Question about Whirlpool GS6NBEXR Side by Side Refrigerator
Whirlpool Ice maker4 issue
I have a side by side fridge / freeze. it no longer despenses ice.
the ice maker is filled with ice which has not despensed.
if you take out the ice maker, defrost all ice, reinstall the ice maker then it fills as normal with water that frezes but still will not despense the ice.
the forks are in the two oclock position pointing towards front of freeze.
i have replaced the ice maker and the same problem exists on the new unit.
what do i need to check?
How can i test to determine if this is correct?
Posted on Sep 14, 2009
  • 220 Answers
Sounds like the optics are bad part # 4389102 this model(if we have the right model#)has two optics boards one receiver one emitter on either side of the door opening which shoot a beam from one to the other through the opening in each side of the bin,as long as nothing blocks that beam and the freezer is cold enough to chill the thermostat to temp in the icemaker,then it should be dumping ice.
Posted on Sep 13, 2009
Whirlpool side by side with water and icemaker. My water works perfectly fine but my ice maker no longer produces ice. It runs but it's not getting any water to make ice. What can be done to fix this?
There are a couple reasons your icemaker will not fill with water.
First thing you want to check for is a frozen fill tube to the icemaker. The easiest way to check for a frozen line is to remove the icemaker. Once the icemaker is removed look for ice in the fill tube. If there is ice in the tube the (water valve) will need to be replaced. You can melt the ice by forcing hot water up the fill tube.
Another reason could be the icemaker is not sending voltage to the water valve. The fix for this issue is to replace the icemaker. Hope this helps you with your whirlpool fridge!
The reason to change the water valve with a frozen water line is because the solenoid is not closing all the way. This allows water to enter the fill tube of the icemaker and freeze based on the temperature.
May 04, 2017 | Whirlpool Refrigerators
Whirlpool Gold icemaker won't make ice
Try this and add tap water to the empty ice maker. Turn it on if off and if after the water freezes the ice maker cycles dumping the ice into ice bucket and if the ice maker does not refill with water on its own you will need to replace the=> 2188746 Water Inlet Valve
If the ice maker does nothing then replace the=>
2198597 Ice Maker Assembly
Thanks John Tripp Appliance 911
Feb 16, 2014 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
I have a whirlpool model ED25PWXBN00 refrig and the ice maker is making ice but the part that holds and dispenses the ice has broken and no longer dispenses ice. what part do i need?
That depends if the ice maker continues to fill with water or just sits there with the ice slots empty. Sometimes it is the dual water control valve=> 4318046 Water Control Valve
and sometimes the ice maker itself. Does not hurt to have an extra part of each if you are a ice user like myself. If ice slots are empty fill with tap water and allow to freeze. If the ice drops and slots do not refill with water then replace the dual water control valve. 4317943 Ice Maker Assembly.
Oct 02, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
There isnt any water getting thru to the icemaker. i changed the watervalve and still no water i cannot locate the water filter even tho i removed the bottom grill, water is still getting to the water...
if you put a new water valve on the fridge then you either have a bad ice maker or the line is frozen where the water fills the ice maker,a bad water valve will make the line freeze,water keeps dripping through the valve and freezes the fill line behind the ice maker cup,you can remove the ice maker and check the fill line,if it's frozen get a hair dryer,shut down the fridge or unplug it and blow the hot air into the fill line until the ice melts,then get a piece of wire and after you reinstall the ice maker pop off the cover to the ice maker and jump it out with the wire,stick it in the t and h for 15 seconds and pull it out,if the ice maker is good it will start turning and when the arms get at like 11 oclock it should fill,also you can jump out the fill valve from the ice maker,stick it in v and L and if water fills the ice maker you know you have a bad ice maker if the fill line isn't frozen.hope this helps.next time you need help send the model number,on your machine look in the fridge section on the right hand wall up near the ceiling to find it,if it's older look down near the bottom hinge on the fridge door and you'll see a tag with the model number.good luck
Sep 12, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool ED5VHEXVQ03 side by side. Ice maker is not making ice. Checked water line - okay. Checked water valve - okay. Water filling tray - okay.
Whirlpool Ice Makers are about the hardest working part on your refrigerator and their average life is about five years. You can fill the tray with tap water if the ice slots are already empty and let the water freeze. If after the water freezes and the ice drops to ice bin then the water control valve.
Click Here=> 4389177 Water Inlet Valve will need replaced. You mentioned the water is filling the tray OK then my focus would be on the ice maker.
Click Here=> W10190965 Ice Maker Assembly
Most times it is less expensive to just replace the ice maker module. Here is a helpful video that helps explain everything about the Whirlpool Ice Maker below. If you find this solution helpful please rate my solution, Thanks Sea Breeze
Jun 29, 2011 | Whirlpool Refrigerators
Whirlpool mod.ed25pqxfw1 will not despense ice. motor will not run. is there a test procedure?
I found a parts manual through Whirlpool and it says your ice maker is mechanical type. Fill with tap water and let freeze and if ice maker cycles and dumps the ice but does not refill the the water control valve part number 2182106 but that number has now changed to 2188542. Try this test first and I will send the parts manual and user manual. The test will point to what is happening like water control valve or the fill thermostat inside the ice maker, Thanks, Sea Breeze
Mar 17, 2010 | Refrigerators
I have a side by side that has the ice maker in the door, when it makes ice cubes, they come out all connected and this makes it difficult to get ice to despense from the shoot and most of the time it will...
It sounds like you have too large a fill of water in the ice maker. If you remove the ice maker there is a fill adjustment screw under the cover of the ice maker.( the only way to get the cover off is to remove the ice maker)
Very small plastic screw head of about 1/8 inch or less. Ice maker controls water valve by time fill. Believe there is one turn adjustment total available. You might want to put a small hole in the cover before you reinstall it to adjust screw the next time without removing ice maker, believe it will be side facing out. Lastly I think you turn adjustment screw in to decrease and out to increase time of fill.
Suggest leaving a towel on the floor for awhile until you have solved problem.
Next thing to try would be a different ice maker, or if normal sized ice is melting and refreezing in the bin, you have a cooling or thermostat problem .
Good luck
Mar 07, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
My fridge is a side by side whirlpool, and it has a water despenser. The water despenser and ice maker isn't flowing, there is no water, no ice. Im not sure the model #.
check your water supply is ok and replace your water filter if it has one this should solve you problem if not then its poss you have bad water solenoids but not likely. peyton
Jan 19, 2009 | Whirlpool ED2FHSS Side by Side...
No water
two things may have happened, first the o-ring washer on the pipe tap may have shrunk and restricting the flow of water, second the filter for the machine may be plugged up and need changing. good luck and if yoiu still need assistance feell free to ask againd
Ice maker will not despense when full of ice
Hello , that is exactly what is happening this is caused by 1 of 2 things.
1- the module/control on the front of your ice maker is sticking during its cycle and over timing the fill stage.
2-your inlet valve located in lower rear at water line connection is not sealing causing water to seep through line to ice tray and overfill.
Both are common issues and the most cost efficient way to repair this is to order the ice maker kit that contains both the ice maker and the valve so you can guarantee the fix.
You can purchase on line with your model number for around $100 Calling a service company will cost at least $150 changing only one of these parts or about $200+ for both.
If you have any questions please ask and let me know how it goes.
Phil
Jan 02, 2009 | Samsung 26.0 Cu. Ft. Side-by-Side...
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
407 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
