Question about Dishwashers
Dishwasher reservoir is still full of soap after wash cycle
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 24 Answers
The machine uses a solinoid to release the detergent lid at the appropiate time, This item may be defective in which you will need a service call. A common reason for this problem occurs if the lid is blocked by a item badly loaded in the basket.
Cheers
DeJudge
Posted on Sep 13, 2009
How to Clear out dish soap from the jet dry resevoir?
Use a shop vac and suck it all out. Then, spray some Pam-type cooking spray grease into the jet dry reservoir and then, A) start a normal wash cycle and stop it a few minutes after it starts the spray action. Then, open the door and look for suds. B) If you see suds, spray them with Pam spray to knock them down and then C) cancel the wash to drain it out. Repeat ABC until all the suds are gone.
Then, whatever you do, DON'T put dish soap in the jet dry reservoir again!
Good luck
Oct 21, 2014 | KitchenAid Dishwashers
Detergent is still full after 5 washings. I ran it through several cycles and purchased powder to run it and it still will not work
What? The soap lid won't open, or the soap won't dissolve? If the lid is opening, but the soap won't dissolve, then you're not getting proper water flow. Check your wash arms for clogged holes. The other thing to check is the sump area for a clogged food trap or clogged or broken chopper. You might be able to find a video on YouTube that shows you how to do this, otherwise, you should call a professional dishwasher repairman.
Sep 25, 2014 | Kenmore Dishwashers
Wont drain
Should not be any soap at all. If the soap has small shiny bubbles in it you have an oversuds problem which will cause the pump to cavitate during pump out. After setting for while the soap turns into water until the next wash. Easy fix is use 1/2 cup of liquid fabric softener and run thru complete cycle with heat dry off to dissipate all of the soap residue. Hope this helps.
Feb 02, 2010 | Dishwashers
13 year old daughter put liquid dishwashing soap in the rinse dispenser. Now all dishes come out covered in soap scum. How do I get liquid dishwashing soap out of the rinse dispenser?
Sorry but thats funny!!lol About the easiest way I know to tell you is take a turkey baster or marinade injector & draw as much as you can out of the reservoir,fill it with water & repeat until you get very little foam when putting water in it.Fill with rinse aid & the rest will just have to work its way through.Should be fine after a few wash cycles.
Jan 07, 2010 | Admiral 24 in. DWUA601 Built-in Dishwasher
Water in the bleach reservoir after each use
The dispenser door is caked with old soap and not closing all the way. (most likely)
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 01, 2009 | Kenmore HE2 Plus Front Load Washer
Soap dispensing problems on a kenmore dishwasher elite 577-0
is your soap door open when this happens if it is then make sure there's no water or other liquids in the dispenser from loading the washer one tablespoon of water in there will clump up the soap and it won't drop when it pops open
Dec 25, 2008 | Kenmore 24 in. 15252 / 15254 / 15259...
Kenmore 74362
I had the same issue and you will never beleive the solution.
Steps to follow:
1) run one full cycle with no dishes or soap
2) run one full cycle with a dishwasher cleaner like Jetdry
3) run one full cycle with a gallon of white vinager
4) never put soap in the extra in and only fill the main soap bin half way.
should work fine from here on out, but never fill main bin more then half way when you do dishes. also run the hot water in the sink until the water is very hot before starting the dish washer.
Dec 19, 2008 | Dishwashers
Soap dispensor door opens, but powder soap mostly stays in the cup
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehowsimple it was. thanks Ronnie " - ronnieshomes
Oct 15, 2008 | Maytag PDB3600A Built-in Dishwasher
Soap door won't open during wash cycle
its either the dispenser or the timer/pcb.
Mar 01, 2008 | Dishwashers
Dishwashers Logo
Top Dishwashers Experts
Owen Barnes
