Question about LG Televison & Video
Hi, Am writing from Uganda requesting for expert help from Lg the manufacturer of the above TV model. I bought my Lg xcanvas 37lp1d from S.Korea i bought it in used state and has been working well since I got it in 2014 but about 8 months ago i started noticing anomalies; it started displaying flickering screen, slow to start, distorted lines appearing on screen, certain times when a decoder/DVD player is connected it would fail to display picture until both TV and gagdet are switched off and turned on again. Recently it completely failed to turn on. On switching on the mains the power on LED lights yellow, then it goes into a sequence of clicks as if its being turned on and off, but the yellow stays lighting, midway it starts to blink as though about to display picture and finally reverts to standby mode, yellow light turning red. when you switch off the mains and back on again it goes into the same cycle, again and again. Am not an expert in TV repair and i don't trust technicians here that is why am seeking help from Lg. I will be grateful if i get a response from you. Philip Uganda Mob: +256700800874. Note: the day before it could not turn on there was a lot of flickering screen and distorted lines and it appeared dim and generally power that day was less in voltage on the whole.
SOURCE:
  • 56 Answers
SOURCE: DVD player stuck in standby mode
Bad caps in the power supply is causing this. C17 (10v,470uf), C17,c14 (10v,1000uf) and C18 (10v,470uf). Replace with same capacitance values but 25 volt rating 85 C. Just fixed mine half hour ago works great.
Posted on Jan 22, 2008
SOURCE: MITSUBISHI CRT TV MODEL CT-33AC2SL
check for dry joints in power supply
Posted on May 09, 2008
jmeredith
  • 417 Answers
SOURCE: Picture fails
hi,
sounds like a high voltage issue, it will have to go in, i dont recommend self servicing that. may sound strange but Ive seen several tvs go by way of spouse having a plant above or near the tv, that person watering it and a few hours later mad spouse sitting in front of a busted tv that sounded just like that. also I had a cat that sprayed one and it did that. just a couple ideas for ya.
J
Posted on Jul 12, 2008
SOURCE: PB6110 Powers down after 30s, splash screen appears, red temp lig
Be sure to check the filters and make sure you have good airflow thru the proj. Cleaning filters solved our temp shutdown problem.
Posted on Nov 18, 2008
  • 4 Answers
SOURCE: My playstation 3 stays in the "standby mode" and does not turn on
its a power failure inside the ps3!!! You have to call sony to replace the system it will cost u 150.00 dollars unless ur still under warrenty goodluck because i had to get 3 systems from sony before i got one that worked just right
Posted on Mar 25, 2009
How do i change the language of my xcanvas set from korean to english
Write the words from the TV on apiece of paper, then go to Korean to English dictionary to translate the words so you can change it. It's a pain, but better than trying to learn Korean.
Dec 14, 2017 | The Computers & Internet
I own a LG XCanvas PDP HDtv. I bought it in Korea and it's a Korean (power source) model. I want to ship it to America and use it there. Is this possible and safe for the t.v. and my home? Is it worth the...
Sell it before u leave Korea,tv from Asia used PAL signal frequencies.US tv used NTSC signal frequencies,not compatible.Tv PAL to NTSC signal frequencies,will not work.PAL and NTSC signal frequencies can't be mix.
Feb 02, 2011 | LG 42LC2D 42 in. LCD HDTV
LG 37LP1D - Buzzing niose coming from TV
I blew condensed air through the ventilation holes in the back of the TV, which greatly reduced the buzzing noise.
Mar 03, 2009 | LG 32LX1D 32 in. LCD Television
Lg 37lp1d tv
Press the menu button on the LG remote. If you see the line affecting the menu, then the LCD panel needs to be replaced. If not then you have a signal issue.
Dec 03, 2008 | LG 37LP1D 37 in. LCD Television
Unlock the mobile
have a lg mobile model cyon kh 1200 .. i bought it in korea.. now i am in Bangladesah .. here i couldnt use the mobile ..it says " service area was not register ".. can u help me how to solve this problem
May 19, 2008 | LG Cyon
LG Plasma TV model #DU-42-PX12X
try contacting LG see if there is a backlight if there is that is most likely your problem
Jul 02, 2007 | LG 37LP1D 37 in. LCD Television
MY LG TV PICTURE
You have a vertical issue in the TV itself. It is best to take it in to a servicer.
May 28, 2007 | LG 37LP1D 37 in. LCD Television
Televison & Video Logo
13 people viewed this question
Ekse
