
If your using the feeder on the top of the scanner, it should go face up. If you are faxing from the glass - face down.
Oct 29, 2009 | HP Officejet 6500 Wireless All-in-One...
Fujitsu fi-4340c scanner not scanning all of back side of page
these rear camers get the board that has the CCD chip on it come loose from the camera. take off the ADF cover, at the from of the rear camera you will see the board held on with 2 screws, there have probably come loose. you will need to tighten them up with the board in the right place to allow the image from the camera to be focused on this chip. it will take you a while to get it in the correct place, but once you have it correct, the image will be perfect again. let me know how you get on
Jul 08, 2009 | Fujitsu fi-5750C Flatbed Scanner
White line down side of page when scanning
If this is happening only when you are scanning using the automatic document feeder, check for something blocking light above the scanner. If you open the scanner top, look along the left side of the scanner glass where the paper is scanned by the automatic document feeder. If you see anything on the glass there, clean it with a soft cloth dampened with clean water.
Jun 10, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Scanner excludes front page
This is not the only solution, but this might help.
Put a blank page in as the first page and see if all of your documents scan completely.
You may need to clean the ADF. Try the following:
Cleaning the Automatic Document Feeder
You may need to clean the ADF feed mechanism if your
documents do not feed easily into the ADF, or several feed in at the
same time.
To clean the ADF:
1. Dampen a soft cloth with some isopropyl rubbing alcohol
2. Press the ADF cover release on the top left of the scanner body
to open the Automatic Document Feeder cover.
3. Wipe the feed roller from side to side. Rotate the roller to clean
its entire surface.
4. Wipe the pad from top to bottom. Be careful not to snag the
cloth on the springs on either side of the pad.
5. Close the cover when you’re finished.
NOTE: Please be careful when cleaning the roller. The roller is
designed to rotate in one direction only. As you’re cleaning the
roller, make sure it rotates easily, and continue rotating it in that
direction while wiping it clean. Do NOT force the roller to rotate
in the opposite direction. Forcing the roller to rotate will damage
it, and may cause the scanner to feed pages incorrectly.
Please let me know if this has helped and thank you. Binary Bob
Dec 05, 2007 | Xerox DocuMate 252 Path-Through Scanner
Lexmark P4350 All-In-One InkJet Printer Logo
194 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
