Sony lcd projection tv in self diagnosis mode. 4 red flashes
I have a sony lcd projection tv product code kdfe42a12 and it has been stood unplugged for 2 months. when switching it back on the tv wont start but goes into self diagnosis mode flashing red 4 times in around 2 seconds. what does this mean, and how can i fix it?
  • 556 Answers
This is a fan error take the back off the set and see if the fan is turning.
Posted on Sep 15, 2009
Blank screen flashing red light 8x
Eight time blinks to sony TVs indicates Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board
May 12, 2012 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sony bravia KDF-50E2010 RED LIGHT FLASHES 4 TIMES THEN 3
Sony TV LED & Blinking Codes - What Does It Mean When Standby/Timer Light Flashes Sony has provided a "self-diagnosis function" with your TV, that in the case of abnormalities or problems the LED or red blinking light on the Timer/Standby indicator flashes a number of times to indicate the issue.
when there is trouble with your Sony Television set -- it indicates the issue in either the diagnostic mode, or even more commonly by flashing a series of LED blinks or flashes on the front of your television. Each set or frequency of the blinks indicates a very specific problem with the television itself.
Sorry but unless you may be able to repair the television set yourself , please call a local repair shop to the have a repairman sent out,,
Take care and please Remember to rate/vote for us to
continue f
or Helping out the Community :)
Jul 08, 2011 | Televison & Video
42 projection sony wega tv model kdf46e2000 turn on but red lite flash for 3-4 second then tv gose off
Your TV set has entered a protection mode, the system detects a failure. Try to unplug your set for 5 minutes to reset the system...
Sep 24, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Replaced a convergance chip..(ps8003) now tv
hello Eight GA_googleFillSlot("TL-IMU-Article"); blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board
regards
shaun
Feb 24, 2010 | Sony KP-46WT500 46" Rear Projection...
THE POWER STAND BY LIGHT IS FLASHING RED 4 TIMES
Anything less than 5 blinks is major trouble. More likely vertical IC and circuit failure. Picture has been muted or turned off by TV. If Stand By light was blinking 5 times the Stand By might have came out self-diagnosis function or mode.
Contact Sony Service Tech for service adjustment to fix problem.
Oct 21, 2009 | Sony KDF-E42A10 42 in. LCD Television
HOW DO I FIX THE RED FLASHING LIGHT PROBLEM IN SELF DIAGNOSIS MODE
if your TV is a mitsubishi thats the code for short protect which is most often related to the convergence Ics having shorted especiallif its a WS55809. Post your model number and I can assist you with determining whats wrong.
May 20, 2009 | Televison & Video
Sony 50 Wega LCD flashing red light
Hi
How many times is the red light flashing? The number of times the red led blinks means---
  • Continuous blink once a second, no pausing - No reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective.
  • One blink - not used for the self-diagnosis
  • Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
  • Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
  • Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
  • Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
  • Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board.
  • Nine blinks - Replace D 6116 and D 6301 on the "G" board, do not resolder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negitive).
  • Ten blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board.
  • No blinks(Unit is dead) - Problem in the standby power section. Might check fuse, R607, Q601, IC601, R612 and VDR601 (should show open).
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 01, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Mitsubishi wd-62327 red light
1. Self-diagnosis error 4-4, check for open F9A06 part # 283P128050 on the Power PCB. 2. Self-diagnosis error 4-4, check for proper seating of the DVI cable between the FMT PCB and the DMD (Light Engine). It may be necessary to disconnect and reconnect this cable to insure proper connection. 3. Self-diagnosis error 4-4, if F9A06 is good and the connection on the DVI cable between the FMT PCB and DMD are secure, suspect the Light Engine part # 939P977020 4. Self-diagnosis error 4-4, check F9A07 part # 283P128050 on the Power PCB, if open suspect the Light Engine part # 939P977020 5. Self-diagnosis error 4-1, suspect the Power PCB part # 930B929001
Sep 10, 2007 | Mitsubishi WD-62327 62" Rear Projection...
Televison & Video Logo
227 people viewed this question
Top Televison & Video Experts
Electro Med Services...
