Question about Umax Astra 1200S Flatbed Scanner
Umax Astra 1200S Scanner Problem - continuing the search
(The below is dealing with UMAX Astra Scanner Problem with XP)
As part of the information I have gathered in regard to the above noted scanner, I was told that it might work with the Vistascan version 3.55
(vs355su.exe). I downloaded it and I get so far and then the system hangs at a place called something like "Creating Folders". It does not allow me to installl the whole program. Anybody ever come across this and figure a way to bypass the problem?
I just don't want to give up on a great scanner...
  • jrbns Sep 13, 2009
    Hello and thanks for your response. I have tried that (software from a different UMAX scanner) and I was almost there but the system crashed because of a driver called PV8630.sys. With the Vistascan version 3.55, it installs a driver called UMAXDRV.sys and I get the blue screen because of it when it reboots the system, and then have to do a Restore to before having installed the UMAX software. Apparently UMAX have not updated the XP drivers for the UMAX 1200s, but there should be a way around it. Thanks.
  • 3,153 Answers
Hugh.
This scanner has quite a few issues with regards drivers and XP and is quite an old model. I spent a lot of time with UMAX when I first had one. mine resides in a closet for spares due to issues with XP. Mose so once you get past SP2. I too tried drivers either side of the model with no joy.
Posted on Sep 13, 2009
  • Project NOMAD
    Project NOMAD Sep 13, 2009
    I did figure out that it seemed to be a registry error which is why running Norton win doctor seemed to fix the issue.
    Maybe if you have a registry cleaning program you could revisit my original answer and use that instead of norton ?
    Worth a shot if you must have this scanner ?
    My origianl answer woked in a repeatable way so I do know that win doctor fixed an issue in there but not exactly what it fixed.
  • 62 Answers
Why can't you download the drivers from the Astra site? You might have to get another model's drivers but at least it would be the same brand using the same syntax, which is probably why your scanner hangs as it doesn't understand the Vistascan syntax.
Good Luck
Hello i want umax astra 2100s scanner's drivers for free
As you requested, below is the link to the driver:
https://www.yousendit.com/download/bFlITGs2V3JBNkd4dnc9PQ
Please note you have 7 days to download the file before it expires. Below are the driver notes you are going to download:
Models Astra 2100S (SCSI) Driver UMAX UDS-is11 ISA SCSI Host Adapter Driver Manufacturers UMAX Data Technology (DTC) Microsoft Supported Operating Systems Windows 2000 Windows 2000 Workstation, Windows 2000 Server, Windows XP Home, Windows XP Professional, Windows 2003 Server, Windows Vista Uploader Notes This file contains the Windows 2000 driver for the Astra 2100S scsi scanner as well as the drivers for the scsi controller card. Also some support for the 1200S scanner is included as well. After downloading, double-click the file to start the extraction process. Accept the default unzip folder and continue by clicking the UNZIP button. There is a readme.txt file that explains what most files are so read it first. The large file is the driver/scanner software... Vistascan v3.55.
Jan 21, 2011 | Computers & Internet
My UMAX Astra 1200s worked fine with Windows XP Since a week ago I purchased Windows 7 my scanner doesn't I need help to get it working with Windows 7. Pascualita Gonzalez 916-422-4694
Most of the time Windows drivers are backwards compatible. (one exception, is the 64 bit OS)
Try this site for fresh drivers, come back if this does not lead to a fix.
Sep 27, 2010 | Umax Astra 1220S Flatbed Scanner
Drivers umax astra 1200s
Go on the link I paste here below to downlaod the copy of your driver:
UMAX Scanner Astra 1200S 2.43 Driver
Let me know for further instructions.
Dec 11, 2009 | Umax Office Equipment & Supplies
Umax astra 1200s with windows XP
This particular scanner is a nightmare to get working with XP
When it does work it is also prone to random errors.
On the UMAX australia site I found the information I needed to make it actually waok at all.
Below is part of a very old email that I went through with Umax maybe that will help you ?
It is quite an old scanner though.
Sorted out by steps as follows. Disconnect scanner usb lead from computer / hub 1. remove ALL umax software as issued on the cd and any upgrades 2. shut down restart 3. run norton (not the one button but the win doctor) to clean up any loose ends (important but dont know why ? does not work unless this has been done ??) 4. shut down restart. DO NOT connect scanner 5. Install software from original cd 6. do any umax software upgrades (ALSO IMPORTANT ) 7. shut down 8. plug scanner back in. 9. power everything back up 10. do new hardware wizard thing 11 swap driver to correct one as per instructions on your site somwhere ? all working I just did the norton one button on a second machine and it did not work so did all steps again but used norton win doctor as per step 3 and all good it worked a treat on two machine so it appears repeatable.
Sep 11, 2009 | Umax Astra 1200S Flatbed Scanner
1200s scanner
you can download it here
http://drivers.softpedia.com/get/SCANNER-Digital-CAMERA-WEBCAM/UMAX/UMAX-Scanner-Astra-1200S-243.shtml
Mar 21, 2008 | Umax Astra 1200S Flatbed Scanner
Vista driver for 1200S scanner
at the moment it seems no im afraid they run for mac ops to windows up to xp only.http://umax.com/download/index.jsp
you could email them and enquire will they be releasing a vista driver soon or intend to do so .
riz.
Nov 19, 2007 | Umax Astra 1200S Flatbed Scanner
Umax Astra 1200S Flatbed Scanner Logo
475 people viewed this question
Top Umax Office Equipment & Supplies Experts
Tony
Are you an Umax Office Equipment and Supply Expert? Answer questions, earn points and help others
