Question about LG Televison & Video
I have LG 42PQ6000 plasma tv that turns on and after 2 or 3 seconds it turns off with a click sound. What could be the problem?
    Habit-Forming:
  • 19 Answers
Your plasma tv goes to standbye because protection circuit is activated . Usually there is some thing wrong with one of the boards inside your tv . First try to make a reset to your tv by disconnecting the main plug from wall socket , wait for 15 _30 minutes, then plug it ON , try to use remote controller to switch it ON .
If the problem still exists ., then you may need to take it service centre or ask a specialized technicien to fix .
Posted on Sep 02, 2019
    Habit-Forming:
    New Friend:
  • 123 Answers
The click sound is the power relay coming on and off. The tv is sensing a power problem and shutting itself off. If you are handy, remove the back of set , disconnect the connectors to each board and check voltages out of the power supply. If they are not to speck, replace power supply board. If they are ok, reconnect one board at a time and see if power stays on. You should be able to find the bad board this way. Visually inspect each board for burned components or swollen capacitors.
SOURCE:
  • 15 Answers
SOURCE: 42 inch LG Plasma TV - Lost picture
ysus pcb that supplies voltage to the panel is faulty
Posted on Dec 15, 2007
  • 3 Answers
Our LG 50" plasma tv screen went black after a popping noise but still had sound, after great diliberations decided to take the back off and have a peek!
We unplugged the tv and tested the fuses (there were three we could see) one had blown, the one on the left as you look at the back of the tv it also has one above it. We wrote the code/seriel number down and took the fuse to the electrical wholesalers Maplin and bought a pack of 10 fuses for £1.29 replaced the fuse in the tv and everything now fine!!!!!!
Hope this might be of use to anyone whose lost the picture after a loud popping/snacking noise but still has sound.
Posted on Jan 17, 2008
SOURCE: Lg tv will not turn on, red light
i think your bulb is shot must be replaced
Posted on Apr 29, 2008
SOURCE: Samsung 50" plasma won't turn on
My 42" plasma is making a clicking sound, then it switches off and keeps clicking but not switching back on, when it does go back on it stays on for just a few moments, it is only 14months old.
Posted on Dec 04, 2008
  • 41 Answers
SOURCE: LG plasma TV turned off, after the picture very light
I think you have a defective power board. the pop sound in coming from the board and giving you a low output voltage. do it yourself price about two hundred for parts.
Posted on Mar 13, 2010
My tv powers on displays the LG logo then makes a high pitched squeal sound from speakers and then flashes on screen (strobe light effect) does not display picture or sound.
LCD TV Repair Tutorial - LCD TV Parts Overview, Common ...
? 11:05
https://www.youtube.com/watch?v=tS4sIpdajVw
Aug 23, 2013 - Uploaded by ShopJimmy.com
Repair review of common LCD TV Problems and Repair Solutions ... input the tv is set to it begins making a high pitched whiningsound. .... I have a LG 47LN5750 that powers on, flashes a good picture for about 1/2 second, then goes dark. ... hi my samsung tvis not turning on is black. and I just replace the ...
#Treat At Home high pitched whine from plasma tv Tinnitus ...
www.aspenridgerentals.com/tinnituscure/?...high%20pitched%20whine%...
LG 50PK540 plasma TV Repair power supply EAY60968801 Part 1-2 ... Sanyo DP42849 with high pitched squeal after replacing power supply. ... In my second daily fix video, I solve a mystery that was making me having to turn off my speakers before I went to be ... The flash is accompanied by an high pitched sound.
TV not turning on; making high-pitched sounds - Tom's ...
Dec 16, 2015 | LG 55LE5400 TV
Lg 42pq6000
These blinks [flashes] are fault indication (Error Codes).From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it.This will make repair easy.These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times.Count it carefully.If you wish to get some details, check the site linked here.It has details about blinking codes, and fault locating, to many popular brand TVs and other devices.Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given.
Feb 12, 2014 | Televison & Video
LG plasma turns off and on by itself while making clicking sounds
Probably the power supply is failing. The clicking sound means the power supply is trying to turn on but can't.
Dec 19, 2013 | LG 60PC1D 60 in. Plasma Television
White screen on start up displaying v3.30.0
Try pressing the EXIT button on the remote control, this display is the Aging Mode sometimes caused by a software glitch.
Nov 11, 2013 | LG 42PQ6000 42 in. HD-Ready Plasma TV
LG 42PQ6000 plasma TV blows fuses in the wall plug when switched off on the set (ok when put to standby with remote) Shop said it was probably the wall socket so have had this replaced by a competent...
sorry to tell you but this is a plasma TV it uses very high voltage and is very complex inside do not try to go inside of this tv even if it is unplugged you will likely need to take it to a shop with experience with plasma TVs
Jan 02, 2018 | LG 42PQ30 42 in. Plasma TV
I have an LG plasma TV, model: 50PC1DRA. We had a
Defective power board. Maybe best to call local service man.
Sep 28, 2009 | LG 50PC1DRA 50 in. Plasma Television
Turn the TV on, clicks back off - no sound, no picture
hello, your power supply has to be repaired and you are looking at $275.00 for this job
good luck
Jun 23, 2009 | LG 42PG20 42 in. Plasma HDTV
Dec 17, 2007 | LG 42PX4DR 42 in. Plasma TV
Televison & Video Logo
149 people viewed this question
Ekse
