Question about Cuisinart Coffee Makers & Espresso Machines
Cuisinart dgb 650 warm water but no go the basket coffee
  • teinesamoa Aug 25, 2019
    Hi Andres Huerta, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    I'm not quite understanding your question.
SOURCE:
SOURCE: Cuisinart DGB-500 Filter basket opens during brewing process
broken basket.
Posted on Jan 04, 2008
  • 6 Answers
SOURCE: Water leaking from the base of the unit.
Water leaking in the DGB-600 is mainly caused by heated water escaping from its proper path. There is a rubber grommet on the underside of the upper part of the coffeemaker. (It contacts the lid over the filter basket when the front door is closed.) The design in this area is very poor; the grommet does not seat properly in the fixed part of the coffeemaker, and heated water seeps out. Also, the heated water tube that comes up through the cold water reservoir is actually in 2 pieces. One goes inside of the other, but there is no seal. It is a loose enough fit that some steam escapes, condenses on the inside top surface of the coffeemaker, and then finds its way down to add to the leaking. I completely disassembled my coffeemaker (3 of the screws in the upper compartment are hidden under small circular plugs that look like they are part of the plastic surface), and used high temperature automotive RTV sealer to help the rubber grommet seal better, and to seal the 2-piece hot water tube. Works great now! But I must say that I have seen better engineering in childs' toys!
Posted on Aug 12, 2008
  • 3 Answers
SOURCE: Where do I purchase replacement charcoal water filters for my coffee maker?
I found replacements at Bed Bath & Beyond
Posted on Oct 17, 2008
SOURCE: Cuisinart DGB-300 coffee maker brew pause valve
I just called Cuisinart and they will send me another brew basket for my DCC-100 (it has a Brew Pause valve also) for $9.14 (part + S&H). Did you try to contact Cuisinart?
Posted on Feb 03, 2009
ThaMp3Doctor
  • 8596 Answers
No one has just the individual part, but you can get the whole brew basket with the part included on Cuinart's website, or by calling them.
Posted on Feb 06, 2009
I have a cuisinart grind & brew coffee pot that leaks when I put water in it. How can I open it to see where the water is coming from?
The Manual for your coffee maker can be found here:
http://www.cuisinart.ca/pdf/ibs/en/DGB-600BCC_en.pdf
'Leaks' are usually caused by overfilling either the water reservoir or the coffee basket or by coffee grounds interfering with a seal.
Make sure you perform a complete cleaning on your coffee maker making sure any contact points which need to seal are free of coffee grounds.
Instructions for removing the grinder and filter baskets are contained within your manual.
Feb 06, 2011 | Cuisinart DGB-600 Coffee Maker
Where can I get a replacement grinder filter basket holder for a Cuisinart DGB 300 coffee maker
Go to this link to order directly from Cuisinart for items for your coffee maker. Just copy and paste into your web browser.
http://www.cuisinart.com/parts/coffee_bar/dgb-300.html
Hope this helps, let me know if I can help you with anything else.
JimmyC
Sep 30, 2009 | Cuisinart DGB-300 Coffee Maker
Feb 03, 2009 | Cuisinart DCC-100 Coffee Maker
Cuisinart dgb-600 brew pause feature doesn't work
Replace the filter basket - they can be had for around $6.00 plus shipping - you can even get them directly from Cuisinart.
Jan 23, 2009 | Cuisinart DGB-600 Coffee Maker
Need schematic to reassemble...
The filter basket is orderable from Cuisinart and costs somewhere in the neighborhood of $5 to $6 - there is no service manual for that particular part of the coffee maker.
-Tha Mp3 Doctor
Dec 05, 2008 | Cuisinart Thermal DGB-600 Grinder
Cuisinart DGB-600 replacement charcoal water filters is Cuisinart DCC-RWF 6 pack charcoal water filters, 12 filters.
Oct 17, 2008 | Cuisinart DGB-600 Coffee Maker
Won't start
DGB-300 - continuously beeping indicates that something is out of place - either the grind basket isn't exactly in place, the filter basket is loose, the water filter holder is out of place, or the lid of the coffee maker is open.
-Tha Mp3 Doctor
Jun 23, 2008 | Cuisinart DGB-500 Coffee Maker
Aug 30, 2007 | Cuisinart DGB-300 Coffee Maker
Coffee Makers & Espresso Machines Logo
Top Cuisinart Coffee Makers & Espresso Machines Experts
Pierre Laplante
Steve Allison
Steve Allison
Norman Worley
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
