Question about Sony Cyber-shot DSC-W70 Digital Camera
After charging the Battery the power button flash blinks
My camera Battery was dead fro 2 months, after getting an new charger ($65) to charge the battery I placed it in Camera. Theres Red light blinking where I put the battery in never seen that before. Now to tuen on the Camera I have to hit the recall button ! Display never comes on either
    Scholar:
  • 44 Answers
I think the red light means low power for battery... maybe just maybe your battery didnt really charge.. im not saying that its the charger, but try to buy a new rechargeable batteries, use it then charge it and compare it with the other one... i think thats the problem with batteries if we stop using it for a long time... hope ull be able to resolve it
Posted on Sep 13, 2009
SOURCE:
Light does not flash when charging battery
Please try this:
1) Make sure camera is OFF.
2) Plug Charger into the wall (not into camera)
3) Last think plug charger into the camera
Oct 15, 2014 | Nikon Coolpix S3000 Digital Camera
I hit the power button and it turns green for a second but then goes out. The camera and LCD screen do nothing. So I have some sort of power problem. When I put the battery in the charger the charger light...
theres no choice your battery charger is may be out and try new battery and try the power cable from the charger and connect directly to the cam if you got the original power pack/ for the green screen it can go green or bleu when the battery go low, some time that is the video processor ic...
i hope for you it just the battery....
and good luck
May 13, 2010 | Sony Cyber-shot DSC-W120 Digital Camera
Battery Dont Charge
I had the same problem. I had a 1 year warranty, so I called 1800-435-7732 and they sent me a new battery within 5 days. I just received it today and it works perfectly. Hope this helps you! =]
Dec 26, 2008 | Casio Exilim EX-Z77 Digital Camera
Olympus battery charger flashes red when battery is inserted.
@gminvite1
"Another way I found was when this happens, to push the battery to the point the light will turn on, when it starts flashing slide it off then back on. Do this a few times so it charges a little, then you should be fine to leave it on."
I tried to do this with my LI-10C Olympus charger and it worked..The blinking red light turns to solid red..Thanks for the info...Now I won't be bothering to buy a new batt.or have my charger checked..
Nov 14, 2008 | Olympus FE-230 Digital Camera
WON"T WORK
sounds like a dead battery. Plug the origional charger into it and the front led (below the flash) should flash red. If the red led in the back of the camera flashes or stays lit, then you have the wrong charger plugged in. (the camera won't power up if the back red/green led is on when plugged in)
May 08, 2008 | Jazz DV-179 Digital Camera
Casio Ex-Z75 Battery not charging ?
This problem is known. There is a way to fix it.
The fact that it blinks on and off means that the battery is completely out of energy. Thus, the charger doesn't "recognize" the battery.
To fix the problem, you need to give some energy to the battery. What I usually do is that I use a 9V battery (or any other source of power) and I link + and - of both the Casio battery and the 9V battery. You can use a paperclip as a link (you will use 2 paperclips, 1 between minuses and 1 between pluses).
Do that for 2 minutes and then charge your battery as usual. It should work !
Sorry if my English isn't accurate. I'm French.
Mar 17, 2008 | Casio Exilim EX-Z750 Digital Camera
Battery Charging light doesn't flash and battery doesn't charge
I have the same problem. Worked for 3 years and now the battery charges to green but goes dead immediately. I've changed batteries. Its the camera not the batteries. Works fine plugged in. Obviously the cameras are not charging the batteries. Canon must know but I cannot find a fix and warranty is over. I guess buying the expensive camera of the day isnt always assuring you of quality.
Dec 25, 2007 | Canon PowerShot G2 Digital Camera
Is my camera broke?
sounds like your battery or charger might be defective. I have this camera an when the battery is to low it flashes the screen.
I still use the original charger that came with it to charge the batteries,been thru 4 of those. It seems if they set a while without being charged the go bad.
Nov 04, 2007 | Video Cameras
Battery charger
I had the same problem as this.
what i did was...
i kept putting the battery on the charger then took it off as soon as the red light came on.
i did this about 6 times.
doing this puts a bit of charge in the battery each time before the charger starts to flash.
after the battery as got enough charge in it it can start to charge.
hope this helps.
Sep 26, 2007 | Casio EXILIM Card EX-S770 Digital Camera
Sony Cyber-shot DSC-W70 Digital Camera Logo
166 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Dan Dangel
Dan Dangel
Level 1 Expert
Are you a Sony Camera Expert? Answer questions, earn points and help others
