Question about Xerox Office Equipment & Supplies
Xerox machine 5855 overwrite job message on machine pls how can remove
How to reset 5855 0 counter
Power it off and unplug the mains plug. After 5 mins plug the mains plug back in and power it up.
Oct 29, 2016 | Xerox 5855/APT COPIER PRINTER
Can't stop beeping
Machine needs something, press machine status button, the one with a question marks. Check "Consumables" for low toner, drum end of life or fuser end of life. Or cleaner or waste bottle.
Mar 19, 2014 | Office Equipment & Supplies
I have a xerox f116 faxcenter machine that I bought from an online auction. When I set it up and put a document in to fax, it came up with a message that said 'REMOVE DOCUMENT STOP TO CONFIRM'. The...
Go to the link below and see page 116 for your solution. The link below takes you to the users manual for your model unit:
ttp://download.support.xerox.com/pub/docs/FaxCentre_F116/userdocs/any-os/en/userguide.pdf
May 25, 2011 | Xerox FaxCentre F116 Plain Paper Laser Fax
My Xerox Wokcentre 4260 is stuck on one job. Some pdf file prints first 4 pages and then just sits there not doing anything, and the job still have "printing" status, and blocks all other tasks....
Solution : Perform an On Demand Image Overwrite (ODIO) Image Overwrite Security protects against unauthorized retrieval of confidential data from the machine by removing image data that is left when jobs are processed. When started, all of the physical areas of the hard disks holding job data are overwritten with a series of alphanumeric patterns.
There are two options for On Demand Image Overwrite: Standard and Full Overwrite. Standard ODIO will overwrite all jobs stored in image data as well as fax card image data. Standard ODIO will not overwrite fax mailbox, Poll store (mailbox 0) and dial directory information, or folders created with the Store Job feature, if these features are installed on the machine. Standard overwrite takes about 30 minutes. Full overwrite takes approximately 160 minutes to complete.
NOTE: Full ODIO will overwrite and delete all fax image data, including mailboxes, Poll store and dial directories on the fax card. Full ODIO will also overwrite any images that have been stored in folders created with the Store Job feature. When On Demand Image Overwrite is initiated, the machine is taken offline until the overwrite is completed. Any existing jobs in the queue are terminated, including print, fax and LAN fax jobs.
NOTE: Overwrites can also be performed on a per-job basis, immediately after each job has been processed, using Immediate Image Overwrite. See the Related Items below for additional information.
CAUTION: The machine should not be in Diagnostics mode when the overwrite is started. (The Touch Screen indicates a status of "Diagnostics Mode". This mode is used by Customer Service Representatives when servicing the machine.)
Do not power off the machine while an overwrite is in progress.
To perform an On Demand Image Overwrite from the Control Panel:
  1. Access the Tools screen. See the Related Items below for additional information.
  2. Select [Security Setting].
  3. Select [Image Overwrite Security].
  4. Select [On Demand Image Overwrite].
  5. Select the [Standard / Full Overwrite] button to switch between the two options, and select the required option.
  6. Select [Overwrite Now].
  7. The Overwrite Confirmation screen will be displayed. Select the [Overwrite] button to begin, or select [Cancel] to cancel the On Demand Image Overwrite. The machine will be taken offline and will be unable to receive any incoming jobs. The Image Overwrite will proceed to overwrite all image data on the hard disk.
    NOTE: If Embedded Fax is installed, all Embedded Fax compact flash data will also be overwritten.
  8. When the overwrite is complete, the On Demand Image Overwrite completion screen will be displayed.
  9. Select [Close]. The Disk Overwrite Confirmation Report will print. This details the status and time of the overwrite. The Network Controller will then reboot and network functionality will be unavailable for several minutes.
    When the machine has rebooted, verify that the overwrite operation has completed by viewing the Confirmation Report (under Confirmation Details). The Job Information: Status ESS Disk parameter should read "SUCCESS".
Apr 15, 2011 | Xerox WorkCentre 4260/S Multifunction...
How to open a message???help!!!!!
On the console you should find menu buttons. Find jobs or job prints. Select your number job and print it.
The menu buttons have many features you can scroll through. The print reports can print out the menu of the different menus of the fax machne.
good luck.
Feb 17, 2009 | Xerox WorkCentre Pro 785 Plain Paper Laser...
HI I M JIGNESh patel i was purchase xerox pe in my printer error is lsu how can i solve it pls send me reply
I'm not sure what the problem is or what machine you are using but follow the link below and enter the name of your machine and then the error message and it should help!
http://www.support.xerox.com/go/prodselect.asp?Xlang=en_US&metrics=HDR
Dec 06, 2008 | Xerox Phaser 8500/DN Printer
I HAVE A ULTRIUM TAPE DRIVE 920 IT ALWAYS ASK ME TO OVERWRITE THE TAPE BUT THE TAPE IS NOT YET FULL WHEN IT REACH THE CAPCITY OF 300GB, IT ASK ME TO OVERWRITE THE TAPE???? CAN YOU HELP WITH MY PROBLEM
it asking you to overwrite because that is how you set up the backup job. Setup a new backup job using append instead of normal backup and the message will go away. Its not problem its a feature to prevent you from overwriting data.
www.SanDiegoFixMYPC.com
Jul 15, 2008 | HP (DW017A) Ultrium Tape Drive
Top Xerox Office Equipment & Supplies Experts
Clive
Clive
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
