Question about Infinity Audio Players & Recorders
Which button is the home button on my infinity dvr3 remote control
3 Suggested Answers
SOURCE:
SOURCE: Code for Comcast remote for Sony DAVHDX275
It seems like most (maybe all) Sony HTIB do not work with the Comcast Custom Remote. I've found a work around that fixes the volume control and power button though. Hope it helps you all. I have a DAVHDX275 but I think this will work for most Sony HTIB systems.
What you need to do is steal some codes from a like product and then hardcode in the changes you need to the comcast remote. Set your AUX to 21232 (a sony code for TV/VCRs).
Then do the following:
1. While still on AUX, press and hold SETUP again until the remote blinks twice
2. Type 994
3. Press and release SETUP
4. Type 32975
5. Press and release VOL+
The remote should blink twice. That should reprogram the VOL+ to work with your Sony HT device. For each of the following function codes, follow the same steps and use the codes listed below:
Vol+ = 32975
Vol- = 31951
Power = 32719
Good luck. Let me know if it works.
Posted on Nov 08, 2008
tariq_romy
  • 116 Answers
SOURCE: remote control power button and stop/play/home dont work
open the remote clean with petrol
or ony from dry cloth
thare was a corben in that key becouse that key are more useable so carben
Posted on Feb 19, 2010
Alarm issue with fx35
alarm should only be activated by remote or key, check your remote...
maybe the buttons are faulty, or take it to alarm techy to have the
control box checked. could just be moisture.
May 21, 2014 | 2005 Infiniti FX35
Samsung DVD Player remote buttons activate Samsung TV settings
To do a reset of the remote control follow the instructions below.
1. Remove the batteries from the remote control.
2. Hold down the Power button for a full minute.
3. Once done, put the new batteries back in and test the remote control. Please power cycle the unit as well by unplugging it from the wall and leaving it of for a couple of minutes. Once done, test the remote control again. To delete the recorded programs, please follow the steps below
1. Press the BD button on the remote control then press Home. This should bring up the home screen.
2. On the Homescreen, choose AllShare Play and press the Enter Button.
3. On AllShare Play, scroll down to Recorded TV and choose ''HDD''.
4. Now the titles of the recorded programs will appear.
5. Press the Tools on the remote control and select ''Delete'' from the side menu.
6. Select the titles to be deleted by highlighting them, then press the Enter button on the remote control.
7. Select ''Delete'' from the side menu then confirm deletion.
To try and resolve this issue, please reset the remote control. To do so, please refer to the instructions below: 1. Remove the batteries from the remote control. 2. Hold down the Power button for a full minute. 3. Once done, put the new batteries back in and test the remote control. Please power cycle the unit as well by unplugging it from the wall and leaving it of for a couple of minutes. Once done, test the remote control again. To delete the recorded programs, please follow the steps below: 1. Press the BD button on the remote control then press Home. This should bring up the home screen. 2. On the Homescreen, choose AllShare Play and press the Enter Button. 3. On AllShare Play, scroll down to Recorded TV and choose ''HDD''. 4. Now the titles of the recorded programs will appear. 5. Press the Tools on the remote control and select ''Delete'' from the side menu. 6. Select the titles to be deleted by highlighting them, then press the Enter button on the remote control. 7. Select ''Delete'' from the side menu then confirm deletion.
Jun 27, 2017 | Samsung LA40A550 40 in. HD-Ready LCD TV
Bose 321 series wont play region 1 dvd
To convert Bose 3-2-1 GS Series 2 DVD system to Multi-Region playback
1. Press the Right button on your remote control
2. Press the Up button on your remote control
3. Press the Shuffle button on your remote control
4. Press the Stop button on your remote control
5. Press the Mute button on your remote control
6. The disc tray should eject twice to confirm the region change
7. Press the Standby button on your remote control to power off your machine
8. After one minute, press the Standby button on your remote control to power on.
Done!
Nov 29, 2010 | Bose 3 2 1 GS Series II DVD Home...
Remote control power button and stop/play/home dont work
Feb 19, 2010 | Philips DVDR 3355 DVD Recorder
Need remote controller
Check out the Logitech Harmony series of remotes that can be programmed to operate all your electronics from activity-based buttons.  For example pressing the "Watch Movies" button will turn on the TV and select the DVD input, turn on the home theater, and turn on the DVD.  Then the buttons on the remote will control the appropriate device (home theater for sound, play buttons for DVD, etc.)
Go here for info: http://www.logitech.com/index.cfm/remotes/universal_remotes/&cl=us,en
Jun 02, 2009 | Insignia 42" LCD Flat-Panel HDTV
Remote locks the doors but will not unlock doors or trunk Battery
It is entirely possible that the unlock button on the remote is worn such that it is not making contact. I've seen this happen many times, as the unlock button is pressed so much more than lock. You might try to reprogram the remote first before you look into getting a new remote. The procedure goes like this. Close and lock all doors Key in and out of the ignition 6 times, hazard lights should flash twice Turn key into accessory or on position Unlock and lock doors with drivers switch Press lock or unlock on remote Hazards should flash again to verify recognition turn key off  manually unlock door and then open and shut it.  you should then be able to test remote.
The key to the procedure is doing step two quickly Hope this helps, if not you may need another remote or see dealer.
Apr 11, 2009 | 2004 Infiniti I35
2. Type 994
4. Type 32975
Vol+ = 32975
Vol- = 31951
Power = 32719
Sep 27, 2008 | Sony BRAVIA DAV-HDX267W Theater System...
Remote
Hi jimvandy
Most yamaha codes will work some of your unit functions. try 0176 or 1176. These are for a dvr3 comcast remote. You can get the whole list and manual from here
I am more than happy to answer any other questions you may have about it, just give me a hoy :) If you still have problems, before you give a rating for this advice, please get back to me and we can try some more things.
Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards
robotek
Jun 02, 2008 | Yamaha RX-V661 Receiver
Comcst remote control code not working
comcast dvr3 remote code for jensen sc2050j is 0150 [email protected]
Jul 27, 2006 | Jensen TS2050J 20" TV
Top Infinity Audio Players & Recorders Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
rjivaro
Are you an Infinity Audio Player and Recorder Expert? Answer questions, earn points and help others
