Question about Jabra Radio Communications
I cant seem to pair my Jabra 65t to samsung s9
SOURCE:
SOURCE: Pairing with a phone
Turn the headset off. Then hold the main button (not the volume up or down button, but the button with the phone on it) for 7-8 seconds. When the light is a solid blue it is in pairing mode.
Posted on Apr 28, 2008
SOURCE: Cannot pair a7010 with Plantronics Voyager 520
The actual problem was Plantronics, I was not turning on pairing mode. I was confused with quick pair which starts not immediately after turning on, but you need to hold the button longer until led will start blinking blue and red.
Posted on Aug 23, 2008
SOURCE: how do i pair my jabra w/my phone. cant find
hold down the button till the light turns solid blue, then let the phone already in bluetooth mode find the jabra, it will ask for a password, enter 0000
Posted on Sep 09, 2009
  • 4 Answers
SOURCE: i cant pair my jabra bt125 with my nokia n97
This is one of the mistake commonly done by many people. First you need to pair. Let me walk you through. First, the headset has to be switched to pairing mode which is done by holding the on button for a while even after the headset is switched on. Then the bluetooth headset light will remain on. You switch on the phone bluetooth, search new device. Then select it and press the option for pairing. Read the instructions which come on the phone display and select accordingly. It will ask for passcode which is usually four zeros. Then it will get paired ask you whether to connect. You select connect and you are done.
Posted on Sep 10, 2009
fkuk
  • 311 Answers
SOURCE: how do I pair my s9 bluetooth headset with my
do you have the adapter that makes your ipod nano have bluetooth?
im guessing you do so
turn on the bluetooth adapter on the ipod
mod the power button on the motorolla s9 untill blue light is constantly on
from the ipod select the bluethooth options and select the headset
use the password 0000
Posted on May 14, 2010
How to pair the samsung galaxy s4 to the jabra cruiser
  • Touch Apps
  • 2.Scroll to and touch Settings
  • 3.Ensure Bluetooth is turned on
  • 4.Touch Bluetooth
  • 5.Slide the Power switch to turn the JABRA CRUISER on
  • 6.Press and hold the Multifunction button until you have a rapid flashing blue LED
  • 7.Touch the JABRA CRUISER in the list of devices
  • 8.The JABRA CRUISER is now paired
  • 9.The JABRA CRUISER and Galaxy S4 are now ready to be used
  • 10.Press the FM button in order to start streaming audio via the FM transmitter. The FM LED will turn red
Oct 01, 2014 | Jabra Cruiser InCar Speakerphone Black
Samsung reality won't stay connected to jabra bt2046
I've had this issue with lots of Jabra products, including both my BT3030 devices. The problem seems to stem from the quality of the charge. When the device is fully charged, it seems out a nice loud clear signal which can be detected by your phone. As the charge begins to wake the signal gets noisier. So (my experience shows), When you pair your device with a clean signal, that's what your phone is looking for. If you pair with a weak signal; it looks for that. The ideal seems to be too pair the items up when your bluetooth device is either fully charged, or mostly charged.
Think of it this way. You meet and are introduced to a strange man in the early morning who is clean shaven. You meet the same man a few days later with lots of stubble and fall to recognise him. It's a bit like that!
Feb 18, 2014 | Samsung Reality U820
How do i pair the jabra stone with the iphone 4? seems like i cant pick up anything from it when its in pairing mode.
Just did it myself. Ensure the iPhone is discoverable and searching.
Switch the Stone off by squeezing down the control surface until it bliddle-omps.
Put it into pair mode by squeezing the thang again until the bluetooth light flashes. Keep squeezing.
Watch the iPhone - it will pair automatically - no password required.
Sep 03, 2010 | Jabra Stone Bluetooth Headset
How do i pair my jabra w/my phone. cant find
Sep 07, 2009 | Jabra BT125 Headset
I just bought 2 Jabra handsfree sp700s and cannot seem to pair either one of them with either mine nor my husbands's phone. what could be the problem? I have a Samsung Eternity & my husband has LG...
I also have 2 sp700s. They worked fine for a while but now are very finicky. One of the problems is that the phone will sometimes say it is paired but the Jabra will not. I have found I can get them to pair correctly, if I disconnect the charger cable, so the SP700 is running on its battery, and then pair the phone. It will pair and work fine for a while after that. Repeat as necessary.
I suspect this is not your problem, but perhaps my work-around will help others.
Aug 22, 2009 | Jabra SP700 Bluetooth Headset
Can i pair jabra bt125 with samsung blackjack ??
Mine is a Blackjack II, but i did get it to connect. Hold the clear button down on the Jabra until it lights solid blue, keep holding it with one hand while you use the other hand to operate your Blackjack. I went to Settings, then Connections, then Bluetooth, then "Add new device". As long as my Jabra was lit solid blue, the phone found the headset. Then it will ask you for the pin code, which i found by accident (0000 - four zero's).
Jul 11, 2009 | Jabra BT125 Headset
Chocolate phone will not discover the Jabra BT150
you use your Jabra BT150, you need to pair it with your mobile phone. 1. Put the headset in pairing2 mode Make sure that the headset is on. Press the answer/end button and press the volume up (+) button at the same time, until a solid blue light comes on. 2. Set your Bluetooth phone to ediscoverf the Jabra BT150 Follow your phonefs instruction guide. This usually involves going to a esetup,f econnectf or eBluetoothf menu on your phone and selecting the option to ediscoverf or eaddf a Bluetooth device.* (See example from a typical mobile phone in fig. 4) 3. Your phone will find the Jabra BT150 Your phone then asks if you want to pair with it. Accept by pressing eYesf or eOKf on the phone and confirm with the passkey or PIN3 = 0000 (4 zeros). Your phone will confirm when pairing is complete. In case of unsuccessful pairing
Oct 07, 2007 | Jabra BT150 Wireless Headset
Bluetooth from Samsung D900 (HELP PLEASE!)
nback - DO AHARD RESET *2767*3855#
KEWL - BUT YOUR BT TO SEARCH SWTCH THE JABRA ON THEN PAIR THE P/W 0000
Sep 27, 2007 | Samsung SGH-D900 Cellular Phone
Radio Communications Logo
Top Jabra Radio Communications Experts
Anthony Ward
Anthony Ward
Bobby G
Bobby G
Damen Wong
Damen Wong
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
