Question about Simrad Rpu160 Reversible Pump 21118237
Testing Simrad Autopilot RPU160 Reversible Pump (21118237)
Autopilot failed. Keep getting rudder response failure. In standby, rudder indicator works. Steering with manual hydraulic wheel works fine. RPU motor was replaced 12 months ago due to a failure. Is there any way to test the RPU unit before purchasing a new one. I have removed the old unit from the boat. If I hook 12 volts up the the motor leads, will it prove it anything?
    New Friend:
  • 132 Answers
Yes, hook it to 12V it runs, reverse wires it runs opposite it will spit oil, watch out! shoulda coulda left it in place and tested with jumper cables or battery if pump is bad 1 find out why your boat eats pumps 2. call me, i have it in stock for less than you paid before (most likely) 3. you can replace the electric motor without disturbing the hydraulics!!!
847-746-0100
Posted on Jan 16, 2010
Drive unit error navpilot 511
That errors means the autopilot is trying to move the rudder but it thinks its not moving. If you can manually move the rudder in standby mode with the green or red buttons on the 511, then the problem is typically with the rudder feedback unit. i.e. the rudder is moving but the only way the pilot knows it is if the signal changes from the rudder feedback unit.
If you can't make the pump work with the arrows (or anything else) then the problem lies with the pump. Check 12VDC to the pump and the connection to the processor.
Apr 03, 2014 | Boating
I AP 35 Setup
ensure you are setting correct rudder value.
Aug 14, 2008 | Simrad AP35 GPS Receiver
Problem: Autopilot does not engage. This is a new problem as it was working quite recently. Model: Simrad NSE8/AP24 with AC42 Autopilot Computer. Attempts to engage the autopilot result in an...
jimtippettau:
Which drive are you using with the AP24, is it just a hydraulic pump on a powerboat, like our RPU80, or is it a hydraulic linear drive (like our HLD-2000) or draglink drive (like our DD-15) on a sailboat?
Mar 24, 2011 | Simrad AP24 AUTOPILOT DISPLAY UNIT
MOT POW SWAPPED, this is the message which appear just like that. the autopilot is working last 5 years, i have checked the wires connections, all is set as the diagram. one thing: my rudder has some...
Check if rudder reference unit is installed as before ,it seems that the pilot sense that the rudder is turning the wrong way. check when giving +10 command the
rudder turns to increase the heading,if yes, it could be the wiring of the rudder reference unit or it was installed the wrong way after service on the rudder.
Is rudder position indicating correctly?
Jun 24, 2010 | Raymarine Smartpilot Autopilot St6002 S1g...
Autohelm ST 6000
Check the installation manual for initial setup,if system worked before ,check rudder reference unit for broken wire loose connection or defective unit (it is a potentiometer resistance shoud change smoothly with position)
May 21, 2010 | Raymarine Smartpilot Autopilot St6002 S1g...
Simrad AP 11 Autopilot control head
I happen to have an ap11 head unit in good condition, please contact me.
Oct 28, 2009 | Simrad Boating
Autopilot shows "no rudref"
The rudder sensor works like a light dimmer, so you get 5V and ground on the outside two connections and a varying voltage between about 1 and 4 volts depending on rudder position
847-746-0100 www.technicalmarine.com
Jul 07, 2009 | Raymarine Smartpilot Autopilot St6002 S1g...
Simrad ac10 current overload
Normally this is the electric motor causing this problem. Just went on a call and had the same thing. Checked voltage coming from the AC unit to the motor and had 12 vdc then put a new one in it's place and it solved the problem. You don't have to change the pump portion, just change the motor itself. Indeed you will have fluid leaking but many times it's better than plumbing in a new pump.
Feb 18, 2009 | Simrad Ac10 Course Computer
AP35 Autopilot
Yep, if rudder calibration values are OK, then there is a real problem with calibration, it can be a mechanical problem or a faulty rudder feedback unit. Follow procedure at page 93 of user manual :
AP35 Autopilot Instruction Manualto troubleshoot the error, if you cannot get rid of the error message you may have to replace the rudder feedback unit or to have the unit inspected by a technician.
Simrad Rpu160 Reversible Pump 21118237 Logo
538 people viewed this question
Top Simrad Boating Experts
Michael Vincent Cruz
Steve
Steve
ray gallant
Are you a Simrad Boating Expert? Answer questions, earn points and help others
